Question about GE GSS20IEP Side by Side Refrigerator
Water filter for ge tfx22cr
Where is the water filter for ge tfx22cr refrigerator?
  • 330 Answers
SOURCE: GE TFX22CR Ice Dispenser inoperative
Check the ice maker see it is in the right position, maybe you can try pull out the ice maker and clean it and push it back, make sure the position is right.
Posted on Jul 21, 2008
SOURCE: No water from dispenser ice works fine
My water outlet was frozen and wouldn't let the water through. Turn the fridge off and let it thaw out if this is the case. Regards, Phil, Brisbane Australia
Posted on Jan 14, 2009
professio101
  • 158 Answers
SOURCE: Water Filter Freezes
The filter is building up ans excess of water. When this waters freezes it expands and breaks the filter. Do you have a way to extend tubin, and install filter on the outside of unit?
Posted on Jul 20, 2009
aasc
  • 1606 Answers
SOURCE: I have a water softner in my house do I need the
If your using the correct bypass plug which came with the refrigerator , the water dispensor should still work . Make sure the plug is very snuggly , tight in place .
Posted on Aug 26, 2009
richroth
  • 9472 Answers
SOURCE: what temp should the freezer
The recommended setting for most all brands and types is 0-5 for the freezer and 36-38 for the refrigerator.
Posted on Feb 11, 2011
No dispensing water...GE refrigerator
There may be an interlock switch on the housing where the filter or dummy stopper is inserted. If this interlock is not satisfied, then the water dispenser won't turn on. This would prevent water from spraying all over the inside of the refrigerator if the filter is not seated properly. Check to make sure the filter or plug is inserted properly.
Apr 01, 2014 | GE Refrigerators
I have a water softner in my house do I need the smart water filter on the refrigerator GE model PSS26NGSA GE PROFILE. I use the filter bypass plug but there is no water running thru the dispensor. Do I...
Aug 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Jul 20, 2009 | GE Profile Arctica 25.4 Cubic Feet...
TFX22CR GE refrigerator TFX22CRXFWW does Not dispense ice.
I had this problem with a similar refrigerator. The problem was the slide switch burns itself especially if you slide it from ice to water while holding the glass in to get ice and water into your glass. Better to slide it to ice, press the glass in to get ice, release the glass to stop the ice, slide the switch to water, then press the glass in again to get water. I "fixed" mine by removing the control panel and soldering some of the connections on the slide switch together so that we now have no crushed ice function, but the ice cubes work again. You can also replace the circuit board in the control panel to restore it to like-new operation. I could not find a place to order just the slide switch.
Not sure if this is the same problem with your unit, but sounds the same.
Dec 06, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE TFX22CR Ice Piling up in Back of Freezer
You either have icing that you didn't clear or the unit is low on gas.  You might also try cleaning the condenser coils.  This is a big problem in cooling.
To check low gas:  After cleaning the condenser (!), clean around the piping to the compressor in the back of the unit.  Wait at least an hour with the unit shut off.  Restart.  The larger pipe should begin to frost up.  If after about 15 minutes the frosting gives way to: ice, wetness or drying out...the gas level is likely okay.  If it stays frosted, you'll need a gas recharge.
Nov 04, 2008 | GE GSS20IEP Side by Side Refrigerator
May 28, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Water dripping on GE Fridge model TFX24ZR
check your water filter. water preasure is important in the operation of the water valves. if the filter is ok replace the valve. water filter should be changed at least once every year.
Sep 10, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS20IEP Side by Side Refrigerator Logo
438 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
