I replaed the thermostat for Rheem RGPJ-05NAUER Furnace,but it did't work after that. so what do you think that could happened if i made a mistake with connicting the new thermostate? is it a fuse or control box or switch...?
  • 455 Answers
Hello Ikark Check for a jumper wire at RH & RC termnials it should be added if not there.
Posted on Jul 29, 2010
What airflow does RHEEM RGLN 07eamer Furnance have? Is it downflow or upflow?
looks like Downflow
Rheem Classic Series Downflow Gas Furnace cdn.globalimageserver.com/fetchdocument-rh.aspx?name=rgln... · PDF file Rheem Classic® Series Downflow Gas Furnace FORM NO. G11-519 REV. 1 RGLN- Series ... RGLN- SERIES 05EAUER 05NAUER 07EAMER 07NAMER Standard Filter ...
Feb 18, 2016 | Filter Heating & Cooling
Will a th5000 work with a ruud dual fuel
Are you talking about a pro 5000 Thermostat??? if so then NO it will not work.With this stat you do not have a temperature lock on the heat pump. Say you don't want the heat pump to run below 25 degrees. it won't shut the heat pump. And you don't want the heat pump to run at the same time as the furnace. With the Pro 8000 3 heat and 2 cool thermostat you can lock out the heat pump at 25 degrees outside an turn the furnace on. You will have to install an outdoor thermostat hooked up to the pro 8000 it usually comes with the stat. Honeywell products.
Nov 29, 2013 | Rheem 3.5 Ton 14 Seer / Ruud 100K Btu 80%...
How do you lite the pilot lite on a Rheem Gas Furnace Model #rgma-125a
If I recall correctly, model number Rheem furnace you listed has electronic ignition to light the pilot, when the home's thermostat calls for heat. Is this what you're having a problem with?
Mar 11, 2011 | Heating & Cooling
On occasion, my furnace will not kick on at
If your Rheem furnace is less than 10 years old, it may store an error code to help you figure out if it is the furnace or the thermostat. Look at the circuit board for a blinking light. If you have to remove the panel that opens up the door safety switch, it will erase the code. Look for a small viewing port. Next time the furnace fails, prior to doing all the things you did last time, look thru the viewing port to count the number of blinks. Once you get the number, open the cabinet and on the wiring diagram glued to the back of one of the panels'\; there will also be an error code chart. It may give you a starting point where to look. If you have no error code, chances are that your thermostat is freaking out or has a bad connection. Hope this helps.
Dec 28, 2009 | Honeywell CT3200 5-2 Day Electronic...
Rheem Classic Series Super Quiet 80 gas furnace problem
I have this same POS model. It is not the thermostat. this model is just garbage and cant wait to get something that works right. i have been fighting this thing for 4+ years now.
Dec 25, 2009 | Heating & Cooling
I have a Rheem Gas Furnace with an old analog thermostat (Wires conneected to terminals R and 4 for the thermostat). I went to install a Rheem digital and programmable thermostat and it indicated that it...
if you have 2 wire at thermostat Terminals at furnace that the thermostat wire attach to should be R & W if your new thermostat has R & W terminals is should work, an easy thing to remember is the red wire on R the white wire on W. If 4 wire at thermostat at furnace green on G, Blue on Y, red on R,and white on W same at thermostat If these do not match find a thermostat with these terminals
Dec 06, 2009 | Heating & Cooling
Rheem RHQA Heater:Blower works but no heat.
Is there a setting on the thermostat for Auto or Fan? If so, make sure it is in the Auto setting. You will have a contactor that turns on the elements and a relay for the fan. Follow the wiring diagram to see which relay energizes the fan then unplug it to see if the fan stops.
Nov 02, 2009 | Heating & Cooling
Working on a Rheem 90+ gas fired furnace with A/C. Replaed the 24vac fuse twice now. Unit runs 1-3 days then blows the fuse. Thoughts?
Could be a couple of things check the low voltage wiring going from the furnace to the outside unit. It will look like a small telephone wire. Sometimes rodents like to chew this wire and it can cause a short which will blow the small fuse.
Jul 20, 2009 | Heating & Cooling
Thermostat seems to be working, furnace does not always turn on
Joss sounds like the anticipator setting on thermostat i would replace it with a digital it will be more actturat . The furnace has to go over temp setting to turn off
Jan 15, 2009 | Honeywell Electronic Programmable...
My furnace works intermittently.
You may have a dirty flame sensor. There are a number of other possible causes as well. Rheem/Ruud/Weatherking furnaces also have problems with the connection on the blower deck.
The flame sensor sometimes must be bypassed around the MOLEX CONNECTOR in the deck due to humidity.
Hope this helps.
Matt
maxhtcl1@verizon.net
Jan 14, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
66 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
