Question about Sony Cyber-shot DSC-H2 Digital Camera
Can't get camera to go into Manual Focus
I've been using my camera to take close up pictures of jewelry and beads, using macro filter/lenses. Because of this, I've been using the manual focus, instead of auto-focus. However, something changed in the settings when I took the camera on vacation and started taking standard vacation pictures, and now I can't get any response from the camera when I push the focus button next to the shutter button. I have put the camera into single, monitor and continuous options in the AF Mode of the menu. Is it possible that the button is simply broken now, or is there a setting that I'm missing?
  • Scot Stecher May 11, 2008
    That did it! Thanks!
    Problem Solver:
  • 8 Answers
Hey, i have one too, just take the camera out of auto adjustment and put it in say, program auto or some other setting on the thumb wheel...
Posted on May 10, 2008
I would like an instruction manual please.
The user manuals coming with lenses most of the time have little information about how to use them. The lens will have a MF and AF and perhaps a VR switch. If you want to learn more about macro photography, check this site from Ken Rockwell, where he is explaining how to do so with a Nikon camera.
Be aware the macro lenses are designed to focus close to the camera and will have the sharpest pictures close to the camera. I would not say you can't use a micro as a tele, but the results with a normal 105 could be better.
Still I think you have a great lens with your Sigma.
How to Shoot Macro
Mar 31, 2015 | Sigma Telephoto 105mm f/2.8 EX Macro...
What lense can i use for close-up shots
That would depend on the camera, but I'm going to assume you have one with interchangeable lenses.
The camera manufacturer probably makes one or more "macro" or "close-up" lenses for your camera. Any of these lenses will let you get closer than a normal lens. Many third-party lens makers also make macro lenses.
Another alternative is to put extension tubes between the lens and the camera body. This moves the lens further from the camera, shortening the focus distance.
Probably the cheapest (and lowest quality) alternative is to put close-up lenses on the front of any lenses you already own. These screw on to the front of the lens like a filter and act like a magnifying lens, letting you get closer to the subject.
Sep 07, 2013 | Computers & Internet
HOW TO PUT Fotodiox 49mm Filter Thread Macro Reverse Mount Adapter Ring for Sony E-series
The ring threads onto the front of any lens with a 49mm filter thread, just like a filter. The front of the lens then fits onto a camera body, effectively mounting the lens "backwards" or reversed. With most lenses, this allows the lens to focus very close, for close-up or "macro" photography.
Mar 14, 2013 | Fotodiox 49mm Filter Thread Macro Reverse...
28-80 how to set for macro
Hi, for macro work you should set it to the 80mm end, this will give you the closest focus, some lenses may have a macro or 'M' switch, you could also add some close up filters to the lens to get even closer.
Jun 19, 2012 | Nikon Cameras
Focusing
For taking pictures of things close to the camera, switch to macro mode. There's a slide switch on the end of the camera, near the USB socket. Slide it to the flower position for macro.
Don't forget to switch back for taking "normal" pictures.
Nov 30, 2011 | Vivitar ViviCam 8025 Digital Camera
I can't get the lens to focus at all on any close up setting manual or auto. I have been trying to take pictures of flowers and insects with it set to close up and I have tried also with it on manual...
The 70-300mm lens won't focus closer than about 5 feet (1.5 meters). If you need to get closer, there are several alternatives. Here are some in descending order of cost (and picture quality).
A special "macro" or "micro" lens. Some lenses are designed to focus closer than others.
Extension tubes. These are tubes that fit between the lens and the camera body. By putting more distance between the camera and the lens, the focus point moves closer to the camera.
Close-up lenses. These are like filters in that they screw onto the front of the lens, but act like a magnifying glass.
Sep 04, 2011 | Nikon AF 70-300mm f/4-5.6 ED Nikkor Lens
What is the lense for taking a profetional picture from crafts (indoor)
By "crafts", do you mean things like figurines or models?
Most any lens (other than fisheyes or super-wide-angle) will work so long as the object is within the lens' focusing range.
If you need to shoot up close, you will either need close-focus filters (basically screw-on magnifying lenses) or a lens with "macro" capability. Other lenses typically cannot focus on objects closer than about two feet to the camera.
It also helps to have decent lighting, which cannot be controlled with the camera alone.
Apr 12, 2011 | Nikon D40x Digital Camera
The distance focus ring, is it supposed to turn all the way to the macro symbol when you are focusing on a subject that is very close?
If you're right "on top" of the subject - then, yes - it should indicate "macro". Macro focusing is for "very up close" photography and is exactly as you describe. You simply physically move the camera a little closer to or further from the subject to focus.
Not all lenses are capable of macro focusing. The vast majority of these non-macro lenses are required to be at least a couple (or more) feet away to focus. Macro lenses on the other hand can usually get just inches away - which is a great capability.
Enjoy your macro lens!
Oct 12, 2010 | Canon EF 28-80mm f/3.5 -5.6 USM Lens
Cannot figure out how to take good macro shot with new Tamron len
With an SLR you only get true macro focussing on a lens that has proper macro focussing abilities. Unfortunately in the photogaraphy world, there are a huge number of lenses which claim to have macro ability but are stretching the term far too much.
Strictly speaking, macro means that the lens is capable of producing images on the sensor which are the same size as the actual subject or even bigger, at life size this is described as 1:1 macro. Your Tamron lens is only capable of a maximum 1:3.7 "macro", and that's only at the 200mm zoom setting with the subject no closer than 45cm from the lens. By SLR zoom lens standards, that's actually pretty good, but if you want to go closer and get greater magnification you need to either use a supplementary close-up filter lens or for better optical quality use a set of extension rings. The trade off with close up filter lenses is poor image quality and usually plenty of colour fringing and with extension rings is that if you're using a 2x magnification at 200mm, your f5-ish maximum aperture at 200mm becomes a very dark f10.
The only way to get good macro results is to either use a proper (=expensive) macro lens and excellent lighting, or use extension rings plus a good ring flash unit. However you can improve your macro by investing in a more capable zoom lens with a closer minimum focus distance and a better aperture at the telephoto end of the range. This can be expensive, or you can pick up some very cheap 35mm film SLR lenses. Using an adapter will never allow you to achieve infinity focus on a Canon digital SLR but you can get a close focussing 200mm f3.8 very cheaply. The crop factor of your smaller sensor means it will have the same angle of view as a 310mm lens but the aperture will remain at f3.8. As Canon digital SLR's have the deepest body register (lens to sensor distance) of the current systems then you'll also have the effect of using it on an extension ring. The downside is that you'll have to use the lens in a totally manual mode as no information will be communicated to your camera body. By mounting the lens back to front using a reversing ring you can achieve some really stunning macro magnifications but then you need a tripod, powerful flash and absolutely no wind... There was also a Makinon 80-200mm zoom which sells for next to nothing on auction websites, but it had a macro collar which allowed it to achieve around half size macro (1:2).
Alternatively, if the Fuji still works and does the job just keep it in your camera bag ready for those types of shots. overall, that seems the easiest and best solution unless you really want to get heavily into macro shooting.
I hope that I've helped you, please ask more if there's anything unclear. I've tried to keep a very complicated subject as simple as possible. Please also take a moment to rate my answer.
Mar 05, 2010 | Tamron 28-300mm f/3.5-6.3 DI XR for Canon
Pictures of sporting events all blury
have you got your camera set to continuse focus this will cause this set the camera to on shot
Sep 28, 2008 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Sony Cyber-shot DSC-H2 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
