Hi.
There is more than one wire going from control board to the tub. If the connector can be plugged either way without forcing it, then usually does not make any difference the way you plug this determined connector.
It will be useful to know wires colors, and where wiring is connecting .
Color codes are also different depending on the country.
If the contact is 120V AC connector (eg.pump), it does not make any difference the way you connect it.
If wires are going to Drain pump, in UK those should be black , gray or brown for wire coming from drain contact on control board through over flow micro switch (gray from control board to switch).
Check drain and screen. If clogged, clean it out. If not clogged, check pump to make sure it's not missing fins or loose or clogged
The previous expert has mis understood the question. I do not need advice about the draining problem.
I only want to know how to re-connect the wire that attach to the baseplate.
how do I tell which way round to connect the connector with 2 coloured wires to the base plate?
many thanks
Jeremy
Thanks for your response, which I don't fully understand, please can you explain this without using electrician terminology, i'm not an electrician. what is the:
drain contact?
overflow micro switch?
where is the control board?
when you say "gray from control board to switch" does the word switch mean the connector on the baseplate?
many thanks
Jeremy
