Question about Sewing Machines
I have a problem with a juki 5550n-7 the panel cp 160 shows a key buet I don´t know where to remove that key the whole machine turns on just fine but it does nothing just shows every thing but it does nothing it seems as it is locked then I would like to know how to unlock it... my mail addres is dasanluzcruz420@yahoo.com
    Scholar:
  • Sewing Machines Expert
  • 176 Answers
Hi there
to unlock key on panel cp-160 please turn off machine and press start bartack button and first + button together and push power on. machine unlock
best regards
ashraf abozid
aabozd@hotmail.com
Posted on Aug 19, 2010
Automatic thread cutter is not working. Juki cp-160
I am confused as to why one place on this says Juki cp-160 and one says DDL-8500-7
If it is the DDL, my most common problem with my knives that cut the threads have become jammed after I either broke a needle or had a thread 'nest' underneath from something I did wrong, like not getting my bobbin case in good before I started to sew.
1. Remove your throat plate (the silver or black plate that covers your feed dog teeth, may sometimes have lines on it to allow you to measure your seam allowance as you sew) that is held on with two screws.
2. Use a bright light to look into your machine under the plate and see if you see broken needle parts or a thread nest. If so, remove them with tweezers or a small pair of needle nose pliers. If you solved the problem, you will hear a small click as the blades return to their proper places.
...Then you can simply reinstall your cover plate and begin sewing.
If the above didn't work:
Your cutting system is made up of two pieces. A moving knife that looks like a tiny silver bird the size of a dime and a stationary knife that looks like the letter L backwards. If either is broken, you should have a repairman fix it. If you have had your machine and sewed alot you may also just have dull knives but I would imagine that they are either jammed or broken.
Good Luck.
Feb 09, 2018 | Juki Sewing Machines
Why does my Juki DDL-5550N-7 sewing machine become hard to control after 15 mins of use? It gets difficult to depart and stop and becomes uncontrollably fast.
indicates a problem motor or motor control problem due to heat from current (power) usage
take it in for a service and proper diagnosis
Dec 14, 2016 | Juki Sewing Machines
DDL-5550N control panel
Yes, your machine has one. Contact your Juki dealer for help and a replacement.
Sep 02, 2012 | Juki Sewing Machines
Problem with Juki DDL-5550N-7 Sewing Machine, Error Code E24
El Drv se refiere a la tarjeta interna que controla el motor, est? se encuentra da?ada.
Email: ingcegadan@gmail.com
May 11, 2012 | Juki Sewing Machines
How long before changing oil for a Juki DDL5550N-7?
just add oil and clean junk off take up pump filter. no need to change oil there no combustion like a gas engine.
Feb 26, 2012 | Juki Sewing Machines
Where does the oil go in my Juki DDL-5550n-7 sewing machine? I lost the manual and I don't want to buy a new one just for this one thing. Thanks.
hi there
here's the type of oil u need for juki lockstitch machine
( juki Defrix oil No.1 ) you cand found in your local market if NO u can buy light oil white color for industerial sewing machine
best regards
ashraf abozid
Aug 17, 2010 | Juki MO-644D Mechanical Sewing Machine
Sewing Machines Logo
246 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
