Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Need code info
What does code 91 mean for intex salt chlorinator?
  • 297 Answers
Code 91 is low salt
do not just guess at it! even the recommended amount in the manual is just that, a starting point
It is up to you to fine tune it
Get a salt test kit that reads in #'s not color
Now get your pool to as close to 3000ppm as possible
under 2700 will cause the system to not produce enough chlorine
any higher than 3500ppm and you can go cloudy, trigger high salt alarm, and even taste terrible
Here is a link to manuals so you can see all other codes
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?source=intexstore
Posted on Jul 29, 2010
Low salt
The salt chlorinator cell should be cleaned with a proper cell cleaning fluid. Your pool surface may coat the salt cell with calcium and unless this has been removed it will not generate chlorine efficiently no matter how much salt you add to the pool water.
When the salt cell has been cleaned properly then the amount of salt in your pool may exceed then recommended concentration and it will overload the power supply to the salt cell and the salt concentration will need to be reduced.
Mar 30, 2012 | Intex Pool & Spa
Hi i have a 18 x 48 above ground intex frame pool with a salt water pump /chlorinator system. i have put the required amount of salt in 75 kg and it has fully desolved. the alarm keep coming up on the pump...
the amount of salt that they reccomend in the book is just a starting point
You need to get a salt test kit that reads in #'s not colors
Get your pool to as close to 3000ppm as possible
lower than 2800ppm and you will not produce enough chlorine
any higher than 3500ppm and you can trigger high salt alarm, have bad tasting water, or even get cloudy water
Like you have done, when adding salt , filter only for 6 hours or so to fully disolve
Jul 18, 2010 | Intex Automatic Salt Water System for ...
Intex salt water chlorinator 56602
First of all 91 is low salt content not too much
Are you checking your salt level with a test strip
You need to be at 3000ppm anything under 2800ppm can trigger an alarm and not produce enough chlorine.
Same thing if you are over 3600ppm
all manuals just give you an amount to start with but it is up to you to fine tune it
After adjustments you need to filter only for 24 hours before trying to generate chlorine
Jun 26, 2010 | Intex Automatic Salt Water System for ...
I have a Intex Pool that is 18 ft by 52 in. I have a Salt water chlorinator unit and I am tryiong to start up my pool. I added 80 kg of salt which is the recommended amount for my pool and then I ran my...
I have a krystal Clear deluxe Satlwater system recently the water went green(lots of rain) I added more salt and have run the pump extra time. It is better but not back to normal. Do I have to shock it and how do I do that? What and how much do I put in for an soft set pool 18 x 48.
thank you
Jun 17, 2010 | Intex Automatic Salt Water System for ...
My intex saltwater system pump is beeping ''91'' meaning ''low salt level''. Do I need to just add salt again?
Yes, and be sure to keep up with your pH as it will want to rise slowly over time when using a salt water chlorine generator.
Dec 06, 2009 | Intex Automatic Salt Water System for ...
Salt water system not working , alarm code 91 appeared and then the system shut off . after more salt was added (20 kg) and the electrolytic cell housing was removed and cleaned the system still isn't...
if this pump is less than 90 days old, call intex they will replace it immediately without you having to send in the old one in the mean time get a salt tester kit and get your ppm to 3000ppm nothing else and dont take no for an answer :-) this is a great ppm to be at and adjust your chlorine and ph to that
Jun 29, 2009 | Intex 2000 GPH Salt Water Filtration Pump...
My intex saltwater chlorine generator & filter beeping forever!!!
hello our pool chlorinator keeps comming up low salt 91 no matter how much salt we put in this is frustrating why is this happening ,,,please help
Jun 06, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
572 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
