Question about Saniflo & Saniplus& Macerator Pump
My saniflo has started to go slow- it now does small pumps - one every 30 seconds so takes 5 minutes to drain the bowl. I'm pretty sure no foreign objects have gone into it as it's only me and my wife here. Been installed about 2 years so just out of warranty (bought it 2.5 yrs ago) would the descaler help? other recommendations?
    Scholar:
  • Saniflo Expert
  • 115 Answers
Typically when solids don't leave the toilet after one flush or if it short cycles like is doing, then is definitely a pressure problem. Is the unit vented via an 1 1/2" vent pipe to the open air? Please disconnect the vent pipe and leave the vent connection open to the room, flush the toilet and check if it makes a difference. Air must flow in and out of the vent pipe at all times so it can work properly. An obstruction on the vent pipe can cause this issue. Also could be calcium build up inside the rim of the bowl. Pour a few cups of vinegar on the toilet tank and then flush the toilet, it should get rid of calcium right away.
Posted on Jul 30, 2010
The saniflow is trickling and filling up bowl then flushes itself
You need to adjust the float. Or, you can buy the complete inexpensive float valve assembly at Lowes or Home Depot and can install it in less than 5 minutes. Turn off the water supply, drain the tank, sop up the remaining water in the tank or put a pan under the tank opening for the next step, remove the valve assembly and float and install the new valve assembly with the float included. Turn on the water supply and set the water level adjustment valve to about 1/4 inch below the stand pipe overflow drain. This is done by the float assembly. Turn on the water supply. This completes the change-out.
Oct 12, 2014 | saniflo"" turboflush toilet"
My neighbours saniflow toilet is drivng me mad. The motor keeps whirring every 5 mins. Whats the problem, please!
Water pressure is what makes the unit kick on and off. If its kicking on by itself most likely water is somehow draining back into the pump. Start by checking the flapper in the flush valve inside the toilet tank, it may be leaking water into the bowl and from the bowl into the pump. Also inspect the check valve inside the 90 degree elbow where the waste is pump out from. The check valve may not be closing properly and is allowing waste water to drain back into the pump creating water pressure making the unit kick on and off by itself.
Oct 07, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
System works perfect however the pump now has started turning on every 10 or 12 min and runs for about 2 seconds then shuts off
This means that water is draining back into the pump, creating enough water pressure that is making the pump kick on and off at all times. You need to inspect the check valve inside the discharge elbow where the waste is being pumped out, the check valve may be obstructed or may need to be replaced. Also check the flapper on the flush valve inside the toilet tank (water closet) the flapper may not be sitting properly allowing water to drain into the bowl and from the bowl into the pump.
Dec 08, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
I AM RESTORING A T020 MF. I REPLACED ALL WIRING AND IGNITION SYSTEM AND REBUILT THE CARBURATOR, AND ADJUSTED IT TO SPECS. I GOT IT TO START RIGHT AWAY AND IT SOUNDS GREAT. HOWEVER, IT WILL ONLY RUN FOR...
Ok a quick check. When the engine cuts out and you go for restart it dies within 5 seconds. Next time put the ignition at position 2 (on but not starting) and wait one minute, then start the car. If the engine again runs for 30 seconds before cutting off this tells you its is a fuel problem. If the fuel is supplied slowly it fills the carburettor fuel bowls and when the car starts it quickly uses up these local reservoirs of fuel faster than they can be replenished. When you try to restart immediately there is only a tiny amount of fuel and so it used up almost immediately. By leaving the ignition on 2 for while it gives the pump time to fill the carburettor bowls and this takes a while longer to run down when the engine starts. Just before moving on does the car have a choke OK remove the low tension connection to the coil, basically remove any chance of a spark. Put a big old towel around the carb. Now remove the fuel line at the carburettor and put ignition on 2 to engage the starter pump. Listen to pump operation and look at the rate of fuel being pushed from the disconnected fuel pipe. If the flow is slow check on pump and filters.
Sep 13, 2010 | Ford F-100 Cars & Trucks
I have a saniflo macerator toilet system and when flushed, the pump does not immediately come on and the water level rises up pretty high. only then the pump comes on for a second or two but the bowl does...
