Question about Ovens
The fan motor needs to be replaced. The repairman who looked at it said he applied direct current to the fan and it wouldn't move. I have the model BTOBR0050
  • montyw719 Jul 28, 2010
    Thank you for your quick response. It almost sounds too easy, but hope you are so right.
    President:
  • 2,047 Answers
Usually when a fan has gotten direct current appliede to it and it doesnt work then it needs to be replaced as you have said. To replace the fan take out all the screws on the sides so you can access the back panel where the fan is located. after taking out the side screws then you do the same to the back screws take out the back panel and loose the fan out to know the model make and type get it replaced at any hardware store and put it back the way it was removed. Although it is very advicable to get an expert to get this done for you as it might end up spoiling the entire system.
Hope this solution has been helpful?
Posted on Jul 28, 2010
Noisy fan cda oven model DC940
Sounds like either your fan/motor has come loose or there is debris or junk in the moving parts.
Suggest remove the side panel and clear/clean the fan.
Be sure to disconnect the electrical power and stay conscious of the sharp sheet metal edges.
If this is an older model I suggest is time to purchase a new one.
Why ? Older models usually have other worn parts that will soon fail - after you do your marvelous fan fix a couple of months later the thing could give out wasting your time and efforts.
Nov 19, 2017 | Ovens
Electrolux insight ekc6044k
If light comes on and oven still heats then probably needs new fan motor. best to seek out an appliance engineer.
warmest regards
Richard the Repairman
Colchester Repairs in Essex
Mar 29, 2014 | Ovens
Hotpoint de47x/2
These ovens often use methods of regulating the fan voltage or current limitors inside the motor itself , to test this it requires a fair knowledge of electrical motors as there are several types used in fan housings, not knowing this model I can only give you a General guide
Let me know your competance level as far as electrical testing is concerned. As the danger of electric shock from a a/c or d/c motor is quite considerable.
Nov 13, 2013 | Hotpoint Ovens
I have a Thermador Model C302U wall oven the fan on the uppper oven starts and then stops and I get the F34 code I am thinking to replace the motor but I want to know if there are other things I should...
When that fan starts up the air pushes against an air switch and that tells the board the fan is blowing. The stove uses a DAC system that relies on switchs to confirm the operations of the fan. the DAC control uses signal voltage to detect switch function. The air switches must physically close by air movement from the cooling blowers before the oven proceeds into a bake or broil mode. Reason being f the cooling motor does not function and the oven goes into a bake or broil mode, the oven will overheat and could damage the fancy smancy over engineered piece of garbage electronic components. My opinion. This is not for the DIY unless you are a TV repairman.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 03, 2011 | Thermador C302U Electric Double Oven
Neff fan oven dead. Where do I look next? I've
this could all so be the timer For all Free appliance repair videos visit our VIDEOTUTORIALS Nefffan oven element video1, If the fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Dec 17, 2009 | Neff U1721 Double circotherm Electric Oven
Candy oven noisy fan
Noisy fan means bushes are worn. cant be repaired. needs replacement. Quote model of oven to spare parts supplier and replace. Make sure power is unplugged and not just switched off before repairs are done.
Sep 14, 2009 | Candy FP855 Electric Single Oven
Noise exhaust fan on my Amana AOCS3040
The exhaust fan on my oven (Aosc3040) is loud also and has always been. Just hope nothing significant brakes because this model has been discontinued and it is difficult to get parts for it. I have been told by Amana that the life expentency of this oven is 10-13 years, so don't invest in anything that is not necessary. The glass door broke on mine and I cannot get a replacement piece. My kitchen looks terrible. It is a shame because the oven works great. Linda
Oct 06, 2008 | Amana AOCS3040 Electric Single Oven
Fan assisted oven
Like a clothes dryer.. simply applying heat and not moving the air will be less efficient than moving the air so the same principal applies in an oven..
Oct 03, 2008 | Ovens
Thermador built-in double wall oven -- replace cooling fan?
No, do not try it yourself. When the motor is bad sometimes it won't have the power to start itself. With a push it will take off. If you try to remove it yourself you will risk damaging cabinet, the oven itself, floors and/or yourself. Please trust your repairman. We are trained and experienced. Not everyone Is out to get you!
Feb 11, 2008 | Thermador Ovens
Convection fan not working
Check for a bad fan motor or a jammed blade.
Jan 01, 2007 | GE Profile JK915 Electric Single Oven
Ovens Logo
18 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
