Question about Cell Phones
When i plug my phone into charge it suddenly says unauthorized charger and will not charge my phone
  • 532 Answers
The charger is bad.
Replace the charger with another one and it will work fine.
Thanks.
Posted on Jul 28, 2010
When I plug in the charger it wont charge Im not getting like unauthorized charger message it just wont charge
I advice you try get a similar charger to charge your phone, if the similar charges your phone, it means your charger is bad and will need to get another charger or the phone.
But if it did not charge and you still get the same message, it means the charging port on your phone is the problem, the charging port on your phone is bad and can not read the charger, so you will need to replace or change the charging port on your phone. Doing thi will solve the problem on your phone.
Take care.
Jul 19, 2010 | Motorola Mobility Hint QA30 Cell Phone
Unauthorized charger
HimoronI
Could be you have a battery issue.
Mark
Motorola Support
Dec 26, 2009 | Motorola Mobility MOTO W755 Cellular Phone
Motorola v325 won't charge after using phillips universal charger
Sometimes a bad charger can send a high voltage charge to the phone and fry the charging port on the phone. That is why a lot of the car chargers today have a fuse on them now. So that it will blow the fuse on the charger, instead of frying your phone's charger spot.
Dec 01, 2009 | Verizon Communications Motorola V325i...
Whenever i plug my charher into my motorola razor it says unauhorized charger.
The "unauthorized charger" message is hence telling you that the power
output of your charger is significantly lower than a Motorola charger
would provide. It may or may not still charge the phone, you'll have
to try it to see. If it does charge the phone it will take longer to
do so than a higher power charger would.
Hope this helps. =)
Oct 20, 2009 | Motorola Cell Phones
My motorola hint phone says "unauthorized charger"
u have to turn off ur phone and then put the charger on..thts another way to fix it ..it can be any charger..u have to turn off ur phone then put the charger on
Oct 04, 2009 | Motorola Mobility Hint QA30 Cell Phone
change your battery and charger. tnx
Jul 28, 2009 | Motorola Mobility MOTO W755 Cellular Phone
Unauthorized charger everytime i plug it in.
There may be a problem with your charger output. Do you have another charger you could try?
A temporary workaround is to reboot the phone with the charger still attached. It should now say "Authorized" and start charging.
Jul 25, 2009 | Motorola Mobility W385 Cellular Phone
My motorola w755 stopped charging
Is it saying "Charging" when plugged in?
Could be the wall charger.
Mar 12, 2009 | Motorola Mobility MOTO W755 Cellular Phone
Motorola Razr phone charger gets message, ''unauthorized charger.
The problem was in the point of connection between the charger cord jack and the cell phone charger receptacle.  By moving the jack within the connection I was able to resume charging.  The connection may have become faulty as a result of heavy usage.
Feb 15, 2009 | Motorola Mobility RAZR V3i Cellular Phone
"Unauthorized Charger"
you can try to clean the charger port (but first make sure its not bent, or broken - the pins are really tiny and hard to see, so make sure)
But try cleaning the charge port on the phone and the charger with denatured (rubbing) alcohol, and a toothbrush -
Just make sure not to plug it in when you do this!
and clean both the charger and phone, make sure neither are bent
lastly, try a new charger!
NGK
Dec 22, 2008 | Motorola Mobility RAZR V3
Cell Phones Logo
557 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
