Question about Sony RDR-VX530 DVD Recorder/VCR
My Sony RDR-VX350 will not play or eject a VHS tape. I took the cover off and it appears that a gear is broken. Wher can I get a replacement gear.
  • wjstone Aug 03, 2010
    Thanks for the information
  • 10,594 Answers
Please recheck model number as it could be RDR-VX530 because RDR-VX350 seems incomplete/ incorrect model number.
Let me know exact model number to provide you info.
Thanks.
Posted on Jul 28, 2010
  • 5 more comments
  • wjstone Jul 28, 2010
    You are correct. it is a Sony RDRVC530.
    Let me try it one more time. It is a Sony RDR-VX530
  • Shahid Electronics
    Shahid Electronics Jul 28, 2010
    Thanks for model number correction.
    Get back to you shortly after finding parts, wait my next post.
    Hi again,
    I need to know what gear you see is broken. Below are two exploded views of VHS Mechanism in your combo player, let me know number of gear marked in images to find out its part number and availability.
    Image-1 is posted again for better view.
  • wjstone Jul 29, 2010
    Unfortunitely the gear that is broken is not numbered in your diagrams. In the top diagram there is a small moter on the top right that has a worm gear that drives the broken gear that then drives a bigger gear. On closer examintation it looks like the two gears cannot be replaced because they look like they are rivited in place. Is this planned obsolesence? No wonder Sony want $140.00 to repair this! Do you have any suggestions?
    Shahid Electronics Jul 29, 2010
    Alright, whatever gear is damaged, complete VHS mechanism will be replaced in unit and part number is as follows:
    988510119........ ASSY DECK
    You need to put Video Head Assembly from broken mechanism to new one.
    Individual parts of mechanism are not available.
    Thanks.
How can I get my tape to eject?Sharp VC-A560. Played my taped, rewound, but tape would not eject. Tried to play again and it would not play.What can I do?
Unplug from wall outlet - find the wheel that ejects the tape when you slowly turn it. It's usually on the right side when the cover is open. Avoid touching any metal parts.
Mar 01, 2015 | Sharp VC-A560U VHS VCR
Stuck video tape
Is the tape protection guard rotated upward (and the tape engaged with the heads)?
Aug 13, 2008 | Emerson EWV403 VHS VCR
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
Why is my vhs tape immediately ejected from my Sony DVD/VHS machine, tapes will not stay in long enough to record or playback.
mechanical problem usually in rubber belt types it has to replace new belts for it was already worn...
Dec 31, 2009 | Sony RDR-VX521 DVD Recorder/VCR
I cannot play a VHS tape - it just ejects
Hi there, try to run a VHS cleaner first and try it again..If not
Jul 15, 2009 | Sony RDR-VX525 DVD Recorder/VCR
Panasonic 7350 VCR Keep ejecting tapes just seconds after loading
This happens when he strings are worn out or broken. It will not hurt to replace the strings of the VCR after some while.
Jan 29, 2009 | Panasonic AG-7350 VHS/S-VHS playback VCR
Vcr jams on eject
What do you mean 'Tape crunches" Do you mean that there is tape slack, which then crunches when Tape is lifted during Eject? If that is the case, then the Supply Reel Roller Brake is bad. it is a Felt Pad, which needs replacing. If the entire eject operation is wonky, or if it's timing is bad, then I suspect that One of the eject Gears (On either side of the Mechanism) is damaged and needs to be replaced. One question, i assume that you are able to eject the Tape eventually, and so - Does the Tape Load into the VCR properly, when you insert it into the machine? This will help me in giving you a better diagnosis.
Mar 13, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
Sony RDR-VX530 DVD Recorder/VCR Logo
482 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
