Question about Vacuums
My electrolux oxygen canister cuts on and off. I have to open and close the vacuum, or take the base of the hose off and then re-insert. I have to do all these things before it will start up again. I sometimes shake the hose around, then it will come back on. If I try to dust with the dust brush (like a lamp shade or shelf) and the suction pulls against the object, the vacuum goes off for awhile. Sometimes I'll have to reset the vacuum by unplugging the electric cord. I never get to finish vacuuming. The unit was brand new when I bought it from and individual. It has never worked right. I took it to a repair shop, they said they bypassed a computer board to get it working. The man said the rug power tool wont work, and he bypassed the computer board so I can at least use it on my hardwood floors and to dust. But since I picked it up from the shop it drives me nuts turning off just as I get into my cleaning.
  • Anonymous Jul 26, 2008
    power cords inside wand shorted out----this is a OXYGEN 6988----drives the COMMANDER nuts----she needs---2--> aprox. 14 inch cords inside the wand--any help thx Twoturnin
    President:
  • 1,673 Answers
Maybe you should have taken it back to that shop, it appartently isn't fixed. I would have replace that board, don't believe in modifing, you usually end up with other problems, like you have. One thing to check is maybe you have a partial clog in the hose or wands. A clog would cause this shutting off, then restarting after it has cooled down. If this has a hepa filter, and it has a reset for that filter, press it to see if that is the problem. But I know that board would cost you approx. $90 to $100 just for the part.
Posted on Apr 24, 2008
I'm looking for an electrolux oxygen repair manual
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner
i have 2, 1powers up and all 3 lights flash change hoses from the good one that work fine and it still wont run and the three blue lights continue to flash and wont run
Aug 08, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
The on/off buttons are not working anymore? Any
With your hose plugged into the vacuum, check your cord at the outlet, is it securely plugged in? There are no signs of cord damage? If so, you will need to take it to the shop,but it probably just has the wrong sequence in the power buttons.. turn on the main unit switch then turn on the hose switch to the canister, if no power, then hit the switch on the machine again, it should power up, if it does not, open up the bag compartment, and shut it again, making sure that the bag is aligned inside and the cover is closed tightly. Did this fixya? Let me know. You may need to contact electrolux for a replacement hose. they are really good about warranty service and will send yu a new hose at no charge if they determine that is the problem. Here is some contact info. Thanks, Rene(the Vacuum Doctor)
http://smallappliances.electroluxusa.com/node47.asp
Nov 13, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
I have an Electrolux Aerus 2100 canister vacuum. When I
it might be that the hose connections are bad.or it might be a sensor in the vacuum. call a electrolux vac shop and get it looked at.
Jun 24, 2009 | Vacuums
9 month old electrolux oxygen vacuum just quit
my electrolux oxygen canister just quit- i think it's the sumo board and the whole fuse problem why does this keep happening over and over (my 4th time w/ this model) and where can I buy a replacement sumo board myself?
Jun 19, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
EL7020A ELECTROLUX VAC SHUTS OFF AFTER 10 MIN
The symptoms you describe are typical of a vac that has a blockage (hence poor suction). It cuts out because it's over-heating. You need to check the hose, the filters and anywhere else where something may have got stuck. Blockages are often caused by things like paper clips, but can be caused by something as apparently harmless as a piece of paper which gets stuck and then debris builds up behind it and causes a log-jam.
Feb 10, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vacuums Logo
74 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
