Question about Whirlpool Dehumidifiers
The Whirlpool AD25DSSO model dehumidifier in our basement is discharging a slimy water from the continuous drainage hose. That water is clogging the floor drain in our basement. How can I get rid of the slimy water and just get "water"?
  • 105 Answers
SOURCE: Connecting a drain hose
Most units have a drain connection, either on the machine itself, or in the collection pail. These connections usually fit standard garden hoses.
Posted on Jul 17, 2007
  • 417 Answers
SOURCE: Bucket fills up instead of water flowing out hose
There must be a blockage in the hose causing the water to back up and flow into the bucket. Try pushing a flexble peice of wire through the hose to unblock it.
Posted on Oct 17, 2008
  • 340 Answers
SOURCE: looking for floor drain hole cover that accepts a hose
yep home depot get one with holes and a plastic tie will keep it in place
Posted on Jun 17, 2009
SOURCE: Continuous drainage
Take out the drain pan and look in left hand top of the compartment and you will see a drain hole for the pan.Plug the drain hole with a small rubber plug, I used an electrical wire nut wrapped with tape and it worked fine.replace the pan and the water will run out the back. A 3/4" garden hose should work for the drain hole.
Posted on Jul 28, 2009
wcrawf11
  • 52 Answers
SOURCE: water does not drain thru hose for continuous
water only comes out when you have hi humidity
and will only drain after the unit shuts off
the indoor blower motor makes a vaccuum and holds the water in the drain pan
Posted on Sep 11, 2009
Model AD50USS1 Dehumidifier, discharge hose is hooked up, but machine still empties water into the bucket, how do i get it to discharge through hose?
The problem is that either the discharge hose is clogged, to long. 48" is the standard length. In addition, the hose connector on the unit and it's interior tubing may be clogged.
The hose is easy to check for a clog. Simply remove it and either look thru it or blow thru it. If the hose is clear, the clog is in the hose connection and/or the inner drain tubing. To unclog it, do the following.
Turn the unit OFF & unplug it.
Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hose connection & tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow.Reconnect the hose, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor the hose end, for water flow. It may take 10 minutes or more for the water to start flowing.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
Hope this helps you unclog the problem. Thanks for choosing FixYa.
Aug 21, 2011 | Whirlpool AD50USS Dehumidifier
Basement smells musty, fan won't stay on continuous
Barbara, are you running the unit in a continuous mode (i.e Using a hose to drain the unit)? Or is the water draining into the water collection bucket?
If you are not using a hose for continual drainage, the fan will not run constantly. It requires that, for continual operation.
Also, you may have the humidity extraction level set to high. Lower it to 35%. Also, remove and check the air intake filter, as it may need cleaning.
Dehumidifiers that are not Low Temp models have a difficult time operating in basement applications. Because the air temp at floor level is colder than at shoulder level. At temperatures between 40 & 60 degree F, regular dehumidifiers struggle to keep up. Raising it up off the flow on to a sturdy table, counter top, etc that can handle the weight of the unit, plus a full bucket of water can really help.
I hope this was of assistance and thanks for choosing FixYa.
Jul 29, 2011 | LG LHD459EL Dehumidifier
The hose discharge does not work
This may be as a result of a clog in the hose or inside the hose connect tubing of the unit. When this happens, water continues to go into the bucket. To troubleshoot and solve the problem, follow the directions below.
1. Turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet.
2. Disconnect the hose (which should be no longer than 5 feet) and inspect for clogs. If any found,
remove them.
3. If the hose was not clogged, use an 18" long plastic Zip Tie or something similar. That is flexible and appropriately sized to fit into the hose connection. NO wire coat hangers, though.
4, Carefully, insert the Zip Tie and continue to push it in, until you reach a bend in the tubing. You must gingerly work it past this bend, until the Zip Tie bottoms out or you run out of usable Zip Tie.
5. While pulling it back out, rotate (twist) the Zip Tie. This will help dislodge any clogs. As you reach the inserted end of the Zip Tie, be prepared for some water to follow.
