Question about Leviton 8299 Combination Switch / Smart lock GFCI Outlet
I would like to replace a switch going to a fan with the 7299-NA
I would like to replace a switch going to a fan with a leviton combo 7299-NA.
Currently the box has 2 wires with ground connected to the switch. The white wires are connected together away from the switch and the black lines are both connected to switch.
How do I connect the 7299-na especially the two black wires that are already on the combo unit?
Thanks
  • 843 Answers
First you must determine which wires in the box are LINE and which are LOAD. Remove the wire nut from the two white wires and separate them. The LINE wires are the black and white wires that come from your breaker box. The LOAD wires are the black and white wires that go to the fan. You can determine this easily with a non-contact voltage detector (about $15). Or temporarily hook up a black & white pair to a lamp. In either case, make sure the exposed wires won't be touched and turn on the breaker for your test.
I will assume that you want the GFCI to protect the fan. Refer the picture (Back View) in the upper right corner of the front side (page 1) of the instruction sheet. If you lost the instruction sheet, you can find it on this page: http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=417265&section=11624&minisite=10021 Connect your black LINE wire to the upper right (LINE, brass) terminal. Connect your white LINE wire to the upper left (LINE , silver) terminal. Remove the yellow tape that covers the load terminals. Connect your white LOAD wire to the lower left (LOAD, silver) terminal Connect your black LOAD wire to one of the two switch leads with a wire nut. Connect the other switch lead to the lower right (LOAD, brass) terminal.
Posted on Jul 29, 2010
Testimonial: "Perfect!!! Exactlt what I needed to confirm. Your assumption are 100% correct."
  • Al Kupchella
    Al Kupchella Jul 29, 2010
    Another assumption I made is that you don't want the switch to operate the outlet in the combo unit. It will remain live in either switch position.
I have a leviton double switch that i can't get to work. I have 3 white and 3 black in the box
Try the link below for a diagram.
I would think that you have one black feed and two black legs going out, and three common wires that should be wired together with a wire nut. Is this for a ceiling fan with a light? or ?
May 14, 2014 | Leviton 5634 Dual 1 Pole Switch Decora...
What model Leviton GFCL should I use? My wire is a 600 volt 12/2 with ground. Said wire feeds other GFCL outlets.
Any off-the-shelf GFCI sold today with work on 12-2 wire:
By code, 12-2 wire should be connected to 20 amp circuit breaker, but typically most switches and outlets wired to that circuit are rated 15 amp. Amp rating is printed on electrical devices.
Leviton 15 amp 7599-W:
http://www.amazon.com/Leviton-7599-W-Receptacle-Feed-Through-SmartlockPro/dp/B000VYO9MU/ref=pd_cp_hi_3
Leviton 20 amp 7899-W
http://www.amazon.com/Leviton-7899-W-SmartlockPro-Indicator-Wallplate/dp/B000N663PM/ref=pd_cp_hi_0
Wiring:
http://waterheatertimer.org/How-to-wire-GFCI.html
Jun 17, 2011 | Leviton R01-7299-0NI Switch And GFCI...
I have a black/white/ground wire coming from my power supply into my bathroom. I want to install a 274w combination device so as I can have one plug outlet and a switch for the shower fan.I need to see a...
1) In this situation we need to test the wires.
Electricians don't guess, they test, and a diagram would be guessing which wire color does what.
2) FYI: non-GFCI receptacle located in bathroom is not code, and device will have to be replaced when property is sold. The reason for GFCI is the likelihood of you holding defective electrical gizmo from China in one hand while putting other hand in running water. Or electrical gizmo falling into bathtub occupied by wife with large life insurance policy.
If you have kids using that bathroom, I want you to avoid using non-GFCI device.
3) Your new device has color-coded screws: Dark, brass, and silver.
These colors tell electrician how to wire the device.
4) Let's test to see which wire connects to which screw:
Separate wires.
Use ordinary 2-wire tester from hardware store.
Tape tester leads to wood sticks so hands are away from power.
