When I turn my computer on, there are beeps. My 'A' key was stuck but I've taken that out now and unstuck it but beeps are still heard. Also, a lot of my keys no longer work.
    Guru:
  • 352 Answers
Try to find another keyboard to test out on your computer. It does sound like the keyabord you currently have may have stopped working properly. If a different keyboard does work, then you'll know it's the old one that was giving yout problems.
Good luck.
Posted on Jul 28, 2010
Mobility scooter
Check the freewheel lever is not engaged.
Jun 03, 2017 | Health & Beauty
Key won't turn in ignition on 2006 chevy cobalt
on a lot of these late model computer base cars when battery power get low the computer gets confused. try this disconnect the neg. battery cable. charge the battery. reconnect and try again. my son cobalt battery went bad key was stuck in the igntion. good luck.
Dec 19, 2017 | Chevrolet Cobalt Cars & Trucks
My Polaroid 4.3 Internet Tablet power button broke, is there any other way to turn it on?
Sometimes, if you plug in the power cord, a tablet will turn on automatically. If that doesn't work, the button will either need to be replaced, or you will need to get another tablet. A lot of the cheaper tablets like Polaroid, Coby, and the like are made to be throwaway devices. Once they break, it's more cost-efficient to just buy a new one a lot of the time.
Jan 02, 2013 | Polaroid 4.3" Internet Tablet
I have an F7 code on my gas range that keeps beeping
F7 code usually means a stuck key on the key pad. Some of the keys can be unstuck, but if high heat caused the pad to warp it might not be repairable.
  • Turn off power
  • Disconnect the key pad from the clock
    • If code goes away key pad is at fault
    • If it does not the EOC (electronic control board) is at fault
You can try giving the oven a hard reset by disconnecting the power for 20-30 minutes, then restoring the power.
Apr 17, 2011 | Maytag Ovens
WHEN I TURNED ON MY COMPUTER, (intel d845epi/d845gvsr) i heard three long beeps. what does this mean? what shall i do?
Keyboard error is what 3 long beeps is you might have a stuck key. Run your fingers over all the keys a few times then try to restart the pc.
Feb 27, 2011 | Computers & Internet
Error code E 68
A button is stuck and it needs to be unstuck. Enter key test mode during the diagnostic test mode to determine which keys is stuck.
Press and hold Select and Cancel buttons simultaneously for 6 seconds to reset the control.
The buzzer sounds then immediately turn the cycle selector knob counterclockwise to the second position from the bottom.
Press and hold the Options and Cancel buttons simultaneously for 2 seconds then the control enters diagnostic mode. The buzzer sounds 3 times and the LEDs flash.
Turn the cycle selector knob clockwise the second position from the top. The drive motor runs and the heat source turns off.
The buttons can now be tested. Press each button and the corresponding LEDs turn on. You should be able to find which button is stuck. The Options and Select buttons turn on the same set of LEDs and also the Cancel and Start/Pause buttons.
Access the control and unstuck the button. Disconnect power and remove the top panel by removing the screws attaching it to the rear of the dryer. Slid the panel rearward and lift it off the cabinet. The screws attaching the console to the cabinet are exposed. Remove the screws and disconnect the wire harnesses then remove the console. The control can now be removed and the buttons are exposed. Unstuck or clean the stuck button contacts. It is recommended to clean all other button contacts to prevent the recurrence of the same problem in the near future.
Oct 28, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Key stuck in ignition of 2005 Ford Focus. Tried jiggling steering wheel while turning key, tried moving from Park position. Car starts, but I have to use the extra key to lock car. Also, does the...
your ignition have to be replaced focus 2002/7 have that problem and a lot more often if you have a lot of other keys with it,try some wd40 ,but if you do take the key out replace the ignition or you going to get stuck.
Aug 03, 2010 | 2005 Ford Focus
I spilled some water on my laptop. After removing keyboard and letting it dry, it seems key 29 is stuck. When turned on, my ThinkPad T60p shows error 0210 **** Key 29. Which letter or key corresponds to...
mcdevito75 here, Yopu should be able to lift the cover off that #29 key and use a drop or 2 of penetrating oil to free up that key, not unless that button is broke in which case you"d have to replace the entire keyboard.
Jun 22, 2010 | Office Equipment & Supplies
I have a dell inspiration 1100 and last night I was reinstalling Windows XP and all the drivers after installing the system drivers I got a diag>: I didn't know what promt to put in here so I shut the...
Since you have power on your laptop. I have this questions you need to answer: 1. have you seen Dell logo after turning on the computer? 2. After turning on the computer heard beeps? If all no do this
1. Turn off laptop remove batt and use ac adapter
2. While laptop is off press Fn key + Power button to run test check if you see display test in progress. If no, wait for 5 minutes to listen to beep codes. Once heard beeps keep pressing hold on N key. If fails turn off laptop
3. While laptop is off, press hold D key + power button. Check if you will see colors display whole screen. If no this will need to replace LCD call Dell.
If see colors whole screen replace motherboard call dell.
Oct 01, 2009 | Dell Inspiron 1100 Notebook
IGNITION KEY DOESN'T WORK
You accidently tripped the anti theft deterrent that lock the whole ignition system when the worng key or a foriegn object is inserted into the slot. The only way to fix this, is to have it taken to a ford repair shop, since they will probably have to replace the whole steering collum.
Jul 16, 2008 | 2004 Ford Escape
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
