Question about Bosch Dishwashers
My Bosch Dishwasher will not power up
My Bosch ''she43f02uc/52'' dishwasher will not power up. I have changed receptacles, but no success. There is a small amount of water still in the bottom of the appliance.It seems to have shut down near the end of a cleaning cycle, but I cannot get it to power up again.
  • Bosch Master
  • 2,605 Answers
Hi, Welcome to FixYa.
I would start by first shutting off the breaker.
You mentioned you replaced the "receptacles", I'm not sure if you are referring to the junction box but...I would start by removing the kick plate ( access panel at the bottom ) and checking the wiring at the junction box for the dishwasher 120vac supply line.
This is actually quite common to find a wire murret/connector come loose due to improper fastening and once the unit is in use for a while the connections heat & cool, become loose from normal operating vibrations and burn up from all the added heat caused by "resistance".
The end result is no power to the controls. Check it out and post back what you find.
Thanks for visiting "fixya" and please take a moment to rate the solution/suggestion provided here for you.
Good luck.
Macmarkus :)
Posted on Jul 28, 2010
  • Mark MacDonald
    Mark MacDonald Jul 30, 2010
    Hello again,
    I see you rated my post, but you didn`t comment on what you found.
    Did you find the problem ?
    I was going to suggest other possibilities, but that would have been based on your reply or your findings. I typically start with the most common, therefore the most likely problem based on a visitor`s description ( which I did ) and go from there.
    If you could let me know what you found or if the issue has been resolved that would be awesome.
    thanks again,
    macmarkus :)
  • Gone2Bodega Sep 12, 2010
    I can't thank you enough. Pulled off the kick plate and the access plate to the junction box and it was exactly what you said it would be. Thank you for your time and talent.
Our dishwasher has two grey and one green wire but the instructions say there should be a white, black, and green one. How do we figure out which wire is which?
The green is the earth. If the other two are the same colour, I guess the polarity positive and negative doesn't matter. What does the Bosch installation instructions say?
http://www.doityourself.com/stry/220-wiring-color-code-interpretation
Dishwasher GFCI Requirement ' Electrical Construction ...
ecmweb.com > Forums > Electrical 101 > National Electrical Code (NEC) Mar 4, 2014 - 18 posts - ‎13 authors Sounds like I have to install a GFCI breaker to protect the entire branch ... National Electrical Code (NEC) > Dishwasher GFCI Requirement ...
Dishwasher: Hard Wiring Vs. Plug-In ' Home Guides ' SF Gate
homeguides.sfgate.com > ... > Other Types of Mortgages When you install a pigtail on your dishwasher, you must plug it into a three-prong receptacle. The electrical code does not require the receptacle to be a ground ...
Installing a dishwasher- Does it really need a dedicated ...
forum.mrmoneymustache.com/.../installing-a-dishwasher-does-it-really-n... Mar 12, 2014 - 15 posts - ‎12 authors Installing a dishwasher- Does it really need a dedicated circuit? ... "If your local code requires it on a separate breaker, then put it on a separate ...
electrical - What is code for installing a dishwasher in the ...
diy.stackexchange.com/.../what-is-code-for-installing-a-dishwasher-in-th... Mar 14, 2013 - Current code suggests a dedicated line run to the breaker box for use with the dishwasher. 2008 NEC indicates that the kitchen should have ...
What is the typical dishwasher/disposer electrical connection?
diy.stackexchange.com/.../what-is-the-typical-dishwasher-disposer-electri... Dec 11, 2013 - Checking the wiring for the disposal, might give you some clues as to ... Code that allows Garburators and dishwashers to be cord-and-plug- ...
Dishwasher Connection And Wiring, Oh Boy! - Electrical ...
www.diychatroom.com/.../dishwasher-connection-wiring-oh-boy-10656... Jun 4, 2011 - 15 posts - ‎9 authors Q: should I hard wire the dishwasher or install a receptacle and wire the machine with an appropriate cord and plug? The code says you can do ...
Feb 28, 2016 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Where to buy timer motor for my bosch dishwasher SMU2042UC/14
I have had success finding appliance parts on Amazon of eBay, especially if you have a part number or Model number.
Nov 03, 2013 | Bosch Dishwashers
My bosch dishwasher beeps everytime we close the door.
Better switch of till you are ready with full load. Otherwise you have to trace the beeper and disconnect it.
Apr 12, 2010 | Bosch 24 in. SHY66C05 Stainless Steel...
Kenmore model 16625691 ultra dishwasher I have this dishwasher and after changing another appliance in the kitchen it will not come on at all. I have looked at some of the help for the reset fix but it...
The dishwasher is plugged into an ordinary receptacle somewhere -- either in a base cabinet or behind the dishwasher. Find that, and check to see the receptacle has power. Perhaps something got disconnected in the other appliance swap or a breaker got left off and needs to be reset.
Mar 04, 2018 | Hobart AM14-253 Free-standing Dishwasher
How do I reset an old Bosch dishwasher SHI4302UC ?
Assuming that you can control power to the dishwasher from your kitchen panel switches, hold down the power on switch on the front panel of the dishwasher and recycle power (switch off and on) at the kitchen panel switch.
This will reset the dishwasher.
Sep 26, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher Start Process
lol...yes this is normal for a Bosch. They have several "safety" measures incorporated into their dishwashers. Look on the bright side they are one of the very best dishwashers on the market and are known for their longevity and quietness.
Jul 31, 2009 | Dishwashers
Dishwasher: BOSCH SHE43 - pump keeps draining
Your dishwasher is stuck in flood mode. Bosch dishwashers are built with flood switches located in the bottom base pan of the dishwasher. The flood switch is connected to a rod that activates a small interlock switch. When water enters the base pan on a Bosch dishwasher, a Styrofoam puck lifts the rod, activating the flood switch.
When the flood switch is activated, the dishwasher will go into a no-fill, only-drain mode. The drain motor may also run with the door open to the unit. This is definitely a sign there is water in the base pan. This can be caused by the drain being clogged. There are two ways to fix:
1. You can uninstall the dishwasher and tip it forward to about a 45 degree angle to drain the water out of the base pan. (This is probably why Ian Bint's solution fixed the problem.) Be sure to put a towel under the dishwasher first so that the water is soaked up in the towel instead of going all over the floor. Once you've drained all the water out of the base pan, reinstall the dishwasher and begin a cycle. If it fills and runs, you are good to go.
2. You can also unplug the unit, then remove the kick panel at the bottom in the front. (It's attached with two screws.) Then get some old washcloths or small towels and reach into the base pan below the dishwasher to soak up the water. The pan is directly behind the plastic base panel rim. Once the pan is empty and dry, your dishwasher will no longer be in "flood mode" and will run properly.
If the base pan keeps refilling with water and the no-fill problem returns, there is definitely another issue, such as a clogged drain. At this point, you need to decide whether to invest in an expert evaluation by a certified Bosch repairman and make the necessary repairs, or buy a new dishwasher.
Jun 28, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Burnt wiring on Bosch SHX46A06 Dishwasher
Bill that is exactly what happened, the connection wasn't correct from the start. The Bosch dishwasher pulls 11 amps during the cycle while heating the water to temp. The cooler the water the longer the heat time. Your dishwasher came with a set of wire nuts that where suppose to be used. Be sure when you correct this to use 20 amp wire nuts with the unit. This will stop this from happening again.
Aug 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
284 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
