Question about Panasonic KX-TG1033S Cordless Phone
Terrible static making phone unusable. causes? solutions? do not have dsl service through phone co. Cable co. supplies phone, tv, and intenet.
  • 1,606 Answers
I have these phones at home connected to a vonage box and the local cable company sells their own version so they are not very helpful to say the least and I've heard they actually choke the signal.
static on these phones will come from a few sources. They will be internal ie a damaged phone, bad or low batteries or the base station or the antenna on the base. You can also get this from a poor Internet connection or when the net is slow. As an example on our 'high' speed cable modem the voip or vonage box should connect and the delay should be no longer than 50ms that is 50/1000's of a second. Any more and you get static on both ends of the conversation.
First thing I would check is to see if it is a handset that is causing this. So what you do is remove the battery out of all of the hand sets and then plug one in, check for the static. Then take the batteries back out. repeat for each. that will tell you if the problem is one of the handsets. Next thing is to relocate the base station and check the cables and connections carefully. These phones are pretty good about ignoring electrical interference from microwaves or wifi's. However is the antenna on the base is close to a strong electrical signal source it may still get noisy. The base should be away from any wiring or other electrical devices, also make sure there isn't metal in the walls close by ie ductwork or kitchen back splashes and so on.
Next you need to contact your isp and get them to check your connection for both speed and noise. You can have a fast connection but even as little as 1-3% noise can cut that speed by more than half.
When our phones have been bad the isp/cable was the problem.
Posted on Jul 28, 2010
    President:
  • 2,047 Answers
Usually statis in phones are caused by two things either an improper connection or interference from other transmission device. Although a thrid cause can be identified as the phone speaker making partial contact although this is very unlikely.
If you have other devices around phone which emmitts radio waves try relocating phone away from them to avoid interference on phone.
If not this, then try tracing the cables which are used in connecting the phone as if there is an impartial contact or a bridge between the cables you could have static problems on the phone. Although it is advisable to get an expert to check the cables as their connection can be a bit tricky. If after this the problem persists then call your cable company.
Hope this solution has been helpful?
We have 3 TVs. Can we watch on anyone of them and is so can we watch on two at the same time?
Jerry, since you did not mention what the signal source is (over the air, cable co, phone line DSL via modem, a direct wired (coax) VCR or DVR, other source it is unlikely anyone will be able to help.
FWIW, if your source is over the air, each TV can tune any channel it receives. If it is cable co or via DSL modem, each TV must be connected via appropriate wire / cable box / etc.
The above isn't much help, but without more info-details, there's little more I can do to help.
Positive thoughts and best wishes.
Mar 14, 2018 | Televison & Video
Vtech model 2656 caller id is not working. How can I fix this?
Found this on the VTECH support site regarding your model:
Tip 1 of 1
Caller ID and Call Waiting ID are subscription services, available from most local telephone service providers. You must subscribe to these services in order for the features to work on your phone. Contact your local telephone service provider for more information.
In addition, your caller must be calling from an area that supports caller ID.
Both you and your caller’s telephone service provider must use compatible caller ID systems.
If you subscribe to DSL service for this telephone line, DSL filters must be plugged into EVERY phone jack that has a phone. The DSL signal can cause caller ID disruption, static, noise and other issues on your line. DSL filters block the high frequency DSL signals from being transmitted to the telephone. If you are not using the DSL filters provided by the telephone company, this will cause static/noise and possibly caller id issues on your phones.
In most cases, we recommend you connect the plug end of the DSL filter into the telephone jack, then connect a telephone cord between the filter and your phone.
Please contact your service provider to obtain DSL filters and installation information.
Caller ID and Call Waiting ID may not be available for every call. Common reasons are incompatibilities between your and your caller’s service, transmission errors and answering calls before the ID data is received.
In addition if you would like to contact them or get more info on your phone, then use this link:
http://www.vtechphones.com/vtechui/support/faq_index.cfm
Nov 22, 2009 | Vtech VT 2656 Expandable Cordless DSS...
