Question about Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I cant program any channels on my tv. Toshiba 42'' plasma. Do i need the remote or can i do it directly from the tv?
  • Toshiba Master
  • 5,521 Answers
Which specific model from Toshiba do you have? There are several 42" TVs released with the Regza name. Most of the manuals can be found on the Toshiba support web site. http://www.tacp.toshiba.com/customersupport/
The one that I have allows for the channels to be set from the On-Screen Menu. In the TV mode, press Menu (there is a Menu button on the side of the TV). Navigate with the arrow keys (CH+, CH-, Vol+, Vol-) to the Setup menu and highlight Installation and press Enter (the Menu button is also the Enter key when using the buttons on the TV). Then highlight Channel Program and then Start and press Enter. When the search is done, press Ch+ or Ch- to view a station. To add or delete channels, use the Channel Add/Delete that is one line below Channel Program. Use the enter key to change the check mark status next to a channel. If adding a digital sub-channel not previously found, enter the number manually on the remote using the 100 key to add the dash. If the channel isn't found, an error message will result.
I hope this helps.
Posted on Jul 28, 2010
I want to program the digital channels onto numbers on the remote.
The remote will have a DASH or DOT key to let you enter the digital channel numbers directly,
as in: for digital channel 53.2, you'd enter "5" "3" DASH "2"
To program digital channels into a FAVORITEs list, you'd have to provide the Mfr/model
of the remote control itself...
Mar 28, 2011 | Samsung PS42P2S 42 in. Plasma Television
Screen message- channel fixed. how do I get it to program channels in our ares ( direct tv satellite system)
If you are on a sat system then you only need one channel programmed, if you are using the cable input, if you just want the channels scanned for a local antenna, then you need to go to the menu and go to programming and change the cable/ant to ant and program.
Dec 13, 2010 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
It will not change the channels to the tv it is a
Hi,this will never works if your remote is not programmed for your tv set, if the original remote is not works you can fixed by cleaning it
any thoshiba remote will works its all the same frequency
hope that will help you
Mar 17, 2010 | Toshiba 42H81 42" Rear Projection...
Cant program our slvainia t.v with satelite dish remote
Your problem is common because there are so many products on the market these days.
That said, you can purchase one truly universal remote that will absolutely control all of your devices. Go to any TV/electronics store, even a radio shack and take a look at these. Don't be surprised by their price tags, as they are usually in the $100. range.
Jun 06, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Tv remote
I was looking for codes for you but cant find any compatible ones!
You can order the orginal remote for your TV at www.remotes.com
Have make and model ready!
Hope this is a fix ya solution for ya!
Jan 12, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Hitachi Ultravision will not change channels
Tuner may be fubar is the only logical explanation. Use external one. Repair not cost effective
Aug 27, 2017 | Hitachi 42HDS69 42 in. Plasma Television
1999 sansui tvm1915 tv
You'll most likely need a Sansui remote made to work with your specific model TV. I have similar problems with my Toshiba TV. Check eBay.
Nov 10, 2007 | SansuiM1315 TV
Tv not changing channels.
This likely has a bad main board.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Oct 05, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
Oct 02, 2007 | Toshiba 20AF44 20" TV
Toshiba REGZA 42 in. Flat-Panel LCD HDTV Logo
587 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
