Question about GigaFast Ethernet GigaFast EE400-R Router
Gigafast Ethernet Router
Could you tell me what steps to take in gaining access to the configuration page of this router?
    Problem Solver:
  • 6 Answers
Make sure you are connected to the router:
goto START
Select RUN
Type CMD and hit ENTER
A black box will appear in there enter in IPCONFIG and hit enter
You are looking for the default gateway. Maybe 192.168.1.1 or something like that:
When you have that information open up your browser, enter in the default gateway IP address where you would normally put the website address.
username:
password: admin
Now you should have access to the configuration page.
Posted on May 01, 2008
NSN 1600, restored to factory settings, no internet access, internet light blinking fine, help
Some people find configuring Nokia Siemens Residential Router 1600 with BSNL is a little difficult. So I would like to present a tutorial to setup Internet connection with BSNL using Nokia Siemens Residential Router 1600. Just like other BSNL modem/ router models, we do not need any setup disc to configure Nokia Siemens Residential Router 1600. All we need is to follow some simple steps and adding some values. We can also setup wireless and wireless security from the web based setup page Configure Nokia Siemens Residential Router 1600 In order to configure Nokia Siemens Residential Router 1600 with BSNL follow the steps below.
1. Connect Nokia Siemens Residential Router 1600 to computer using Ethernet cable
2. Power on Nokia Siemens Residential Router 1600
3. Type 192.168.1.1 on address bar of Internet Explorer and press enter
USER Name: admin
Password : admin
Now you can access the web based setup page of Nokia Siemens Residential Router 1600.
Apr 09, 2013 | Computers & Internet
What is the default passwoed to get into the router?
You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Let me know if you need further assistance. Thanks for using FixYa.
Jun 29, 2011 | GigaFast Ethernet (EE410-R) Router
Access routers configuration and wireless filter to edit MAC List to add MAC adress
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
Then check wireless or wi fi settings you find there MAC filtering or mac security edit that list then save and restart router.
Dec 10, 2009 | Computers & Internet
Gigafast ethernet won't let my Xbox connect to live
You might open this ports to the Gigafast Ethernet router :
TCP 80, 3074 and 53
UDP 88, 3074 and 53
Note: You'll needing to open these ports to the virtual server or port forwarding under advance settings of the router.
Mar 06, 2009 | GigaFast Ethernet Gigafast 10/100, 8-Port,...
Zyxel nbg334w router configuration
Hi
To configure the wireless router it is recommended the it is connected directly to router.
Please follow these steps to fix your issue
1. Reset the router using reset button on the back of the NBG334W router
2. Configure or change the laptop ehternet adaptor setting to "Obtain IP address automatically.
3 connect laptop and router using ethernet cable. check the ip address using ipconfig command in DOS prompt. If IP address is 0.0.0.0 or 169.X..X..X run command
ipconfig /release
ipconfig/ renew
best way restart the computer
4. if you still have issue in getting ip address double check ethernet cable and try reseting the router again.
5. Still problem persist install new firmware on the router. you can download router firmware from
http://www.zyxel.com/web/support_download_list.php?indexflag=20040906164737&ModelIndexflags=0,420070320142921
Please vote if this information is helpful in resolving your issue
Dec 27, 2008 | Zyxel Prestige 334 Router
How to Configure Nomadix AG2000W from scratch
hello!
-- what is the exact model number of your access point and router?
-- what is the ip address of your access point and router?
-- what is the operating system of your computer?
-- Is your computer directly connected to the router?
-- Do you have a wireless computer? what is the model number of the wireless adapter
if you want to configure your access point with your router you may try the ff:
Step 1: Connect the Ethernet port of the access point to one of the Ethernet ports of the router
Step 2: Make sure the power adapter is plugged to an available power outlet
Step 3: Check if the corresponding LEDs on the access point are lit
Step 4: After connecting the devices together, configure the access point’s wireless settings
Step 5: Open the access point’s web-based setup page
Step 6: When the access point’s web-based setup page opens, change the SSID, Channel, and Wireless Security.
Apr 21, 2008 | Nomadix AG-2000W 802.11a, 802.11g/b...
Tew-630apb
hello!
Apr 07, 2008 | Trendware TEW-630APB (TEW630APB)
Wireless conections
Try the http://192.168.1.1 to access the router config page (needs Ethernet cable to be connected to the Router)
If config page still does not appear, then check your Internet Explorer settings> Security Level (not set to custom) If it is, then choose RESET ALL ZONES TO DEFAULT LEVEL and then try this address again. It worked for me.
Dec 26, 2007 | Zyxel Prestige 660HW Wireless Router...
GigaFast Ethernet GigaFast EE400-R Router Logo
148 people viewed this question
Top GigaFast Ethernet Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you a GigaFast Ethernet Computer and Internet Expert? Answer questions, earn points and help others
