Question about Ovens
I turn on my oven/convection oven/broiler and it turns on and starts to heat (pre-heat). After about 20 seconds, it shuts off with everything flashing "PF"
I have the same problem and would like to know if its a DIY fix.
Posted on Jul 28, 2010
Does the top element turn on during pre-heat on an Kenmore 790.92 range
No, the top element was designed to only work on the broiler setting.
Sep 20, 2014 | Ovens
Broiler element doesn't work
Reseating the Element The broiler is heated using an electric element which should be clipped in to the top of the broiler enclosure. If this has come loose then it might not be making contact with the necessary terminals. Try to reseat the terminal but before doing so you must ensure that the electricity is turned off.
Testing the Element The element is what heats up and cooks the food in the broiler. Over time the heat can damage the broiler element. These elements are supported by stand-offs and if the element burns out or becomes damaged then this can be a common reason why the broiler isn't working.
The easiest way to test whether this is working is to turn the broiler on and look at the element. If it is working correctly then the element should be glowing red.
Another slightly more complicated test for the broiler element is to remove the element from the oven and disconnect it. Then use a multimeter to check the continuity of the element. Set the multi-meter to measure resistance and then put it either side of the element. The normal measurement should be between 20 and 40 ohms. If the element is infinitely resistant then this means it's broken and will need to be replaced.
Testing Oven Controls Another reason why the broiler will fail to work is because of problems with the oven controls. A thermostat is used to set the temperature of the broiler, and the oven selector controls are used to control the setting of the broiler.
Turn the oven controls on to see whether the broiler is working properly. If not the controls can be removed and tested using a multimeter. Check the outputs to ensure that the controls are working correctly.
These can also be replaced if required by fitting a replacement part designed specifically for your oven.
Read More: Troubleshooting an Oven Broiler Doesn Work
Feb 09, 2014 | Thermador SEC302 Electric Double Oven
GE Monogram 30" built-in oven turns itself off after a few seconds.
Likely you need a thermal cutoff replaced near where your heating elements are. It senses the fault and shuts down. You can but an after market thermal cutoff from most any electronic parts supply, and maybe even from an appliance parts supply.
Nov 12, 2013 | GE JTP20 Electric Single Oven
My Creda convection oven does not heat up. The
THIS SOUNDS LIKE THE ELEMENTS HAVE BURNT OUT TO FIX FIRST TURN OFF THE POWER THEN LOCATE THE SCREWS HOLDING THE PANEL INSIDE THE OVEN REMOVE ALL SCREWS AND PANEL THEN REMOVE THE ELEMENT FROM ITS PLUG CONNECTION TAKE THE ELEMENT TO A ELECTRIC AND PLUMMERS SUPPLY STORE REFIT ELEMENT AND YOUR OVEN SHOULD WORK FINE .
Nov 20, 2009 | Ovens
Jenn air ww2780 shuts off in humid weather
check bake element if bad replace if not may have bad power control board
Jun 24, 2009 | Ovens
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
Bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Dec 17, 2008 | Bosch Ovens
Ovens Logo
63 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
