Question about Philips AJ100 Clock Radio
Radio phillips aj100 stuck on am band cant get it to switch over to fm frequency.
    Problem Solver:
  • 7 Answers
Press RESET under the radio a few seconds. Adjust clock, alarm and radio again. AM gone, FM back on the air...
Posted on Aug 24, 2010
  • plopes997 Nov 02, 2010
    ON THE BUTTON THAT SAYS "RADIO ON/OFF" PRESS MOMENTARILY ON THE LEFT SIDE RIGHT TO THE EDGE WILL SWITCH TO FM, YOU MAY HAVE TO DO IT SEVERAL TIMES
How do i tune Mazda Demio (2004 model) radio to Southern African frequencies?
fm frequencies are just that fm frequencies ( not japanese, chinese ,english or anything else
it is a range of frequencies in the fm band that local stations broadcast on
so all you have to do is to turn the tuner knob until you get 107 fm
so as you turn the knob you will loose 89 and it will go probably 90.5 , 100.20, 102.7 etc and if there is a station broadcasting that your radio will pick up it will come in and then fade out as you keep moving the knob
you may have to change the mode as there are fm 1 ,fm 2,fm 3 bands to get your fm 107 as it will depend on what megahertz 107 is operating on
Oct 05, 2015 | Mazda Cars & Trucks
FM frequecy increases/decreases too mugh pr. step
Hi, Your post/description "the frequency increases in steps of .2 Mhz or 200Khz" refers to the increment of frequency spacing between tuning steps and is largely dependent on the radio standards of the country/region the radio is intended to be used. Assuming no hardware fault to the radio, tuning steps may be adjusted by: 1. With the radio switched off, press the Step/Band button for about 2 seconds. This will display the current FM tuning step (200Khz as in your case); 2. With the radio switched off, press the Step/Band button for about 10 seconds. This will display FM and a blinking 50Khz with a single beep sound. By rotating the Tuning Control you can increase or decrease this value. 3. pressing the Step/Band button again will move you to the tuning increments of the AM band again adjustable via the Tuning Control. 4. pressing the Step/Band button again will save the setting and complete the process. Hope this be of some help. Good luck and kind regards.
Sep 13, 2007 | Makita BMR100 Radio
I have an Eton G3 recently purchased which has an operators manual, but does not contain any references to the layout of the buttons etc. I would like a link to find out the correct use of the radio
The buttons are marked and the use of most of them is self-evident.
The number keys are used to enter frequencies (direct tuning).
Lock locks the radio and prevent changes (trurning ON or OFF, changing frequency, any function change is blocked)
Sleep sets a timer.
+, - go up or down in frequency, or when you are setting time.
U/LSB is for toggling Upper or Lower Side Bands.
Auto Up and Auto Down are for the automatic tuning system (scanning the frequency spectrum)
AM is for switching to the AM (medium wave band)
AM/Meter band is for switching to the Short wave bands, and FM is for Frequency modulation band.
VOL + and - increase and decrease volume levels
Page/time: It has 700 memory locations to store frequencies. These are organized in pages (maybe up to 100 pages). You jump to next page with that button. Used also when setting time . Please read the instructions.
F1 to F7 are used to select the day for the alarm. F1 for Day 1, Sunday, F2 for Monday, etc) You can set an alarm for each day of the week.
Reset to reset configuration
TZ/Line in TZ set time zone, Line In if you wan to use the speaker of the radio as the output device for a signal from some other radio, or MP3 player
The tuning knob may also be used to change the displayed value while setting time (I can't remember exactly. You have the manual)
Erase erasing a stored frequency or a page (Check that)
Copy see above.
Nov 04, 2013 | Grundig eTraveller VII AM/FM/SW Radio
How can I get my midland 9001z from AM to FM
Hi Trevor,
The Midland radio you have is NOT capable of FM transmit & receive. It is a Citizen's Band radio that operates on channels 1 thru 40 that are assigned to the 26.965-27.405 MHz frequency range. These are the standard 40 Ch CB frequencies in the U.S. (and may not be legal for use in other parts of the world without a license from your country's communications authorities). It also offers Weather Band reception - again these are US frequencies that may or may not even be used at all in the UK. Since the radio only displays a channel number, you don't actually know the frequency you're monitoring or transmitting on. Your friends on CH 5 may be in a completely different band.
Even if they are on the same frequency, the fact that they are operating in FM mode means that you would hear something - but it may not be intelligible - and the same would be for them listening to you transmit in AM mode. If you could have them switch their radio to AM, all would be fine. I suspect they use FM as there is much less static when compared to AM.
If they won't change to FM, you'll either have to stop trying to talk to them or buy a radio capable of FM (and make sure it has the same frequencies as theirs!).
Feb 08, 2013 | MIDLAND-2 WAY RADIOS New - Midland 9001z...
Fix my connex 3400 hb sideband button
Hi there, if you are talking about the Connex CX 3400 HP there is no sideband or SSB on this radio. It is only AM and FM 10 meter Ham radio. Many people do modify these radios to include the 11 meter frequencies which is the CB band. Maybe knowing the actual bands and their frequencies will help some too this radio does have 6 different bands ranging from (Band A. 28.015 thru 28.455) (Band B. 28.145 thru 28.585) (Band C. 28.115 thru 28.555) (Band D. 28.085 thru 28.525) (Band E. 28.055 thru 28.495) (Band F. 28.025 thru 28.465.) I hope this will help you. Bob
May 13, 2012 | Connex CX-3400hp AM/FM 10 Meter Amateur...