Did you put an 1 1/2" vent pipe? It must be vented to the open air. Air must flow in and out of the vent pipe at all times so it can work properly. I had the same issue but after removing the cheater vent from the vent pipe it solved my problem. They do not recommend using an air admittance valve, cheater or mechanical vent on the vent pipe, as it only allows air to flow in or out.
Jun 09, 2010 | Saniflo SANIBEST Pump Macerator Grinder...
Toilet bowl, and pump housing are full, drain pipe clear? pump not running correctly. how do i drain it to get acsess to pump?
Prepare to get dirty. Use a mug with a handle to lift the water out of the toilet bowl into a bucket. Reduce the water level until it stops increasing from the backflow from the Saniflo. Disconnect the electrical connections (isolate the unit first) Disconnect the outflow pipe but be prepared for some spillage from any vertical pipe in your domestic installation. Ease the boot off the WC soil pipe, Disconnect any breathers. Slide the unit out from behind the toilet but maintaining a backward tipping angle to prevent water inside the unit from spilling out of the boot. Take the whole unit outside, keeping it tipped backwards. Take the lid off, noting how the seal is oriented for reassembly. Use a high pressure garden hose to clean out the interior and inspect. Check the rubber diaphragm on the bottom of the sensor unit. These develop corrugations and become slack over time. If so it will have insufficient power to depress and release the microswitch within the sensor unit. If your unit filled the toilet bowl with soiled water and the pump kept running, it is likely that the non-return valve beneath the outlet pipe is faulty. On some models the valve is Y shaped and the branch of the Y is a rolling ball that falls by gravity when the pump switches off. Replace the valve. If your unit kept running but with clean water in the bowl, it is likely your diaphragm is faulty. Check for corrugations and make sure it is no longer caked with accumulated solid waste. If you cannot buy a new sensor unit complete with diaphragm, you may need a new Saniflo. Both of my Saniflo units stopped working satisfactorily after 10 years. My German built unit has now been working without fault for 19 years.
Apr 25, 2010 | Saniflo & Saniplus& Macerator Pump
I thought my macerator toilet must be blocked as it wasn't emptying in the bowl and when I flushed again the water (and waste) filled more into the bowl and leaked out of the top of the macerator spilling...
Typical saniflo costs about 500 quid incl vat from plumbase, prices vary according to what you need it to do.
It keeps making noise becasue the pump is still trying to get rid of the water inside.
it can't get rid of the water most likely because their is a blockage in the waste water pipe.
if possible follow where the waste pipe runs to. if it goes in to a loft or somewhere else VERY COLD there is a good chance that it has frozen somewhere along the pipe.
If you are tying to pump the toilet waste vertically (upwards) then as soon as you turn the power off to the saniflo, the waste will fall back down and in to the toilet - or over the top in your case, sorry!
You might want to accept the inevitable and get a bucket and start removing the waste water from the bowl. Make sure that you have rubber gloves and I suggest goggles and something protecting your mouth - in case you get splashed.
Easiest solution, is to remove the excess waste water, turn off the saniflo, pour some bleach in to the toilet bowl, then cover the bown securley with cling film to keep the rank smell at bay.
Other wise, start tring to follopw the waste water pipe and warm it up, either by directly or indirectly (warm air gun) or by warming the area around it.
Personall;y i am using the easy option. the cold werather won't last forever, but can you use a toilet elsewhere in the meantime.
In the meantime, Saniflo claim about 15 years as the lifespan, but i have never know a saniflo to make it past 3! they are not ideal, but may be your only option.
consider whether you could get a proper toilet waste pipe put in, as it WILL save money in the long run...
Hope this helps a little bit.
Mark
Jan 08, 2010 | Saniflo & Saniplus& Macerator Pump
Our saniflo is suddenly making a continuous grumbling noise and no water is clearing. We are pretty sure nothing has been put down it as we are all v careful. It is very cold here and has been for weeks. A...
Jan 07, 2010 | Saniflo & Saniplus& Macerator Pump
F21 code on kenmore he2 plus
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Sep 17, 2009 | Kenmore HE2 Plus Front Load Washer
Saniflo not flushing corectly
Does the shower or sink back up into the toilet bowel after running for a few minuits?
If not:
The bowel is clogged. Fill it with water then use a plunger
Nov 21, 2008 | Saniflo Sanibest Grinder Pump Only 013
Saniflo & Saniplus& Macerator Pump  Logo
885 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
