Question about DaVinci Emily Crib
Lowering the mattress
We are not able to lower the mattress to the lowest level when using the Emily crib. The horizontal wood bar at the bottom front of the crib prohibits us from using the last bottom screw hole on the crib. I have a fifteen month old and she is already trying to climb out. I think lowering the mattress can help. Is it possible to use the bottom screw hole on the crib when using it as a crib, or is the bottom screw hole supposed to be used for the guard rail when converting the crib to a toddler bed. Thank you!!
I have the same issue... can anyone let us know if you have managed to put the mattress on the lowest (4th hole) setting? PLEASE.
Posted on Aug 03, 2010
Need to lower mattress to lowest posistion, how?
1). remove the mattress, bedding and any load on the mattress spring.
2). remove the bolts attaching the support frame to the crib
3). reattach at the desired level.
4). reattach all 4 points and tighten. Do not overtighten.
5). Replace mattress bedding and any load.
Any further questions? Contact the manufacturer directly. They respondquickly and have the most accurate information for the SAFETY OF YOUR CHILD.
Here is the website for Million Dollar Baby, DaVinci and Babyletto:
https://milliondollarbaby.zendesk.com/home
Apr 04, 2011 | DaVinci Emily Crib
I have a Bright Future for Baby Melanie wooden baby crib (product # 343-7407); how do you unhook the brackets in order to lower the mattress without disassembling the entire crib?
A:You remove the dropside by removing the bumpers and lowering. Then you loosen the screws on th wooden bar under the mattress base without taking apart . If necessary loosen the screws on the frame, but should only be necessary if the mattress base was put in with the straight hooks facing you. In any case you should not need to completely take apart, but still a pain!
Aug 03, 2010 | Toys
I need to lower the base to its lowest setting but not sure how ?
Remove the mattress. in all for corners you should see metal arms that are attached to the mattress support. these arms will be screwed into brackets on the crib. Unscrew all four screws and re-screw them into the lowest hole available. replace mattress and your done.
Jul 10, 2010 | Baby Gear
I need the instructions for the cosco heritage collection crib model number da0504kmc1w
This site has instructions for the cribs listed below. The 1st two listed seem to be generic cribs with a metal mattress support. It worked for my used crib.
www.milliondollarbaby.com/help.milliondollarbaby.com/
*For cribs with snap-in spring hangers hooks & metal mattress support.w/ spring hanger hdware.
*For cribs w/ bolt-in metal hdware for metal mattress support w/ metal hdware.
For cribs with Safety Glide nylon(rodless) hardware
Sleigh Convertible 3001 Crib
Sleigh Convertible 3091 Crib - Safety Glide
Jenny Lind Crib
Ashley/Alexandria Crib (1 piece headboard) +Day bed info.
Ashley/Alexandria Crib (3-piece headboard) +Day bed info
Lauren Crib ) +Day bed info
Emily Crib (One piece headboard) ) +Day bed info
Emily Crib (Four-piece headboard) ) +Day bed info
Mini Emily Crib
Anastasia Crib
Bridget Crib
Valerie Crib ) +Day bed info
Bailey Crib ) +Day bed info
Ellie Crib Day bed and full bed info
Kalani Crib Day bed and full bed info
Bordeaux Crib Day bed and full bed info
Annabelle Mini Crib
Italian Cribs-Metal Barrel Nut
Italian Cribs-Nylon Nut
Canopy cribs with snap-in spring hanger hardware
Canopy cribs with metal bolt-in hardware
May 17, 2009 | Baby Gear
Need instructions ofr converting crib to a toddler bed.
Jenny Lind Crib
Mini Emily Crib
Anastasia Crib
Bridget Crib
Annabelle Mini Crib
May 16, 2009 | Bassett New Haven 3 N 1 Crib
No directions to assemble a Simmons crib model 2746 76 219
Most of the cribs that you buy have directions on the bottom of the mattress board on how to assemble. They might not be word for word, but its pretty informative. Hey, it does have pictures! LOL
Apr 01, 2009 | Simmons Mattress Baby Gear
Lowering the Mattress
Call LaJobi (the manufacturer) and ask.
LaJobi 877-440-2224
Jan 19, 2009 | Graco Lauren Crib
Assembling Instructions model 01720-1
Jenny Lind Crib
Mini Emily Crib
Anastasia Crib
Bridget Crib
Annabelle Mini Crib
Dec 13, 2008 | Simmons Mattress Matino - Natural Maple...
Model 4624-1 Delta Luv Crib
If its like mine, you just remove the front panel that went up and down. Then lower the wood mattress support to the lowest level. You are now ready for the toddler bed. Once you want to convert to a double bed frame. You have to purchase a metal frame that holds the bed. Then attach the back and the front to the metal frame. This should like a sleigh bed. Good Luck, Nicol
Mar 01, 2008 | Delta Luv Delta - Baby Products 5-in-1...
Childesigns carrollton crib
I am not familiar with this crib, but I have been through many cribs and they all (so far) are adjustable to lower the mattress. You can figure it out by removing the mattress and matress board and inspecting the way the board is connected to the frame. Often there is a bar or rung that sits in a clip or groove at each corner of the crib just below the matress board. You may have to crawl underneath and look up at it. Usually you will be able to lower the platform without using tools, but be sure to take the weight off the platform by removing the mattress and board. Good luck.
Nov 14, 2006 | Childesigns Carrollton Crib
DaVinci Emily Crib Logo
191 people viewed this question
Top DaVinci Baby Gear Experts
Dennis Fitzsimmons
Level 1 Expert
ray gallant
Are you a DaVinci Baby Gear Expert? Answer questions, earn points and help others
