Question about Toshiba Televison & Video
TOSHIBA TV MODEL CX35D80 SOUND DON'T WORK IF YOU RUN CABLE TV WITH NO CABLE WORKS FINE WITH THE CABLE BOX
  • 556 Answers
SOURCE: No sound and no picture for tv and cable option
  • your problem is due to
  • rf in socket loose or defective
  • loose contact near tuner or it is defective
  • supply absent to VIF OR TUNER section
  • print cut in VIF section.
  • hope this will help.
Posted on Oct 25, 2007
SOURCE: no picture no sound
I have the same problem so it would be helpful to know if you've resolved this issue....
Posted on Jan 05, 2008
SOURCE: onkyo reciever (R550) and comcast cable box won't talk to each other
Having the same problem, Please help.
Posted on Apr 23, 2008
  • 71 Answers
SOURCE: help
use tv/video or input button to switch to av input
Posted on May 10, 2008
yambo
  • 230 Answers
SOURCE: Toshiba 36AFX61
Just Connect signal to tv and run autoprogram. Or use video input jacks from converter to tv ( yellow,white and red video in ) and select tv/video on tv pannel front ( don't need remote control) I hope this work for you.
Posted on May 11, 2008
32" toshiba 36a60 plays DVDs but not cable TV
Did you switch video inputs from the remote, each input has its own menu item.
May 19, 2017 | Toshiba 32DF46 32" TV
Toshiba HD ready TV ct 90158 makes high pitched sound
A high pitch sound can be a capacitor losing power it would sound a bit like a fire work. most have back up on the board but it put more pressure on them the more times you use the tv. would check them and replace. all of them can be 5 in a row in some models.
Oct 23, 2013 | Toshiba Televison & Video
Toshiba 27D46 will not come on?
It may be a fuse. But something else may have blown the fuse. I would check the circuity of the power supply.
Oct 27, 2012 | Toshiba Televison & Video
No sound
Try putting in a DVD or VCR tape..if they don't make any sound either...than you have probably blown an audio board fuse... But I bet that they will have sound which in that case the problem is more than likely the cable ITSELF not the box... the cable that carries the signal your tv has video on one wire and audio on another.. then sheilding etc.. it's probably got a short in audio ( I have seen brand new cables to do this so even if it looks ok try different one.) if that don't work... hook a different tv up at that location and see what happens... and then it's to call cable company to come fix the box which probably blew up scrambler... which would show that the output is working fine but unfortunately your tv is not able to dis cipher the audio because it's a tv not a cable decoding device...I hope that helps you.
Jun 22, 2012 | Sony KDS-R60XBR1 60" Projection HDTV
I have a cable box connected to reciever and was working fine for months, now i get no picture on tv only sound. I use hdmi cable out to tv that also uses my ps3 to tv which is working fine. What...
I don't know what kind of TV you have and what kind of output capabilities you have but, while your receiver will transfer your video signal, it is not the ideal way to hook it up. The port you are using may have to be reset somehow or, may have gone bad. Ideally you want to hook all video componenets directly to TV then, use, digital optical is best, audio out from TV to receiver. If you have more than 1 input in to TV, you can run your PS3 and cable box directly to TV, using the TV's menu to select which you are using, then, run your audio out to receiver.
May 23, 2011 | Denon AVR-887
Cable box remote doesn't work when tv is turned on.
I am having this same problem with our Mitsubishi LCD Flat Panel TV, Model LT-46246 ans our Scientific Atlanta remote cable box, same model as yours. We cannot use the remote at all to change the channel. I called Mitsubishi and they said they have never heard of this. I find this incredibly hard to believe. Time Warner, our cable provider says that it is not the box because it works when not hooked up to the TV. What a pain. I would love to hear if anyone else is having this problem or has a fix for it.
Mar 25, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Toshiba 36AFX61
May 11, 2008 | Toshiba 36AFX61 36" TV
No audio
try to reprogram the channel. it seems that your tv's sound circuit is fine.
Jan 09, 2007 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
Televison & Video Logo
67 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
