Question about Frigidaire FGX831C Top Load Stacked Washer / Dryer
Washer won't remove all water from final spin.
Washer goes through it's cycles, the dial moves as it should and then for the final spin it just stops. I've tried restarting the cycle from the beginning and also from the last cycle that worked but always the same result.
My stackable washer/dryer is about 3 years old, purchased in 2007 and gently used.
My neighbor stopped by to look at it and said he thought it was a small rectangular motor located on the bottom front of the washer and two hoses came into this part that needed to be replaced. His online research said it cost around $87. He also verified it wasn't a lid issue.
Unfortunately this friend has moved and I don't recall the name of the part I need to order.
Can you confirm his diagnosis and tell me the name of the part I need to order and where I can purchase it, whether it be in my area or online. I need it ASAP. My zip code is 75002, Allen TX.
Thank you in advance for your help!
SOURCE: Frigidaire Front Loader Won't Drain
if your washer is digital or with elecronic control board check the the motor control board located at the bottom difiniely you have to call a tech to confirm that. other model like wd5595 and wd 8095 has the same problem and it is the motor control unit that always fails.
Posted on Apr 06, 2008
melnavz
  • 1226 Answers
SOURCE: washer cycle not starting
Did you read the user manual of your whasher? Unplug the washer to the wall out let and then verify carefully whats going on. maybe some unwanted material in it..check all the necessary components and test again.
notify me for what did you notice. melnavz
Posted on Apr 09, 2008
barkencoa
  • 3463 Answers
SOURCE: washer will not drain on regular cycle
The problem is certainly related to drain hose and or outlet connection.
Make sure it is not trapped or kinked behind the washer.
Changing the position of the washer could esily have caused the hose to twist and restrict the outflow of water.
Plz rate my solution.
Thanks,
r.
Posted on Jan 07, 2009
  • 50 Answers
SOURCE: Frigidaire front loading washer stopped at rinse cycle. 3 beeps
When in doubt check the easiest thing to check. The pump can cause a number of errors to come up. Since the unit stopped in rinse I would start but checking to make sure there is nothing obstructing the pump before going to the expensive parts.
Posted on Feb 26, 2009
sudel
  • 90 Answers
SOURCE: How do you remove top of new washer so dryer will sit on top?
There should be 2 screws at the rear of the top section. Remove those screws and pull the top backward and it should come off.
Posted on May 20, 2009
Whirlpool washer model lsr8233eqo
So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
Feb 03, 2013 | Whirlpool Washing Machines
Washer cycle not starting
Apr 09, 2008 | Frigidaire FLEB8200DS Top Load Stacked...
My Frigidaire front loader washer drum will not turn or agitate but will fill water and drain water, what is the problem?
Hello acoach194 - If the washer is not agitating try the following steps:
1) Verify a circuit breaker isn't tripped
2) Advance the timer control dial slowly 360 degrees-
If the washer starts spinning, then the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this. If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, then it will need to be replaced. If it is loose, then it will need to be tightened. A professional will need to do so by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt.
Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, once again call a pro.
3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem.
Dec 17, 2012 | Frigidaire FTF530FS Front Load Washer
Agitator won't spin and water won't drain during spin cycle
Hi
Try these things first.
If the washer starts spinning, then we know the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt. Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem. Go here. If the motor isn't spinning, then go here for washer motor troubleshooting.
If none of these tips resolve the problem, then there's probably a more serious problem with either the motor, the transmission or the agitator itself. If this is is the case, call in a pro.
Thanks for using Fixya.
May 22, 2011 | Maytag Washing Machines
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Final spin /rinse cycle won"t stop
It's usually a control board problem. sorry for the bad news :(
Jul 07, 2009 | Maytag EPIC MFW9700S Front Load Washer
Will not discharge water or go into spin cylcle.
I would have to guess you have a dead spot in the timer. If it stops moving, it would still tick like a clock but the internals of it are not catching to send it into discharge and spin.
Apr 03, 2009 | Washing Machines
Washer fills but won t advance to the next setting for all cycle
Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Frigidaire FGX831C Top Load Stacked Washer / Dryer Logo
16 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
