I need the code for a GE universal remote control for a Toshiba TV?
AvioriX
  • 689 Answers
SOURCE: GE Universal (JASRM24912) Remote Control
Hi
Here is the link for all Codes
http://www.remotecodelist.com/remotes/ge/RM24912_codes.pdf
and the Manual for instructions
http://www.remotecodelist.com/remotes/ge/RM24912_instructions.pdf
Good Luck
Posted on Jan 18, 2008
IrishDruid
  • 2712 Answers
SOURCE: Ge remote control #24921
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
the q guy
  • 393 Answers
SOURCE: NEED CODE FOR SETTING GE UNIVERSAL REMOTE FOR SONY TV
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
Posted on May 11, 2009
  • 74 Answers
SOURCE: I need Philips CL035A codes list for toshiba tv
I believe this is your remote. it's listed as pm435s
http://www.p4c.philips.com/files/u/us2-pm435s/us2-pm435s_dfu_eng.pdf
these are the codes for toshiba 0517, 0419, 0512, 0613, 0719, 0112, 0506, 0111, 0618, 0627, 0437, 0041, 0094, 0802, 0111, 0313, 0715
Posted on Sep 17, 2009
SOURCE: i need remote control codes for my GE universal
Need Code for GE RC24991-B Remote Control
Posted on Jan 13, 2010
How do I program a GE universal remote RC 94904-B 1129 to a Toshiba TV?
Your GE universal remote should have a "code search" capability you can use to find a suitable code. Codes are stored in the remote. If a thorough search produces no result, you may have to try another universal remote. Not all remotes contain the same codes.
Sep 19, 2014 | Televison & Video
Toshiba 32a14
  • The GE remote control is not identified as universal
  • The GE remote control may not contain a code applicable to your Toshiba TV.
All universal remote controls do not contain all possible codes.
Jan 16, 2018 | Televison & Video
I have a GE universal remote RC24993-C and I need the code to program a Sanyo tv
necesito el codigo del control universal ge rc24993 para una tele tohiba
Aug 28, 2011 | GE 24993 Remote Control
I have a ge universal remote and have a toshiba tv dont know codes and how to programe it could you please help?
Which GE universal remote do you have? Does the remote use a 3-digit or a 4-digit code? To program most GE remotes for a TV, turn on the TV. Then press and hold the Code Search or Setup button until the indicator light comes on. Then press and release the TV button. Enter the first code available for your device. The indicator light should go off then check if the remote controls the functions of the TV. Repeat the above steps if the code doesn't work or doesn't control all the features of your TV.
The manuals and code lists for GE remotes are here: http://www.jascoproducts.com/support/universal-remote-codes.asp .
Toshiba 4-digit TV codes are: 0159 0178 0109 0120 0181
.............0105 0049 0095 0170 0260 0358
.............0394 0924 0012 0095 0117 0141
The 3-digit codes are 170, 181 or 641 for Toshiba HDTVs.
Please note that the remote probably only has codes for devices that were released 6 months or more before the remote was programmed. If your TV is newer than your GE universal remote, you may need a newer remote.
I hope this helps.
Jul 06, 2011 | RCA Televison & Video
I have a GE universal r emote control. I need the codes to control a 2006 Toshiba TV.
Hello;
According to the site located at http://www.eliztech.com/remotes/ge-4digit-codes.php , GE Universal Remotes operate on 3 and 4-digit codes. Furthermore, the 3-digit codes are sub-categorized as "old" and "new". So depending on how you classify your tv and whether your remote uses 3 or 4-digit codes, the codes for a Toshiba TV are:
3-digit (old) 049, 071, 072, 089, 105, 109, 117, 118, 160, 162
3-digit (new) 012, 013, 049, 089, 095, 105, 109, 117, 118, 120, 141, 159, 170, 178, 181, 260, 358, 394, 902
4-digit 0159, 0178, 0109, 0120, 0181, 0105, 0049, 0095, 0170, 0260, 0358, 0394, 0924, 0012, 0095, 0117, 0141
Hope these are the right codes.
Mar 19, 2011 | GE RM24911 Remote Control
Need the cods for a GE 24944 universal remote. For a Samsung TV?
It uses 4 digit codes try
SAMSUNG ..........0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
One of these should work for you. Thanks.
Jan 02, 2011 | Universal Remote Control GE174Universal...
We have a ge Universal remote that we are needing to use for a toshiba 19" flatscreen tv. We need the codes and instructions to program the tv we have it set up in our kids' room to hook up my sons xbox...
You can use code search to find something that works. If a search through all codes stored in the remote control fails, you may have to try a different universal remote control (such as RCA or Philips). All universal remote controls do not contain all possible codes.
Jun 20, 2017 | GE RM24911 Remote Control
Need codes for philips universal remote on a toshiba TV
i don,t know the code to this remote it is a ge universal remote
Jan 06, 2009 | Philips Universal PH301S Remote Control
Remote codes
how do i progrmm my remote control??
Jan 31, 2008 | GE JASRM24912 Remote Control
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
