Question about Singer CE350
My thread is constantly breaking!!!! I HAVENT EVEN GOTTEN ONE MONOGRAM DONE DUE TO THIS!!!! HELP ME! oh and i thought i wasnt properly threading but i am! and still getting error message!
  • Singer Master
  • 7,365 Answers
1.needle in backwards
2.upper tension to tight
3.needle bent-try rolling the needle on a flat surface to see if it's bent or not
4.thread may be hanging on bobbin case-check for lint or fragments of old thread
5.try different thread
Posted on Jul 29, 2010
My Pfaff hobby 1200 keeps breaking the thread while free motion quilting.
I'd try switching the needle type & size and then a different brand of thread.
5 things you need to know about thread when free motion quilting
Machine Quilting Thread Shreds Then Breaks
Thread Top Thread Breaking Shredding while free motion quilting NEED HELP
Thread breaking or fraying when free motion stippling
Oh, yeh, one more thing I just thought of: Rethread the top thread and make sure the thread is not hanging up on the spool, spool pin, or wrapped around a thread guide. When my thread breaks after 3-4 inches, it's usually because something is stopping the top thread.
Jan 14, 2018 | PfaFF Sewing Machines
The upper thread keeps breaking whenever I sew even though it is always properly threaded and the needle is fine
check the age of the cotton
cotton is not a single thread but a series of fine threads bonded with a glue
old cotton glue breaks down and the thread separates easilty
next check that the needle is installed correctly with the grove ( thread groove away from the bobbin hook
check the needle and hook timing because if it is off a fraction , the hook will pierce the the thread causing it to break
next check that the eye is the correct size for the thread in use
a needle eye too small for the thread thickness will jam the thread ans not let slide through the eye properly
Nov 25, 2017 | Sewing Machines
Why does my thread keep breaking on my brother ce4000?
Change the thread in the bobbin and then try...then change the top thread only and try...helps to see where the problem could be...change the needle again and get it from a different pack. Sometimes needles from the same pack can have the same problem( burrs, nicks, filings, etc...) that are impossible to see with the ***** eye. Oh and buy brand new thread...we tend to think that all thread is good to use and it is NOT. Old thread looses elasticity, frays, and breaks constantly. It may 'look' good, but is a sewists greatest enemy!! Good luck!
Jan 26, 2017 | Brother CE4000 Computerized Sewing Machine
How can I get the monogram to work properly?
On my sewing machine that would be an indicator of misadjusted thread tension. Changing thread type or diameter generally requires tension adjustment. In this particular case, I\'d increase the bobbin tension a bit (if I understand your description correctly, the bobbin thread forms loose hoops), and back off on the upper (spool) tension (pulls too hard on the thread). On one or two of my bobbin cases, I had problems with the tensioner screw working loose during use. I put a dab of nail polish on the screw head to stick it to the bobbin case. Problem solved.
I\'m not familiar with your particular machine, but I don\'t see why you can\'t make the character any size above the minimum (which would be the smallest readable character that can be made with the stitch length and type used).
Apr 24, 2014 | Kenmore Elite Clothsetter 19010
Embroidery not working correctly
Well, before I did all that (which may be necessary), I would take a piece of UNWAXED dental floss or hand embroidery floss and floss between the tension disks. You mentioned that you were suddenly breaking threads; there may be lint or loose threads or both seated between the disks, preventing the thread from seating properly. Then,
I would take the embroidery unit off and try to do some sewing with it, to see what results I got. If you can catch and bring the bobbin thread to the top with the top thread, I am doubtful that your timing is off. Sew a line of both straight stitch and zigzag stitches, and see if the stitches are balanced. If not, you may have a bobbin tension issue, and if so, most bobbin cases can be adjusted.
I think you'll find, though, that things will improve considerably when you have cleaned out the upper thread path and tension disks. Make sure when you do that, that your foot is raised, so that the disks are spread. Oh, a drop of sewing machine oil wouldn't hurt either--generally you should put a drop of oil for every 5 hours of embroidery.
Please get back to us to let us know!
Mar 14, 2014 | Singer Quantum XL-6000 Computerized Sewing...
Top thread keeps breaking. Adjusting the tension does absolutely nothing. It seems as though the thread is getting caught on something inside the machine between the thread guide and thread take-up lever....
these are suggestion, if they don't help then the machine needs to be checked at a sewing machine shop
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Sep 27, 2013 | Euro-Pro Sewing Machines
How do I fix top tread breakage on a white model 935
Jul 27, 2013 | Sewing Machines
Loower looper keeps braking.
Sergers are... well can be a pain. "Lower looper thread keeps breaking." Ok... so Here is what I Would do. Get your magnifying glass out and really get in close with a good light and look for burrs on the looper. Also look for burrs on the throat plate, etc. If you find one use some very fine sand paper and carefully smooth it off.
If that doesn't help or fix it. Take it in to a repair shop and tell them what's going on. you might need it timed too. Good luck
Dec 20, 2012 | Brother 1034D Mechanical Sewing Machine
Mb4 false thread break
found the problem and unfortunately it is not something that i can fix and will have to take it to the repair shop on monday. The thread spring for that needle is broken and flopping around a little bit more than it should. From what i have been able to find on the web the up and down motion of the thread spring is used to sense if the thread is actually being pulled through the machine. this is how it detects if either the top thread or bobbin thread is broken. top thread not advancing and pulling the thread so that the thread spring goes up and down indicates one of the two is busted. Had a lot of responses to this on another forum with one person even sending pictures of what to look for and apparently this is a very common problem if the thread is not properly put through the eyelet of the thread spring and gets caught in the wire wrap of the thread spring. It just pulls it and breaks it. getting old and the eye sight is fading so just bought a lighted magnifying glass lamp to stop me from hurting my sweet little machine. So if you have one needle that is constantly giving you a false thread break indication this is where to look
thanks everybody for the rest of your suggestions. they were greatly appreciated
Jun 02, 2012 | Janome Sewing Machines
Brother XL-5340 sewing machine
Try a new needle, making sure it is put in properly. A bent needle can break thread. Make sure top tension is set properly.
Dec 01, 2007 | Brother XL-5340 Mechanical Sewing Machine
Singer CE350 Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
