Question about Whirlpool GC5SHEXN Side by Side Refrigerator
The flap on my icemaker on my whirlpool gc5shexn003 is not staying closed causing melting and ice jams. there is a round looking item atached to the flapper swing arm that appears to be loose. I don't know where to connect it to place tension on the flapper
2 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: ice dipsencer door flap
You have a Mechanism delay come out. it holds the flaper open and close it slowly. is the end with the arm on it broken you will have to disassemble the dispenser front to get the new one back in... let me know Thanks
Posted on Aug 18, 2007
Whirlpool side by side with water and icemaker. My water works perfectly fine but my ice maker no longer produces ice. It runs but it's not getting any water to make ice. What can be done to fix this?
There are a couple reasons your icemaker will not fill with water.
First thing you want to check for is a frozen fill tube to the icemaker. The easiest way to check for a frozen line is to remove the icemaker. Once the icemaker is removed look for ice in the fill tube. If there is ice in the tube the (water valve) will need to be replaced. You can melt the ice by forcing hot water up the fill tube.
Another reason could be the icemaker is not sending voltage to the water valve. The fix for this issue is to replace the icemaker. Hope this helps you with your whirlpool fridge!
The reason to change the water valve with a frozen water line is because the solenoid is not closing all the way. This allows water to enter the fill tube of the icemaker and freeze based on the temperature.
May 04, 2017 | Whirlpool Refrigerators
My Whirlpool refrigerator, model GT22DMXGW00, leaks. Water is accumulating in the bottom-underneath the right hand side crisper. It then drains out onto the kitchen floor. Some is freezing too. It is...
check the ice door flap where ice drops into a glass.sometimes the flap doesn't close completely and allows heat to enter threw the flap.this causes frost to build and melt thus you have water you can't explain. hope this helps.
Dec 11, 2014 | Whirlpool Refrigerators
I have a whirlpool refrig model # ED5VHEVB06. The door where the ice comes out has a flap that does not close completely and a small black plug dropped onto the floor. Now the ice gets jammed and do
sorry , but to properly fix the problem you need to disassemble the door frame from the inside panel, if you are capable you may do but better to have trained technician to do it
Mar 18, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Indoor icemake is jammed
you don't mention a model or type of icemaker, but here is what I have done in the past.
Sometimes the ice melts together (door left open, etc). Take out all your ice and put into an ice chest, making sure that any large pieces are discarded or used elsewhere. Clean out any ice or pieces on the ice feeder screw or arm. Then close the door and make sure the screw it is rotating without any ice in it.
If all is OK, then put the ice back in and that should solve the problem. Good luck.
Dec 10, 2010 | Whirlpool Refrigerators
Whirlpool icemaker microswitch location
If the icemaker is still in the refrig ,(easily removed with 1 screw ) pour about 2/3 cup of water into it . Also check the black fill hose which is above the icemaker fill cup , to see if it is frozen closed . If the icemaker dumps the cubes , and doesn't refill with water , replace the water inlet valve behind the refrig . If it doesnt dump the ice , replace the icemaker . My parts site is down , or I would give you part numbers for the water inlet valve and the complete icemaker .
The laser light should flash 2 times , pause , flash 2 times etc , if working correctly . If the laser light is not on , then the icemaker is in the harvest mode . If it stays off , icemaker is bad . If you close the flap on the left side of the freezer , the light should go off , until you release the flap . If these factors are ok , then the optics are ok .
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side ice maker
its possible that ice is jamed in the ice crusher compartment this happens to me as well the ice drops down to fast causing it to clog and then stays open until it all of a sudden you pick it up on the floor thanks from gilles
Mar 15, 2009 | Refrigerators
Freezer side has icing problem
check to see if the flap for the ice maker is open and or in need of cleaning, also look at the gaskets on the unit. Put vaseline on them if they feel brittle and it wilkl rejuvinate them.
Feb 01, 2009 | GE GSS25JFM Side by Side Refrigerator
Ice maker flap stay open
the solenoid is bad,next time send the full model number it says it's a ge so this should help you out,for now you can get a ball of paper towels and stick it into the shout where the ice comes out to stop the warm air from getting into your freezer
https://www.youtube.com/watch?v=jpXo0svta9s
Feb 07, 2018 | GE Profile Arctica Stainless Steel Top...
Whirlpool GC5SHEXN Side by Side Refrigerator Logo
37 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
