Question about Vector Vec143 Bright Bar Work Light
Which is the replacement of the lamp? which is the replacement of the ballast? I mean the model of each article
  • 283 Answers
In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service.
Posted on Aug 12, 2010
New member here. I have a 62" DLP Mitsubishi model #WD6252. I've already replaced my lamp AND ballast and continue to have the solid red lamp status indicator. I've made sure the connection from th
Your color wheel is failing or has failed. the red light ONLY means the lamp cannot light or was forced to shut down. it means nothing about the lamp or ballast specifically.
If your color wheel isnt spinning up correctly or you have a stuck fan somewhere, the lamp will be shut down immediately upon startup.
Id check to see if the color wheel is stuck or if its getting stuck.
Dec 17, 2014 | Mitsubishi WD-62525 62" Rear Projection...
I have replaced my Projector lamp, i have had a picture but has shut down and now will not give me a picture and led light blink five times, do i know i didnt reset the lamp setting when i first got my...
hi,
You have to check the lamp ballast supply board. If the Lamp ballast board is faulty the it will burn the new lamp installed. 5 blinks means the lamp is faulty. can be caused by faulty lamp ballast. To deal with the lamp ballast you should need a good knowledge in electronics. Because electric shock risk is involved. Also you need a new lamp
ok
Sep 07, 2011 | Sony KF42E200 TV
TV Model: Sony Wega KDF-55E2000 Projection lamp warning is on..and today a light red bar appeared at the top of the screen and light blue on the bottom..is this because the projection lamp needs to be...
Hello
There are two possibilities for this fault with Sony Projection tVs. The first is with the lamp itself. The second one is with the lamp ballast baord. Replace the lamp ballast board first. Because, it there is any internal winding short in the inverter transformar of the ballast board this type of fault can occur. you have to replace the ballast baord along with the new lamp anyway. Therefore, replace the ballast board first. If this help you, there is no need ot replace the lamp. Picture of the ballast included here for you to compare.
gopakumarg43_36.jpg If replacing the ballast dis not help you, change the lamp too. OK.
Aug 31, 2011 | Sony KP-57XBR10 57" Rear Projection...
Hey i have a panasonic Plasma tv (model: TH-42PW5 ). When i press the button to turn the tv on the green light comes on and stays lit, but there is no picture - the screen is dark. What could this be?
The problem is either from the lamp or ballast. Have you ever changed the lamp/bulb of your TV?
When the LED shows green, it means it is a lamp problem.
The ballast helps to ignite the lamp and make it function well. So you might have to replace the ballast also.
Good luck.
Mar 18, 2011 | Televison & Video
Have a model WD 55734 and the screen is completely black when turned on, and the tv makes a loud chirping or clicking sound that continues even when you turn the tv off. Lamp replacement??
Tv LED"LAMP"light flashes,projection lamp been inside the tv like 1 1/2 or 2 years?Used like 4 or 5 hrs daily?Yes,the tv projection is dead,should be replaced.The clicking noises,that mean the board call the Ballast board also dead,must be replacing too.The Ballast board only job it to ignite the tv projection lamp.
Feb 13, 2011 | Mitsubishi WD-57734 57" HDTV
Mitsubishi 52'' TV Model WD52525
U restart the tv,u hear alots of clicking?That mean the Ballast is dead or have problems,that why ur picture lamp not sustaning the picture.Replacing the Ballast might or will sustance the picture.
May 18, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Red light blinks 5 times
Hello.
5 blinks mean that lamp-ballast duo have a problem. Ballast (power supply for lamp) could go bad if you abuse it with older lamp by not replacing lamp when image become darker.
You have to replace lamp first. If problem would not go away - then next step is to check and replace ballast. It have to be done by skillful technician who suppose to check +5V trigger voltage supplied to the ballast before making decision to replace it.
Russ.
Apr 04, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a Samsung DLP Model number HL-T5075S that is giving me problems. Works for about 2 or 3 minutes then dies. I get the 3 LEDs that mean "Lamp" however the lamp has been replaced with Model #...
Hi,Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.The ballast is the most common failure on Samsung sets it has a sensor that detects if it's not lighting up the lamp or if the lamp is not responding.Pay attention to any sounds your tv makes. Here's the link to replace the ballast :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php Have a blessed one!
Mar 24, 2010 | Samsung Televison & Video
Tv lamp keeps blowing out
You need to replace the lamp ballast. You will need the full model number and version number to get the correct part. The numbers are located on the right side of the television.
Jun 09, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Ballast Unit
Ballast is nothing but it is lamp power unit so here high voltage operating unit. While change the unit please check the voltage ratting and model. connector model and then replace.
Regards,
prakash
Apr 03, 2008 | NEC Replacment Lamp Projector Lamp for...
Vector Vec143 Bright Bar Work Light Logo
377 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
