Question about Sanyo DP32746 32 in. LCD Television
Volume on Sanyo TV stays low even when maxxed out
TV Volume problems, it's Low and won't go Hi
Check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Mar 31, 2015 | Televison & Video
User guide for a sanyo DP40142
I assume you don't have the TV muted, right? Otherwise you may have a sound processing issue in the tuner.
Jun 22, 2014 | Sanyo LCD-40E40F 40 inch Multi System LCD...
Tv volume max
Get another main board, they are fairly cheap.
Or send yours for repair.
www.coppelltvrepair.com
Feb 24, 2014 | Sanyo Televison & Video
My volume don't work
I too have the same problem but have misplaced the original converter. If you have one, try using that for volume. Even the volume button on TV will not work. Looks like your cable connection is ok. Anything else connected to this tv like PVR, ?
Jul 19, 2013 | Sanyo DS19310 19" TV
Volume will not increase.
S\Check whether volume limit lock is on or not. BTW, what is the brand name to your TV?
Feb 28, 2013 | Televison & Video
Watching streaming movies but sound very low even with speakers maxxed out. How can I boost volume?
Check your settings in Control Panel/Sounds and Audio Devices. Make sure vollume is turned up and that the default device under the Audio Tab for sound playback is set to your Altec speakers.
Aug 11, 2012 | HP Computers & Internet
I bought a Sanyo model DP55360 Nov. 2010 that now has started turning itself off after a short time, when I restart the tv it shuts off even sooner than before which continues until it will not restar
When it does come on, before it shuts down, does the volume seem to fade real low first? If so its a problem in you main board. IC1670 is bad. Its pretty much a voltage regulator for the audio tract.
Jun 30, 2012 | Sanyo Televison & Video
Nokia BH-103 low volume.
bh 103 is fail product don't advie to other i suffer lot because i purchsed before 12 houres volue very low it is like 100 rs local ear phone & current it stop working with in 4 minits playback nokia now start bad production & try to foll to all customer
Jan 19, 2010 | Motorola Mobility H710 Bluetooth Headset
Sanyo DS32224 tv remote
It sounds as if you have inadvertently selected the 'Aux' function. Pressing the 'TV' button (should be close to the Aux and others) should restore full control.
Since the volume generally means 'TV Volume,' this function often stays effective but the other controls will not respond, including 'Power.'
This happens to us all the time with our Dish remote which also has 4 basic functions.
Apr 26, 2008 | Sanyo DS32224 TV
Sanyo DP32746 32 in. LCD Television Logo
237 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
