Question about Maytag PYE2300AY Electric Dryer
My maytag dryer model # mde7600apy has stop working. There is no power but the breaker is ok. Please help
  • Maytag Master
  • 3,361 Answers
Replace the thermal fuse located below the heating element.
Posted on Jul 28, 2010
Maytag dryer pye2300azw shut off when drying the clothes i check breaker from house to dryer that's OK it won't turn on back
This dryer is fairly easy to repair.
The thermal fuse is probably blown. Look for air restrictions and a bad blower wheel to be the culprit. When that blower wheel starts slipping it causes the dryer to overheat.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 29, 2011 | Maytag PYE4558A Electric Dryer
My maytag dryer model LDE7304ADE stopped working. I stopped it mid-way through, closed the door, pushed the "on" button and it made a weird noise. I tried again and now it doesn't make any...
Door switch broke???
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 27, 2010 | Maytag Dryers
Having problem with my Electric Maytag. I push the start button and nothing happens.. The model bumber is pyet344ayw..
Have you checked the circuit breaker? I would start there. Dryers run off 220v, and sometimes only one leg of the breaker trips. so you need to flip the breaker all the way off, and then back on. sometimes the breaker feels off when it's not. make sure you completely trip it off then back on. Does the dryer light work? is there any indication that it's getting some power? If the breaker is fine and your still not getting power, then the next step is to make sure you have power coming to the plug behind the dryer. At this point you should only continue if your comfortable working with electricity. Once you move the dryer you can check the outlet with a meter, or other circuit tester. If you got power here, then you'll need to start checking things on the dryer. you can remove the plate where the cord goes into the dryer and look for loose or burnt wiring there. If that looks ok, then you'll need to start taking the dryer apart; front panel, top, back, etc, as needed to access the wiring and controls. From here you can trace the wiring from the supply to the controls and to the motor, etc. look for anything burn, If nothing looks out of place you can start checking temp sensors, or fusable links. If this is above your head, then stop where your not comfortable and have checked by a service tech.
Sep 20, 2010 | Maytag Dryers
Maytag neptune dryer model mde3000ayw
you want to start at high limit thermostat or thermal fuse
its white and has two small wires
it sits on the heat tube
it could be black too
it is shaped like a warped ball
and is rather flat
sears has them in stock
ive included the part number to help
307473
Oct 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer stopped working (model LDE9334ACE - electric). Dryer light DOES NOT work when door is open. Checked circuit breakers and that's fine.
Check your timer switch, that would cause you light not to work.
Also check the bulb, it may be burned out.
I hope this helps
Oct 01, 2009 | Maytag Dryers
Maytag Dryer Has No Power
i am sorry to hear this, mdg model number means that you have a gas dryer, you have a fuse and thermastat that needs to be replaced which is beneath the top behind the drum, you will see a short element, a blue thermastat and 2 white wires that goes down to a fuse.
when you buy the fuse, it comes as a kit, the thermastat and 2 fuses, one of the small fuses you will not use because one if for an electric dryer, so look at your fuse and notice a dot, i do believe your dot will be yellow...
so lift up the top and you will see these parts
Aug 23, 2009 | Whirlpool LGB6300 Gas Dryer
Maytag Neptune Dryer not heating
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Mar 07, 2009 | Maytag Neptune MDE4000 Electric Dryer
Does not work at all
The maytag dryer has a main power board that controls every thing from the light to the heat time. You can change this board but probably it is best a get a new dryer. The board is very expensive because it is the brains of the machine. A technician will tell you to change the board but with the parts and labor it will be costly and who knows if something else will happen. You cannot tell unless this board is changed if there is.any thing else wrong because you need it before the unit will even turn on. I hope this helps you.
Nov 23, 2008 | Maytag PYE4557A Dryer
Maytag PYE2300AY Electric Dryer Logo
61 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
