Question about Panasonic Lumix DMC-TZ1 Digital Camera
My camera will not work even when battery is fully charged. I rubbed the contacts and it worked for 2 days. Now that doesn't work. Do I need a new battery or do I need a new camera? Also tried using rubbing alcohol and qtip on contacts.
  • 3,083 Answers
Sounds like corrosion on the battery contacts, or oxidation. They will have to be cleaned with a stronger abrasive (fine emory cloth or 800 grit sandpaper). Sometimes a pencil eraser will do it, but keep working on it, since it sounds like your problem. The problem could be a low battery and/or bad contacts. If cleaning the new contacts doesn't work out, get a new battery.
Posted on Jul 28, 2010
Testimonial: "Thanks for the advice- that worked! "
  • saoger Aug 18, 2010
    Bonjour,
    J'ai le même problème,
    Pouvez-vous me dire quelle solution a fonctionné?
    fine emory cloth ?
    grit sandpaper ?
    pencil eraser ?
    or new battery ?
    Merci
  • Panasonic Master
  • 6,826 Answers
Http://avc-cs.panasonic.co.jp/faq/1033/app/servlet/qadoc?QID=001570
I think that the battery might be going bad, not enough voltage.
But, if your battery has plenty of volts, and the camera doesn't work, then it may need service.
http://panasonic.net/support/gscn/
Posted on Jul 29, 2010
My camera not comming on
There are (2) common (non-terminal) issues that cause this problem.
1) the contacts inside the camera have become oxidized...., using the eraser on the end of a pencil..., rub (clean) the contacts inside the cameras battery compartment.
2) Modern Li-Ion batteries often last only (3) years...,(if you have good ones)...., so what happens is that as the batteries reach the end of their life span they quite often will work one day and not the next (but show that they are fully charged). Thus if you only have the (1) battery, you will not know if it is the battery, the charger or the camera. Go to your local camera store (with your camera & battery) and see if they are willing to put a new battery in your camera..., if it powers up it's your battery or charger. ask if they will then try to charge your old battery on their charger for 1/2 an hour..., this is enough of a charge to find out if your camera will turn on using the old battery.
Now you must ask yourself, if I need to purchase a new battery of charger..., is it worth it.
Sep 24, 2014 | Nikon Gorilla Pod Camera Tripod For...
No power - fully charged battery
How about cleaning the battery contacts in the camera first with a pencil eraser and then, with a cotton swab lightly dampened with rubbing alcohol.
Aug 02, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Camera switches on for a second and then swtches off btterey is fully charged
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 10, 2010 | Kodak EASYSHARE M1063 Digital Camera
When trying to charge battery green light flickers for hours
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 09, 2010 | Kodak EasyShare V1073 Digital Camera
My camera cant charge if I put it on the light it dosen't CHARGE EVEN IF I PUT MY USB CORD WHAT SHOLD I DO?
Please note that the camera will only charge from the computer if the camera is turned off. Also try a different USB plug. 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 09, 2010 | Kodak EasyShare M863 Digital Camera
It will not switch on, even with fully charged batteries
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 02, 2010 | Kodak EasyShare M853 Digital Camera
Wont come on even when a new battery is installed.
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 21, 2009 | Kodak EASYSHARE M1063 Digital Camera
Have a kodak m1033 that seems to be frozen in the "off" mode. Have replaced the battery twice, works for a day or two then won't/can't charge and can't get the power light to come one even with the charger...
All Technical equiptment can have problems Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 19, 2009 | Kodak EasyShare M1033 Digital Camera
My kodak easyshare V1003 camera will not turn on. It worked a few days ago and now it will not charge or turn on. I just bought new batteries and it still will not turn on. Any suggestions on how to fix...
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 4. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 09, 2009 | Kodak EasyShare V1003 Digital Camera
My camara turns off when i turn it on even with new batteries
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 4. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 08, 2009 | Kodak Easyshare M753 Digital Camera
Panasonic Lumix DMC-TZ1 Digital Camera Logo
161 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
