Question about LG Studioworks 700S 17" CRT Monitor
Control panel button?
Where is that... regarding my question that you answered.
    Genius:
  • 1,124 Answers
This is the button to get your menu on your monitor
Posted on Oct 14, 2008
How do I set the date and time and my hp passed all the fax tests but I do not receive faxes.
Follow the instructions below to set date and time on printer
Setting the date and time on an HP All-in-One Follow these steps to set the date and time from the control panel.
  1. Press Setup .
  2. Use the right arrow button (c00377082.gif ) to highlight Tools , and then press the OK button.
  3. Select Date and Time from the Tools menu and then press the OK button.
  4. Enter the month, day, and year by pressing the appropriate numbers on the keypad. After the date is entered, the Enter Time screen displays.
  5. Enter the hours and minutes by pressing the appropriate numbers on the keypad. After the time is entered, the Tools menu displays.
  6. Press the Back button to return to the main menu.
Follow the steps to solve "Unable to Recieve Fax" Issue
Basic requirement are..
1. Rings to answer should be 2 rings greater than your Answering machine rings or Voice mail ( set it to 6 instead )
2. Auto Answer should be on
3. Turn off ECM ( Error Correction Mode )
Use these steps to change the Rings to Answer setting.
  1. On the product control panel, press the setup button (c01661990.gif ).
  2. Use the right arrow key (c01661991.jpg ) to select Basic Fax Setup and then press the OK button (c01335940.jpg ).
  3. Use the right arrow key (c01661991.jpg ) to select Rings to Answer and then press the OK button (c01335940.jpg ).
  4. Use the right arrow key (c01661991.jpg ) to select the desired number of rings and then press the OK button (c01335940.jpg ).
Make sure that the Auto Answer feature is turned on When the Auto Answer feature is on, the HP fax product automatically answers incoming fax calls. When off, the HP fax product does not answer any incoming fax calls. To turn on the Auto Answer feature, follow these steps.
  1. Press Auto Answer on the product control panel. When the Auto Answer button is lit, the feature is turned on.
  2. Try to receive a fax.
Make sure that ECM is Turned Off ( Error Correction Mode )
  2. Use the right arrow key (c01661991.jpg ) to select Advanced Fax Setup , and then press the OK button (c01335940.jpg ).
  3. Use the right arrow key (c01661991.jpg ) to select ECM , and then press the OK button (c01335940.jpg ).
  4. Use the right arrow key (c01661991.jpg ) to select Off , and then press the OK button (c01335940.jpg ).
Try to Receive Fax Now.
These steps should resolve the issue and you should be able to receive fax
Thank you for contacting FixYa Team
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 13, 2010 | HEWLETT-PACKARD HP 6500 All In One Printer...
How do I turn up the volume on the monitor speakers other than on the PC?
You can use the screen buttons. At the front panel of the monitor press button 1. Scroll using up - down buttons to get at the audio adjust line. Press button 2. Use the up - down buttons to increase - decrease the audio level. Hit twice button 1 to save and exit.
At some models you can control the audio level using directly the up - down buttons, I'm not sure for yours.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Sep 04, 2010 | ViewSonic VX2235wm LCD Monitor
How do I reset drum counter on brother printer HL5250dn
Hello. if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Regards, Joe PS: kindly rate my answer. Thank you.
Jan 28, 2010 | Computers & Internet
I Have a HP laserjet 3380 and I do not know how to change the answer mode and rings to answer settings. Everytime the phone rings it goes straight to fax. It has distinctive ring set on it for the fax...
You switched it to manual. Can you switch it to automatic? (Then check "Rings to answer below)
1. On the control panel, press MENU/ENTER.
2. Use the < or the > button to select Fax setup, and then press MENU/ENTER.
3. Use the < or the > button to select Fax Recv. setup, and then press MENU/ENTER.
4. Press MENU/ENTER to select Answer mode.
5. Use the < or the > button to select Automatic or Manual, and then press MENU/ENTER.
The control panel display shows the answer mode setting that you specified.
Rings to answer default is 5 rings. Did someone change it? You can check that it is still at 5 rings:
4. Use the < or the > button to select Rings to answer, and then press MENU/ENTER.
5. Use the alphanumeric buttons to enter the number of rings-to-answer, and then press MENU/ENTER.
Dec 31, 2009 | HP LaserJet 3380 All-In-One Printer
What does control lock mean?
This means that the machine will not respond to any controls and will have to finish its current programme completely before it will respond to any operator controls again. It is very useful to stop anyone changing the programme mid cycle. It also means that if the power is cut or you have a brown out that the machine will just carryon where it left off and finish the programme.
To unlock the Control Locked feature:
Press and hold the End Of Cycle Signal button for 3 seconds to turn this feature off.
When the machine is running and Control Locked light is on, the machine can be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
Oct 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My heater on my 2003 x-type jag isnt working....does anyone have an answer Karen
karen, this is a very common problem on all x types .the part required is a heater controle panel .,it has three knobs ,the fault occurs in the circuit board built in to the controle panel , second hand from a jag breaker is about 50.00 pounds regards keith
Oct 01, 2009 | 2002 Jaguar X-Type
Control locked on my Whirlpool Duet GGW9250PW0.
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
(Tip Courtesy JSRock)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 22, 2009 | Whirlpool GEW9250 Electric Dryer
Control panel locked
At the far right buttons on control panel, the very bottom far right button says control lock. hold in for 5-10 secs and the control lock will turn off.
Aug 24, 2008 | Whirlpool GEW9250 Electric Dryer
Sharp arc 262 m
It means the drum for Cyan is due for replacement. Can reset with sim 24-7. Hit P * C * on control panel hit 24 then start (copy button) then select 7 enter. Select Cyan or C. Hit execute, then Yes. After complete hit CA button twice.
Don't forget to rate your answers please!
May 28, 2008 | Sharp AR-BC260 Color Copier
WHIRLPOOL WASHER MODEL# GHW9100 LW2
Try pressing & holding the "End of Cycle Signal" button in for 3 seconds. This button is used to Lock/Unlock the front panel controls.
May 05, 2008 | Washing Machines
LG Studioworks 700S 17" CRT Monitor Logo
27 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
