Question about Panasonic ( N2QAKB000050) Remote Control
Panasonic dvd/tv n2qakb000050
The only button that works is the tv-power and the channel +- and volume +-
Nothing else. Can this be fixed?
  • 275 Answers
SOURCE: panasonic pv-v4021 VCR
Actually George, You should read the supplied Operations manual. In that you will find a chapter for using the Remote as a Universal remote, and a list of codes will be give. Check out the code for Misubishi TVs and feed that.
Posted on Mar 21, 2007
SOURCE: Panasonic PT-47WX53 does not turn on
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jun 03, 2008
SOURCE: Panasonic TH-50PX60U no buttons working
The software in the cpu of this set is damaged you must reload it to fix the problem..
Posted on Dec 18, 2008
dsacco86
  • 1077 Answers
SOURCE: Unable to reset Lamp Hour Meter on Panasonic PT-50LC14
Try this, using the Panasonic remote, wait until the notice about your lamp goes AWAY (it wont work with the message still up).
Hold the volume down on your tv while holding the split/play button on the remote.
You will get a notice about 4-5 seconds later that it was reset.
Posted on May 29, 2009
SOURCE: Have no volume on only one channel on Panasonic TH-42PX60U
Try the SAP - same thing happened to me and had to cycle through the audio tracks to get audio back on for that one channel. Good Luck!!!
Posted on Jun 16, 2009
Unit turns on and off but nothing else works
Simultaneously press the [CHANNEL UP] and [CHANNEL DOWN] buttons on the front of the DVD Recorder for approximately 10 - 15 seconds (until the unit powers off).
Disconnect the wall outlet. Wait for 10 minutes. Then power up.
It this still does not help....and If you are capable of taking the risk check out DMR-EZ47 Firmware Installation Instructions
Panasonic DMR EZ47 Installation Instructions Manual
Familiarize yourself with all the steps and especially the page 7,8 before you attempt this,
Mar 25, 2016 | Panasonic DMR-EZ47V DVD Recorder/VCR
My panasonic up/down channel buttons on the side of the tv wont work
Try getting a Harmony remote control. It will operate your tv and anything else you can connect to it. When the TV gets too old to fix, the remote can be reprogrammed for the new TV, so it never gets obsolete. The remote is programmed from their website.
Mar 20, 2014 | Panasonic Televison & Video
Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
Jun 06, 2009 | Panasonic TH-42PX60U Television
I'm looking for the manual for a Mitsubishi VCR HSU447 with the remote control RM75502 so I can program my TV to it. Thanks
1.- Turn off your TV
2.- On the remote control, set the VCR/TV slide switch to TV position.
3.- While holding in SP/EP button, press the code button listed below that corresponds to the brand of your TV
4.- Press TV POWER on the remote control. Once your TV has turned on, your remote is set up to operate your brand
TV.
Brand of TV Brand Code Button
Mitsubishi 1,2,3
Fisher 0
G.E. VOLUME UP
Goldstar 2,9
Hitachi 8
JVC MUTE
Magnavox 4
NEC 2,9
Panasonic CHANNEL UP, CHANNEL DOWN
Pioneer 6
Philips 4
Proscan VOLUME UP
Quasar CHANNEL DOWN
RCA VOLUME UP
Sanyo 0
Sharp 3,5
Sony VOLUME DOWN
Toshiba 7
Zenith INPUT
I finnaly found my VCR Manual, and I'm glad to share this info with you, because I was looking for the manual all
over the web and FOUND NOTHING!. Bye!
Mar 15, 2009 | Mitsubishi Televison & Video
None of the buttons on the TV will work...can't turn TV off
Hi you will need to reset your Tv & remote sounds like that children may have played with the remote reset should clear the problem.
Feb 19, 2009 | Funai MWC24T5 24 in. OLED Television
Son pressed something and now DVD won't work
well there could be two things going on here that i can think of, one the scart lead between the dvd and the tv is not i properly vica versa for the dvd player, the other thing is the button which changes the av channels could have been pushed so simply push the button while the dvd os on and find the av channel, the button looks like an arrow going right hope it helps.
Jul 04, 2008 | Panasonic Televison & Video
Sound won't work...
can you go to the input mode and change it?? try that and make sure everything is turn on ( dvd, cable box, sat box, etc.)
Apr 09, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Remote interacting with TV
According to my manual the codes for Samsung TVs are 31, 32 or 43.
Press and hold the TV on and off switch button.
Enter the two-digit code for your television set (while holding the TV power on the remote)
Nov 11, 2007 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Problem with remote
This fixes the *Set 1* problem. Set 1 means the remote cannot communicate with the Panasonic DVR. If the batteries go out on the remote replace the batteries stand in front of the Panasonic DVR, press and hold the "1" button and the *enter* button at the same time and hold for 10 seconds.
May 21, 2007 | Panasonic DMR-ES35VS
Televison & Video Logo
141 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