Phone line won't hang up
I would check the DSL filters. Your phone should not interfere with the DSL. Make sure there is a filter on any line going into your phones. If there is a filter replace it and see if that works. Also, check other equipment on the line, fax, computer, credit card machine. They will need filters from the DSL too. Remove these other devices and check the line for the problem then add them back one at a time.
Aug 01, 2009 | AT&T 964 Corded Phone
How do you receive fax on hp officejet 4110
Do you have any Digital Answering Machines in the house?
or is it a dedicated line?
anyway heres the link for the 3 digit error codes document, its a public document that can be found by searching www.hp.com using this Article #: bpu02549 or buu02549
anyway as you can see 388 result/solution is the following...
Problem: Unable to complete the connection.
Solution: *Reattempt the fax reception at a different time when telephone line conditions have improved.
Now this means that one or both fax machines can have a problem. So lets isolate the problem.
Place a regular phone into the wall jack that the OJ 4110, if there is a static sound then its the phone line that is having the problem. if there is no static continue on...*Note if you have a DSL Internet service you NEED a filter for the fax*
What this is most commonly caused by is Bad line conditions which can occur in some different ways.
1) If there has been recently a Thunder Storm the electrostatic discharges interupt phone signals.
2) Recent power line downage
3) Recent Phone line downage
4) The phone company upgrading the lines
But basically something is BLOCKING the faxes from hearing each other. That is why you get this error code.
You can call your phone company to run a line trace. The reason you want to do this is so that you can eliminate the possibly of Static, Yes there are differnt types of it;
1) the normal static that you and me can hear
2) the SuperSonic Static, AKA Static in the Higher Frequency Ranges, where your DSL internet connection is. the Fax will pick up on those Higher frequency ranges, and it will cause problems. So put a DSL Filter on the Fax it wont hurt, and most of the times it helps alot.
Again Make sure ECM is disabled.
other than that, try unplugging all devices on the phone system an try...
i think there is alot fo information, i cant think of anything else...
Hope that helps
Jun 19, 2009 | HP Officejet 4110 All-In-One InkJet...
2wire 2700HG-B Dsl light blinks green than turns turns red, keeps repeating. does not connect.
If your DSL light goes green solid to red check to make sure all your phones are filtered. Make sure your not filtering your 2Wire.
May 14, 2009 | 2wire 2700HG-B Router (2700HGB)
Wired router keeps cutting both computers off
Check you wall plug power supply, they get bad not long after they are put to service. Find a replacement power supply with preferably higher current rating and your problem goes away.
Dec 21, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
GE Dect 6.0 Cordless - Loud Static
question is are you running a pc and router/ modem on the same land line
if so you will need the line filters to the phone base
the computer data is transferred by the same land line and there is every possibility that the different frequencies is what is causing the static
reference from a uniden trouble shooter ( will be common as the phones use the same medium)
lots of noise or static on the line === possible solutions --check for interference from appliances ( microwave , tv etc ) or wireless devices ( baby monitors wifi equipment etc)
move the handset base away from the source
if you have any device that uses the phone line , add a DSL or telephone line filter to the system
it is possible from the times you state that the interference could be coming form a neighbour or further down the line so the filter may be the option
available from phone shops or places like JAYCAR
Jul 11, 2017 | Uniden Cordless Phone
Got caller id from local phone co., where we also have dsl service. we can not view call id on our tv, who we have service with direct tv. how can we view our call on our tv?
make sure there is a DSL filter plugged to phone jack that is connected to the directv receiver. if u dont have one, you can pick one up from any electronics store
Jul 03, 2008 | Samsung SIR-T451 DirecTV DTV Receiver
Static on line after DSL installation
I had the same issue - DSL company told me to remove the filters. It worked.
Jan 22, 2008 | GE 25951EE2 Phone
Static
The cordless phones have a button to change the channels that are within the radio freq. range. I would change the channels until you get a clear/static free call.
May 20, 2007 | Northwestern Bell 35807 Cordless Phone
Panasonic KX-TG1033S Cordless Phone Logo
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
