Question about Jenn-Air JGR8850 Gas Kitchen Range
I have a Jenn-Air gas cooktop, Model CG205W. It's about 20 years old. For some reason while I was cooking just now, the igniter on one of the burners I was not using started to click, and it will not stop unless I unplug the unit. I unplugged it and left it unplugged for awhile, and tried again -- same problem. I don't want to burn out the igniter, but now I can't finish my recipe! Can you help????
freetek
  • 5568 Answers
SOURCE: My jenn Air gas cook
One of the switches that control the ignitor is stuck; you might remove the knobs to see if the switch actuators are visible without removing other panels and check to see if they can be operated by annoying them with an insulated probe such as a chopstick or wooden skewer. Ours are controlled by a cam that is part of the knob itself that passes an extension of the switch. The extension is visible with the knob removed.
Good thing you pulled the plug since the high voltage transformer that supplies the spark is definitely not designed for prolonged operation.
Posted on Oct 15, 2008
SOURCE: Jenn-Air electric range
my jen-Air has a problem with it continuing to beep. Ive tried to get it to stop by pushing all the buttons. When I pust the off/cancel button it just keeps beeping. Tried the stop timer button and same thing. When I turn on either the bake or convection bake button it automatically just shuts off by itself. It is approx 10-13 years old. HELP, or please tell me to get a new one.
Posted on Oct 23, 2008
SolutionGuy
  • 331 Answers
SOURCE: Worth fixing 2005 jenn air elec downdraft cooktop?
"Breaker tripped and all power blew when stove not in use. Can't turn breaker back on. Repairman thinks it is two switches since the wouldn't turn on. He fixed them so they didn't stick - but still tripper blew but at least not all the electricity."
Oban, This does NOT sound like a cook top issue --> "blew when stove not in use", "Repairman thinks it is two switches" (I assume you mean the breakers),
I could go on and on.... but what I've seen with these is improper connection at the junction box. In other words, whoever wired it up, screwed it up. Look at #4 in this diagram. The problem is happening here.
"He fixed them so they didn't stick"....Oban... the reason a breaker is there is to trip when there is a short circuit. It is most definitely NOT there to be bypassed! You may consider RE-considering your choice of electricians.
Go outside and kill the breaker. Then open up the junction box (you have to open the doors below the cook top). When you remove the cover of thew J-Box, I'll bet you see burn marks (if not melted plastic).
Check it out.
SG
Posted on Apr 22, 2009
  • 58 Answers
SOURCE: gas range igniters won't shut off
The problem that you're describing is commonly associated with the spark modulator. It usually occurs after a spill or when the ignitor electrodes have remained wet after a cleaning. If after a day or two it continues to spark intermittently on its own, then the only recourse would be to replace the module. Hope this helps,,,, Bill
Posted on May 28, 2009
SOURCE: My gas bake burner won't ignite.The igniter is
If the bake ignitor comes on - check the amperage on the bake ignitor wires when it's on. Amperage should be 3 - 3.6A. If less than 3A - replace ignitor.
Ignitor part numbers (any will do, but the first one is a direct replacement): 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
All those are interchangeable, if you can splice the wires.
Posted on Jul 15, 2010
Gas Kleenmaid cook top, one igniter continues to
the switch for the ignitor is stuck. might need to free the switch, of
> call the repair man.
Oct 20, 2013 | Jenn-Air 30 in. CCG2423 Gas Cooktop
I have a older Jenn air electric cook top and I need to replace the burner element on one side. How do I get the old one out and where do I find parts. JEA 800 ADB
get a gas repairer to check for you or you go back to where u bought it and the burners will be replaced or sold to you if the cooktop is still under one year warranty
Jan 19, 2011 | Jenn-Air JED8230 Electric Cooktop
Flames too high Jenn-air CCG2423
Definitely cut your loses and get a cooktop with a warranty. That unit sat on the back shelf for a reason.......it didn't work properly.
Also, but a cook top that is compatible with the safety knobs they sell as child guards at places like lowes and home depot.
here is a link to show you how the child proof knobs work
http://www.associatedcontent.com/article/327577/childproof_your_stove_safety_1st_stove.html
Jun 20, 2009 | Jenn-Air 30 in. CCG2423 Gas Cooktop
No wattage given with electrical requirements for gas cook top
A gas range requires minimal electric current. "Any ole" circuit will do.
Charlie
May 13, 2009 | Jenn-Air JGC8430 Gas Cooktop
Jenn-Air JGD8130
The problem is the pot(s) is too far from the heat. Jenn-air needs to make a burner cover that is closer to the burner for boiling water...
Nov 08, 2007 | Jenn-Air JGD8130 Gas Cooktop
Jenn-Air JGR8850 Gas Kitchen Range Logo
193 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