6. Reconnect the hose to the coupling and make sure that it has a downward slope and no kinks or significant beds. The water drainage relies entirely on gravity. Then turn plug the unit back in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level at 32 - 35%.
Hope this helped you solve the problem. Please let me know. Thanks.
Jun 20, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
I own a Whirlpool Dehumidifer Model Number AD 70USS1. I have a drain hose connected to the unit, however, recently the unit's internal collection bucket fills with water to the point that the...
superstee - You're having to empty it because either the drain hose you have connected to the unit is clogged or the drain hole a the hose connection is clogged. Therefor, the water is drained into the tank, rather than the drain hose. Also, the drain hose would not be any longer than 5' and must drain down, as the dehumidifier does not have a pump. It relies totally on gravity.
Remove the hose and check it for clogs. If clear check the drain hose connection, using an 18" long appropriately sized Zip Tie. Carefully insert the Zip Tie and continue to push it in until you reach the bend in the tubing. Gingerly work past this bend, until the Zip Tie bottoms out or you run out of usable Zip Tie. The while slowly pulling it out, rotate the Zip Tie. This will dislodge the clog. As you reach the end of the Zip Tie removal, be prepared for some water to follow. CAUTION: BEFORE DOING ANY OF THE ABOVE TURN THE MASTER ON/OFF SWITCH TO OFF AND UNPLUG THE UNIT.
The above should solve the problem for you. Please let me know. Thanks.
Jun 08, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Whirlpool DEHUMIDIFIER Model - AD70USS1 does fan NOT does not cycle off anymore in the low settings as it should
According to the Owner's Manual for your model, the fan will run continually, if the unit is set in continuous mode or if the unit is in defrost mode. Once the unit senses a rise in the humidity level, the compressor will start up again. Also, a dirty or clogged air filter will cause the fan to run more that it should.
Hope this helps you troubleshoot and solve the problem.
Jun 02, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
With this model is there a way to attach a hose to it so that I can leave it running continuously while the hose is draining into drainage hole in my basement? m7dh65b2a
Yes, there is a way to do it. As a matter of fact, your model (now discontinued) came with a short section of hose. However, you can still use a short 5' section of garden hose and achieve the same results. To find the hose connection (if you don't have your Owners Manual) remove the bucket and you should see what looks like a hose connection (which it is) behind where the bucket sits in the unit. If it is not there, inspect the back of the humidifier for a small 2"x 2" pop-out compartment door. Inside of that is the hose connection. Remember, dehumidifiers do not have pumps to pump the water out, they rely on gravity for water to flow through and out of the hose.
Hope this helped you. Please let me know. Thanks
May 08, 2011 | Maytag M7DH65B2A Dehumidifier
I have a Whirlpool Gold dehumidifier with the hose set up for direct water release into a sink drain. I assumed once you hooked up the manufacturer hose provided it would be a direct drain process and...
I have a similar Whirlpool dehumidifier and a similar problem. Have you tried setting it to continuous mode? My understanding was that it would only divert the drainage to a side hose when in the continuous mode.
Jul 20, 2010 | Dehumidifiers
Our Whirlpool gold dehumidifier is leaking water. We have checked the water reservoir and it is in correctly and continues to collect water. But, water is seaping onto our floor from the dehumidifier.
Do you use a hose with your dehumidifier? Could it be leaking? I have two machines in my basement. I use hoses on both. I had to do funny stuff to make the hoses not leak on the plastic 'blown' tanks. Even the cap that originally came with the machines were leaking before I started to use the hoses.
Check for holes in the tank as well.
Sep 27, 2009 | Dehumidifiers
Continuous drainage
Jul 27, 2009 | Haier HDN655E Dehumidifier
Brand New De-Humidifier not pulling water into bucket or hose !
I have lost my manuel. I do not know how to use the hose for when I go away for a few days.
Apr 28, 2009 | Whirlpool Gold AD70USS 70 Pint Per Day...
Dehumidifiers Logo
134 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike Squire
Mike
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
