Hi, I have an ibm t40. The problem I have is that it freezes upon startup, the screen sometimes goes blank (if I move it, it comes in and out) and will even freeze in safe mode. The laptop even has problems starting after maybe ten manual tries (it starts up just with no picture) It usually freezes once the windows xp picture comes up. Any help is appreciated.....please keep in mind I am not too computer savvy Thanks again.
  • 358 Answers
This is likely to be as a result of your processor over-heating, maybe because of your environment, or because the fan is not cooling the processor properly again.
Therefore my suggestion would be for you to unscrew your laptop (If you can do it by yourself), and try to clean, or better still replace your processor fan.
Also clean the air-vent where air is supposed to enter the laptop.
If you cant do it by yourself, you can easily get a technician to do it for you.
Also, remove all your RAM(Memory Sticks), and clean the tip of the connector with an eraser, and re-insert it one after the other.
That is, if you have two of them, after you insert the first one, put on your system and see if it works, then do the same thing with the other one.
If the two of them works, them insert the them all. but if it is just one that worked, just remove the other one that is not working and replace it.
I have actually had the same case before, and after doing what I've just told you, it stopped behaving like that.
Then always make sure that your laptop is in a well ventilated, cool environment and that the environment is free from dusts.
Kindly let me known how it goes after you've tried this.
Hope this helps you out.
Posted on Jul 29, 2010
After changing out fan IBM think pad t40 screen goes black after windows xp screen finishes losding up
Wait Black Screen? AFTER you changed the fan... hmmm... I think I know what the problem is. Okay solution one; You might of hit a wire or cord in the computer when you changed out the fan. Two: You might have the virus 223, get it fixed and it should be going again! Hoped this helped! :D
Mar 25, 2013 | IBM ThinkPad T40 2373 Notebook
My ibm type 2372 t40 keeps freezing on startup also how do i make the dvd drive into a portable external dvd drive
is your hard drive ticking or making any nois if so replace hard drive, normaly you can't but you can buy one at staple for around 60 buck's,back too freezing if no nois try reprograming probly have a bad virus,plus check internal battery...
Apr 15, 2011 | IBM ThinkPad T40 2373 Notebook
I have an IBM thinkpad T40 when I turned on the laptop the image doesn't appear and that times it would but then after a few seconds or minute the screen blanks out and won't appear again and sometimes...
There is no problem in your motherboard. In your motherboard, clean your ram and also where ram is put. Then restart your system again it will work. When it will not work please change your ram. Then it will work.
Nov 07, 2010 | IBM Thinkpad T40 Thinkpad T41 Thinkpad T42...
Thinkpad 42 on startup screen is in a red pigment then goes to the blue welcome screen then goes completely black. On occasion may see my desktop for a moment.
This sounds like a display card (graphics card ) driver issue, or else the screen is going bad..
test that out by hooking up an external screen to the port on your laptop.. Then toggle using your function keys to use the external display..
If the external display allows you to see your desktop..
reload your graphics card driver, then boot up normally..
if the screen still doesnt work, you may need to replace it
Oct 30, 2009 | IBM ThinkPad T40 2373 Notebook
My name is Luis and my Ibm thinkpad r40 keeps freezing and my screen goes black.
Hi, could be simply your computer is going into sleep mode and not waking back up. try changing your screen saver option to not hibernate or sleep.
Aug 18, 2009 | IBM ThinkPad T40 2373 Notebook
Blank screen and unresponsive hard drive nothing on external monitor either
did u manage to enter your bios?if not, then i suspect your ram has a problem..normally notebooks are equipped with two modem...try to use one of them only....also, try to change the position(means slot A is for RAM A and slot B is for RAM B- try to place RAM A to slot B first n test your notebook)
hope it will help ; )
May 27, 2009 | IBM ThinkPad T40 2373 Notebook
Ibm t40
Yap actually i greet you first
what your system is prompting you is that your Processor is getting Bad and you will need to replace it with a new ones ok
After that your system come back to life .
thanks
Rate this solution
Oct 20, 2008 | IBM ThinkPad T40 2373 Notebook
IBM T40 Screen goes off after few seconds
survival,
Here's a couple of things to try:
Power down and remove the battery. Leave it out until you are done with the following procedures. Remove the memory modules and put only one back in. Try to power up. If that works, replace the other one and power up. If that works, you're fixed!
If not, try to power up in safe mode and see what happens. If it comes up, try running diagnostics on the HDD. If that fails, try reseating the hard drive.
Let me know how you're coming along on this. May be able to come up with more ideas, if needed.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Ron-
Nov 26, 2007 | Computers & Internet
Ibm thinkpad t40
http://en.wikipedia.org/wiki/Blue_Screen_of_Death
http://support.microsoft.com/kb/174630
THe most popular windows issue in all the land.
Oct 24, 2007 | IBM ThinkPad T40 2373 Notebook
Computers & Internet Logo
Alun Cox
David Payne
David Payne
