Question about Goodman CKL36AR36 Air Conditioner
Everything works the inside and the outside fan runs there is gas in the compressor but hot blows
  • 139 Answers
Check the capacitor .turn off breaker first take off the panel on the condensor to see parts .capacitor is silver. round or oval .that is your problem most likley. that helps the fan an compressor start .or could need a hard start capacitor that will hook up to the one capacitor on the unit that will fix it ...unless their is a burnt or broken wire ..look at the wires too good luck
Posted on Aug 23, 2010
Unit stopped cooling, inside unit runs, outside unit does not
could be a gas leak ( low gas pressure shut off switch, failed start run capacitor for the compressor , vermin problem shorting out the power board outside
The inside unit is just a fan
call an accredited ac technician to get a proper diagnosis and quote
Aug 06, 2016 | Heating & Cooling
My air conditioner is not blowing cold air in the house
because the fan inside the house is working doesn't mean that the compressor outside is working
It may be a faulty start /run capacitor for the outside unit ,out of gas or failed power board
I suggest that you get an accredited technician to come and give you a proper diagnosis of the fault.
Jul 17, 2015 | Heating & Cooling
My lg gm-313sc keep on work and stop in lest than 3 minits
The refrigeration is short cycling. The cause may be due to airflow problem. There is an outside fan thalt blows across a radiator and another in the inside the fridge enclosed behind panels.
These two fans must run and blow across the refrigeration radiators. The outside one can clog with lint and dirt, the inside one can clog with ice buid up, or the fans simply quit working. Check that the fans run and that the radiator coils are clean and clear to airflow. For the outside one, paneling will need to be removed, as well for the inside one if the outside one does not do the trick.
The refrigerator compressor short cycles because it overheats. The cool refrigeration gas entering the compressor cools it and when the gas is not kept cool, the compressor may short cycle.
There may be a different problem but checking for airflow is a start.
Jan 06, 2015 | LG Refrigerators
Working but not cooling
Check and make sure its on cooling mode and just not "fan only"
You should be able to hear the compressor start up a few seconds after the fan starts. One easy way to tell if an AC is working on cooling is it should be blowing hot air outside and cold air inside. If not, you may have a gas leak or the compressor is not starting..
Jul 14, 2011 | LG Electronic Window Air Conditioner
My air conditioner is blowing hot air. The outside fan in not wo
sounds like a contactor problem. this is the switch that kicks the outside fan amd compressor on. If the inside fan runs it will be on the outside.
Jul 08, 2010 | Whirlwind FH-778 Air Conditioner
The outside ridge between the freezer and cooler
I would guess that the condenser fan isn't running. It's underneath the fridge behind the cardboard cover on the back. It should be running when the compressor runs. You can place your own fan on the floor blowing under the fridge till you get it fixed.
Jan 17, 2010 | KitchenAid (KSRD22FKST) Side by Side...
I have a Intertherm heat Pump. Everything turns on inside the house. Blows warm air and the outside Fan wont turn on. Both the outside copper pipes are same temp, neither hot nor cold. Don't know the modle...
If the fan outside doesn't work the compresor will overheat and shut off by the thermal protection inside the compressor , to fixed this you have to replace the fan motor and its capacitor.
Aug 26, 2009 | Heating & Cooling
Blowing hot air, compressor not kicking on, just fan ? ?
are you speaking of the outside fan or inside? compressor should be a little warm but not boiling hot. the unit could be low on freon. if low it will run a while but the compressor will overheat and shut off leaving the fan running by itself ouside. if nothing outside is running check power. if you have power check the contacted outside to make sure it's pulled in. contacters are bad about going out on goodman untis. Also ants can get under contacts.
Jun 11, 2009 | Goodman CKL60AR60 Air Conditioner
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
Goodman CKL36AR36 Air Conditioner Logo
52 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
