Question about Safety 1st Alpha Omega Elite 22456 TTN Convertible Car Seat
How do you remove the seat from the base in order to remove the seat cover for cleaning.
  • 8,197 Answers
MAy I get the model # and the manufacture date of the product to help you more. Or you can get the manual on the link below.
http://www.safety1st.com/usa/eng/Instructions?ProductNumber=22456CAO
Good Luck
Posted on Jul 29, 2010
  • lonthera Aug 01, 2010
    Hi There!
    I understood that this subscription was cancelled and no charges made so please clarify that for me. As to the part number you reference, it is different from that which I submitted so I'm hesitant to download that particular manual.
    The part # I have is 22410C-HDK and the manufacture date is 01/27/2010 on this particular seat. Since my kids are only here for another week I was just hoping to help resolve the problem of removing the car seat for cleaning without actually damaging it. I don't need a subscription otherwise.
    Thanks for your help and hope to hear back from you soon,
    Donna
  • Jyackle5
    Jyackle5 Aug 01, 2010
    Yes your subscription was cancelled. As for getting the manual please click on the link above and enter the model # and date to download it. On the manual it will tell you hoe to remove the seat.
How do I remove the headrests in order to install seat covers?
    Remove the headrests. Then slide the cover over the seat back cushion (Photo 5). Push the bottom straps through the gap and into the buckles just like you did on the bottom cushion (refer to Photo 3). Reconnect the bib panel and pull down on the rear portion of the seat back cover to remove wrinkles.
    Spruce up Your Car: How to Install Seat Covers ' The Family ...
Oct 04, 2014 | 2012 Chrysler 200 Touring Convertible 2.4L...
I need to know how to remove an air filter on a suzuki DR200 year 2000
Take off the side covers , unbolt the seat and remove( two bolts), the air box is under the seat. Flip the two tabs and lift the cover. Unscrew the center wing nut and lift the air filter out. Clean it, re oil it, and put back in, reverse order.
Sep 21, 2010 | 2001 Suzuki DR 200 SE
How to wash Bugaboo Cameleon seat fabric? As the manual told that all the parts are able to taken apart but I still confused. Especially the seat fabric. there are the back support saw inside. I have no...
If you are talking about the base seat fabric, before you put the seat fabric in the washing machine remove the wooden and foam piece from inside the seat and then throw it in on cold with a gentle cycle. DO NOT put it in the dryer. Hang it to dry. Mine came out great like this. If you are talking about the tailed fabric that goes over the base seat fabric, then just remove the cover and put it in the washer - again NO dryer.
Mar 17, 2010 | Bugaboo Cameleon - Tailored Fabric...
Describe how to remove upper back from monarch car seat
Remove the back and bottom covers (the back cover has four clips; the bottom cover stretches over the front of the base and has two elastic bands that stretch back on top of the base). While holding the base on the floor, push the backrest all the way back until flat (this will take some force). Slide the axel off to the right (your right as you are facing the front of the seat).
Oct 04, 2009 | Britax Monarch - Red Racer Booster Car...
I am unable to remove the back to convert this car seat to a booster.
Sep 02, 2009 | Britax Monarch - Red Racer Booster Car...
Need to clean carseat al eddie bauer online manuals aren't availa
First, snap out the black pieces that attach the cover to the seat with a pair of pliers or a kitchen knife. Then turn the seat over and remove the base by sliding out the metal rod that runs thru the base and seat. Then unhook the center buckle from the bottom of the seat and back up thru the seat. Unhook the straps from the metal bar on the back of the seat and thread them back thru the seat. Be sure to remember the order in which you slide it thru the components so you can reassemble. It may be helpful to lay them out in the order you removed them. Unhook the elastic bands holding the bottom in place and slide it over the top part of the seat and off the seat. If you need to remove the top part and wash, remove the black pieces the same way as the bottom, unhook all elastic and slip it off the top. I wash mine in cold water with mild detergent and usually let it air dry so as to not shrink it. Reassemble by reversing steps.
Jun 06, 2009 | Eddie Bauer 3-In-1 with Latch
Eddie bauer convertable car seat
Product number and the manufacture date is located on the side, back, or under the base.
Oct 27, 2008 | Eddie Bauer 3-In-1 with Latch
Removing the seat cover from base
Have you removed the harness?
Once the harness is removed, you pull the top of the back seat down and back at the same time, and the back should be removed.
Can you post the model number from the bottom of the seat if those instructions don't hurt?
Jun 16, 2008 | Cosco Alpha Omega Elite - Hammer Print
How do i get the seat of to wash?
I was able to find an online instruction manual for this stroller. From that manual, I was able to find the following instructions for removing the seat for cleaning.
"10 REMOVING AND REFITTING THE SEAT COVER
Remove hood from stroller if fitted.
A Twist shoulder strap end buckles and feed through holes.
B Feed waist and crotch straps through holes.
C Unclip seat cover retaining straps.
D Unfasten seat fabric from handle tubes and seat base.
E Slide fabric from seat back and base.
F When refitting seat fabric, insert seat back support tubes
into fabric slits.
G When refitting seat fabric to seat base, loop fabric flap over legrest
strap and pass crotch strap buckle through both holes in seat fabric
and then hole in seat base.
H When refitting shoulder straps, twist buckles and feed through holes."
Dec 18, 2007 | Maclaren Quest Mod Stroller
Shield reattachment
Well, I don't have a solution to getting it back on, but if you could tell me how to get the stupid thing off, I could maybe figure out how to get it back on for you. :) I can't find anything about it via Cosco either. grrrrr!
Aug 08, 2006 | Cosco Alpha Omega 22-180 - with Shield
Safety 1st Alpha Omega Elite 22456 TTN Convertible Car Seat Logo
280 people viewed this question
Top Safety 1st Baby Gear Experts
Rob Sinbad
Rob Sinbad
Jennifer Rock
Jennifer Rock
Are you a Safety 1st Baby Gear Expert? Answer questions, earn points and help others
