Question about Sony KP-46WT510 46" Rear Projection HDTV
I have a red arc at the top and bottom of my screen?
  • 171 Answers
Sounds like the convergence circuit has problems.  if the user convergence adjust screen doesn't help, you probably need to call a technician.
Posted on Jul 29, 2010
Undefined
When your Kobo Arc 7, Kobo Arc 7HD, or Kobo Arc 10HD is connected to a wireless network, you'll see a and-wififull.svg Wireless icon in the System icons at the top of the screen.
  1. Tap the and-home.svg Home icon at the bottom of the screen.
  2. Put your finger at the top of right of the screen and swipe down.
    The Settings shortcuts will appear.and-shade.svg
  3. Tap the and-settings.svg Settings icon.
  4. If required, tap the slider button beside Wi Fi at the top left of the screen. The button will turn blue and display On.
  5. Tap Wi-Fi. The list of available networks will appear.
  6. Tap the name of the network you wish to connect to.
  7. Tap Connect.
  8. If you see a lock icon beside the wireless connection, it means that the connection requires a password. You'll need to enter the password to connect.
Turning off Wi Fi on your Kobo Arc 7, Kobo Arc 7HD, or Kobo Arc 10HD You can turn off Wi Fi to keep your Kobo Arc 7, Kobo Arc 7HD, or Kobo Arc 10HD to keep from connecting to the Internet, which is also known as Airplane Mode.
Turning off Wi Fi extends your battery life, and also lets you use your Kobo tablet on an airplane or in a hospital.
  1. Pull and hold the power slider at the top of yourKobo Arc 7, Kobo Arc 7HD, orKobo Arc 10HD until the power off menu appars.
  2. Tap Airplane Mode.
Oct 27, 2014 | Tablets & eReaders
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
I have Hitachi 50GX30B tv suddenly started to give green-red double vision with arcs On top and bottom of screen What is the solution?
The tv have a problems"Known as a Convergence problems"it,dead.The tv convergence board reqiure changing 2 STK convergence ICS and some or all it resistors to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 19, 2010 | Televison & Video
Television picture has an arc at the top and bottom of the screen red and green ghost
This tv have a problems known as Convergence Problems,it dead.The tv covergence board must require 2 STK convergence ICS and some or all it resisrors to change to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 14, 2010 | Philips 55PW9363 55" Rear Projection...
Green color gun shot
Bad convergence ICs. Much soldering. About $300 to fix by shop.
May 06, 2010 | Akai PT4298HD Rear Projection Television
Red and green arcs, 3-D effect
Convergence is dead.Know how to solders?Replaced 2 Convergence ICS and all it resistors.Tries Tv repair World.com,Tvrepairkits.com for the convergence kit.The shop will cost u $300 for parts and labors.
Jan 21, 2010 | Samsung HC-P4752W 47" Rear Projection...
Blue arc and ghosting across middle part of screen.
Replace Both of your convergence ICs they are big Black ICs will have STK on them! Use STK392-150s or the 180s Better ICs Call Mats Electronics 1-800-628-1118
Dec 21, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
The scroll on the top of the screen is arced
Convergence IC's are bad. You can get the parts over the inernet or you can get a complete kit - parts - instructions - etc from www.TvRepairKits.com
May 05, 2009 | Philips Magnavox 51MP392H Rear Projection...
Arcs at the Top and Bottom of the screen!
You will find small 1/2 or 1watt resistors close to the ic's, you must measure them and they must be exact ohms. I believe you'll find a couple open or have changed in value, I hope the new Ic's haven't been fatigued. That should fix your problem.
Jan 19, 2009 | Philips 60PP9202 60" Rear Projection...
43fdx01b arc at top of screen
Usually this means convergence ic's have to be replaced and possibly a few resistors on small convergence board. Sometimes it requires digital alignment after new parts are soldered in. This repair can cost 175.00-375.00.
Apr 20, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
66 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
