Question about HP LaserJet 4050 Printer
Can't print pdf file
I am using a laserjet 4050 with the PS driver installed. I try to print a pdf file and it will only print the first page of the document. I am not printing the pdf file as an image. I have tried lowering the resolution to 300 dpi and that did not help, therefor i know it is not the RAM in the printer. Any help would be appreciated
  • 52 Answers
Try pcl 6 driver
Posted on Jul 29, 2010
Memory low message on hp laserjet pro 200
see HP LaserJet Pro Printers Memory is Low message displayed on the control...
HP LaserJet Pro Printers - 'Memory is Low' message displayed on the control panel HP LaserJet Pro - Troubleshoot 20.xx (memory failure) and 21.xx (print failure) error messages (ID: emr_na-c05049204)
HP Customer Support page and ensure the printer is running the latest available firmware. Print a Configuration Report from the control panel of the printer to check the installed firmware version.
  • If the printer supports expandable memory, you can install additional memory in the form of a DIMM. Check the printer's User Guide to see if it supports additional memory.
  • Break complex print jobs into smaller jobs that contain fewer pages.
  • If the printer is an MFP, delete stored faxes to increase available memory. Go to this document for instructions: HP LaserJet Pro MFP - Delete faxes from memory (ID: emr_na-c03264743)
  • Power cycle the printer to delete stored fonts or macros. It is possible to download fonts or macros in a way that power cycling the printer will not delete them; see Appendix A - Memory Allocation.
  • Changing some software and/or print driver settings might result in a less complex print job.
  • Use a different print driver. For example, a PostScript print driver will typically result in a more complex print file. If possible, try sending the file with a PCL6 or UPD printer driver.
  • Adobe PDF files can sometimes be very complex. Go to this document if printing PDF files is slow or resulting in memory out messages: HP LaserJet - Print job is slow or hangs in the print queue when printing Adobe PDF files (ID: emr_na-c04071740)
  • If the printer is connected via a network, try sending the file connected by USB cable only. This will eliminate possible network issues that are taking printer memory.
  • Appendix A
    Memory Allocation Utilities or jobs that you download to the product sometimes include resources (for example, fonts, macros, or patterns). Resources that are internally marked as permanent remain in the product memory until you turn the product off.
    Use the following guidelines if you use the page description language (PDL) ability to mark resources as permanent. For technical details, see an appropriate PDL reference for PCL or PS.
    • Mark resources as permanent only when it is absolutely necessary that they remain in memory while the product is turned on.
    • Send permanent resources to the product only at the beginning of a print job and not while the product is printing.
    NOTE: Overusing permanent resources or downloading them while the product is printing might affect product performance or the ability to print complex pages.
    Sep 08, 2016 | HP LaserJet Office Equipment & Supplies
    PCL XL ERROR
    Bad adobe command. Try printing as image in the print driver or using a PS driver.
    Jul 21, 2014 | HP LaserJet 4050 Printer
    My HP Laserjet 1320 won't print even modest sized PDF files. The Printer Window says "Error-Printing" I've had this problem for years. How can I get my printer to print PDF files? I increased the memory...
    If you are using a PS (post script) print driver, delete it and install the PCL driver (PCL5 or PCL6 if available). May help, not positive. I have seen lots of pdf printing problems with PS or incorrect model drivers.
    These drivers are free to download at "support.hp.com"
    Feb 06, 2010 | HP LaserJet 1320 Printer
    I have a hp laserjet 4050 that will print my files but will reverse and print same files again. what is the problem?
    Check your driver settings. Make sure the number of copies is set at 1 copie.
    Gerrit Jan
    Nov 01, 2009 | HP LaserJet 4050 Printer
    How do i get my 4050 to output copies in order, not backwards.
    By using the drivers. File/Print/Properties/Advanced. Drill down to Layout Options/Page Order. Set it for what you want.
    Oct 08, 2009 | HP LaserJet 4050 Printer
    HP 4050N drops pages when printing from WP4.2 under WIN98se
    • Unplug the printer cable from the computer.
    • Unistall the printer drivers from Device manager and also unistall the all the printer appications
    • restart the computer
    • try to download drivers from the website
    • after installing drivers and software it will ask you to connect the printer.
    • then you can connect the printer and and try to Print the test page.
    Hope this help. Please Rate My Response! Thanks!
    PREM
    Mar 12, 2009 | HP LaserJet 4050 Printer
    HP Printer 1320 PCL XL error
    hi,
    I'd suggest downloading and installing the PS (PostScript) driver from HP here: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=410624&prodTypeId=18972&prodSeriesId=410622&swLang=8&taskId=135&swEnvOID=228
    Then use the PS driver when you're printing .pdf files. Use your existing PCL driver when printing all other types.
    i hope it would help you...
    Oct 13, 2008 | HP LaserJet 1320 Printer
    Pale print on PDF files
    It sounds like a driver problem. Try replacing the driver for this printer on the printers folder, using the HP LaserJet Series II. With this driver, try again the PDF file and see if it prints correctly.
    Jul 25, 2007 | HP LaserJet 4345mfp Printer
    HP LaserJet 4050 Printer Logo
    504 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