Ihave a gargeled recive sound
Check the position of the mode selector switch. You may be receiving a SSB (single side band) transmission that is not on the exact same frequency as you or, your radio is in AM or FM mode. You will need to select either USB or LSB (upper or lower side band) and vary the clarifier knob until the sound becomes intelligible. If the sound does not become clear, try the other side band and repeat varying the clarifier knob.
Conversely, if you are in USB or LSB mode and there is a transmission on AM or FM, it will have the same garbled sound. Try changing the mode to AM and the FM. If it does not become clear, it is likely a SSB transmission and you are not on the exact same frequency of the transmission you are hearing. Vary the clarifier knob until it becomes clear - or change to the other side band if needed and try the clairfier again.
The short story is that you must be in the same mode and on the same exact frequency. When in AM or FM, this is less of a problem as these are much more wide banded signals than SSB signals.
The 2990 is really a 50 watt 10 meter amateur radio - but is geared to CBer's as it is easily modified to work in the CB frequency range and the so called "free band" between USA's CB (11 meters) and worldwide amateur 10 meter bands. Be careful transmitting this radio on CB frequencies as it violates FCC rules for power output there - and transmitting in the 28MHz - 29.7MHz requires a valid amateur radio license. Fifty watts on ham frequencies is tiny compared to the 1500 watts permitted. Why not get your ham license (here's how) and leave the "Chicken Band" (and all it entails) behind. You won't miss it!
I hope this helps and good luck!
Apr 12, 2012 | Cobra Radio Communications
How do i change the AM radio to FM?
Hello
Press RADIO BAND.AUTO PRESET until the band you want appears in the display (direct power on). Each time you press this button, the indication changes as "FM" --> "AM". Hold down TUNE + or --, until the frequency digit begins to change in the display. The player automatically scans the radio frequencies and stops when it finds a clear station. If you can't tuned in a station, press the button repeatedly to change the frequency step by step. If FM broadcast is noisy, press "MODE" until "Mono" appears on the display and the radio will play in monatural without any noise. Only strong FM signals can be decoded to stereo. OK.
Oct 22, 2011 | Sony CFD-S300 Radio/Cassette/CD Boombox
How do I preset the tuner for radio stations. I've never had a problem doing this with any other stereo. But what I think should work isn't!
Not very specific. Do you have the manual?
The following is from a VSX-03TXH manual. It ain't pretty but it may help.
I'm posting it in multiple parts due to space contraints.
37
Chapter 6:
Using the tuner
Listening to the radio
The following steps show you how to tune in to FM and
AM radio broadcasts using the automatic (search) and
manual (step) tuning functions. If you already know the
frequency of the station you want, see Tuning directly to a
station below. Once you are tuned to a station you can
memorize the frequency for recall later-see Saving
station presets below for more on how to do this.
1 Press the FM/AM button to select the tuner.
2 Use the FM/AM button to change the band (FM or
AM), if necessary.
Each press switches the band between FM and AM.
3 Tune to a station.
There are three ways to do this:
Automatic tuning
To search for stations in the currently selected band,
press and hold TUNE ?©/?? for about a second. The
receiver will start searching for the next station,
stopping when it has found one. Repeat to search for
other stations.
Manual tuning
To change the frequency one step at a time, press
TUNE ?©/??.
High speed tuning
Press and hold TUNE ?©/?? for high speed tuning.
Release the button at the frequency you want.
Improving FM stereo sound
If the TUNED or STEREO indicators don't light when
tuning to an FM station because the signal is weak, press
the MPX button to switch the receiver into mono
reception mode. This should improve the sound quality
and allow you to enjoy the broadcast.
Using Neural THX
This feature uses Neural Surround™, THX® technology to
achieve optimal surround sound from FM radio.
• While listening to FM radio, press AUTO/DIRECT for
Neural THX listening.
Dec 23, 2010 | Pioneer VSX-07TX Receiver
Realistic pro 2020 scanner
The Realistic PRO-2052 is an old (vintage) scanner receiver with fixed AM and FM modes on the bands it cover, as specified by the U.S. band allocation. The PRO-2020 covers only the VHF and UHF frequencies and modes AM and FM is not user selectable. Frequencies can be programmed into any of the 20 memory channels
U.S. Coverage: (varies from state to state and other countries. We don't use 30-50 Mhz here in the Philippines for 2 way mobile communications, except for cordless phones)
30-50 Mhz Lower VHF at FM narrowband only (covers mobile, emergencies, businesses, etc. and
cordless phones)
108-136 Mhz Aircraft band at AM narrowband only
138-174 Mhz Amateur and Commercial band at FM narrowband only (2 meter band)
410-512 MHz Amateur and Commercial band at FM narrowband only (70 cm band)
If you're trying to select AM or FM for a specified frequency, I'm afraid you can't do that as it is not selectable.
If you are trying to program AM Broadcast frequencies (mediumwave (MW) or FM Broadcast frequencies (FM radio stations), those were not covered by your PRO-2020's microprocessor. Even if you modify your scanner to receive those bands, you will not hear radio transmission properly since the receiver do not decode FM wideband, which is the standard mode for FM broadcast and Television band.
MANNY DE GUZMAN, JR.
SoundMagik Home Studio
Manila, Philippines
Visit my website at http://mannydeguzmanartist.wetpaint.com
My talents and modeling site at http://teenmodels2007.wetpaint.com
Jul 02, 2008 | Radio Shack Pro-2052 Scanner
Switching radio bands
what radio do you have? does it even have sideband channels? some radios don't come with them, of fm or upper or lower side bands and short wave
Dec 08, 2007 | Connex 3300 240-Channels Base CB Radio
Philips AJ100 Clock Radio Logo
1,998 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