Turn power ON.
Test each wire to bare ground wire.
Tester lights up on Hot wire. Hot wire connects to dark-colored screw on device.
Hot wire is identified.
Test Hot wire to all other wires in box, except bare ground wire.
Tester lights up on Neutral wire. Neutral wire connects to silver screw, and will complete circuit to receptacle.
If box does not have a Neutral wire, the circuit to receptacle can be completed using ground wire on silver screw, but I am not recommending that.
Last wire goes to Load (light, fan, motor). Load wire connects to brass screw, and will complete circuit to Load.
Add a comment for more free help.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on electrical device.
Leviton and Lutron both make GFCI switch-outlet combo.
Buy at Home Center or on-line
Leviton 7299
http://www.amazon.com/Leviton-7299-NI-15-Amp-125-Volt-Combination/dp/B000UJADW6
Jan 02, 2011 | Cooper Industries Cooper Wiring 274W...
A Bryant 3 way independent rocker switch with red, black and white wires for 3 lights in bathroom one switch not working can i replace it with a Broan Nutone P66V three function control
397bfdd.jpgLeviton triple switch
fe442eb.jpgNutone P66V
Nutone looks like an ordinary three-switch combo being marketed as a bathroom 'fan switch.'
The screws on the device would tell the story.
Look at the Leviton screws:
The switch has dark-colored screw on one side >> the hot from breaker always connects to dark screws.
Other side of switch has 3 silver-colored screws, but these can be brass colored screws > the wires to fan light and heater connect to each of these screws.
Most likely the Nutone switch is identical to the Leviton
I say this because the descriptor on Amazon describes it as a 'fan' switch.
It's being marketed as a bathroom fan-light combo switch >>> so it looks like an ordinary three-combo switch
Oct 28, 2010 | Broan-NuTone P66V Fan Control Switch
How do I wire a leviton 7299 combo switch. I have power to the box from standard 3 wire cable blk and wht with a grn ground. I then have another cable again blk/wht with a grn ground going to a set of...
Ok this is a GFCI switch receptacle combo. You will connect the incoming cable to the incoming terminals on the Recptacle. White goes to Line (silver) terminal Blk goes to Line (brass) terminal. For the light connect the white to the load terminal (silver) Then take a short black wire and connect from the Load (brass) terminal to one of the switch therminals. Connect the remaining outgoing black wire to the other switch terminal (at bottom of switch) connect both green wires to green ground screw. (best to "pigtail" ground wires so only one wire on terminal. This will give lights GFCI protection also good for hanging lights in a bathroom.
Aug 17, 2010 | Leviton R02-7299-0NW Switch And GFCI...
I'm using a Leviton 1755 combo 3 switch for a bath light/fan combo and then onto a vanity light. Basics: wires from ceiling light/fan: black, red, white, ground. Wires to vanity light: black, white,...
remove white switch one and connect to incoming white ground--all whites should be connected [hooked] together these are grounds-- switch 1 black from fan ,leave switch 2 red from fan ,switch 3 vanity black
Feb 22, 2010 | Leviton 003-1755-W Three Rocker Switches
Wiring switch and GFCI outlet tandem, so that
There should be 2 screws at the top that say LINE. This is where you connect the power wires. The 2 screws at the bottom should say LOAD. That is where you connect the second outlet.
Dec 13, 2009 | Leviton R01-7299-0NI Switch And GFCI...
I need instruction manual for a gfci recepticle and switch combin
power coming in from the breaker box: black wire will go to line-hot screw, and the white wire will go to the line-white screw. the switch wires coming out of the back of the gfci- 1 will go to the load-hot screw & the other black wire will wire nut to the black wire going to the light. the white wire going to the light must go to the load-white screw.
Apr 12, 2009 | Leviton R01-7299-0NI Switch And GFCI...
Leviton 8299 Combination Switch / Smart lock GFCI Outlet Logo
288 people viewed this question
Top Leviton Electrical Supplies Experts
Steve
Hippy_dd
Gene Haynes
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
