Hello Mr. Expert I have a Whirlpool Cabrio High Efficiency Top-Loading Washing Machine (WTW6600SWO) and the problem that i;m having is it will not complete the wash cycle... I stops just before the spin cycle with 10 mins to go. and the "LD" code comes up. How do I resolve this issue? Plz help...
  • singingpr473 Jul 29, 2010
    no, i needed more information and it's hard getting a quick responses back
  • 10,319 Answers
If there is no blockage in the drain hose the pump and motor will need to be replaced
Some things to check...
When you try to pump out, any "pump-like" noises? What do you hear/see/smell? Remobe the pump from the motor (two clips) - can the pump be turned by hand using a flat blade screwdriver? These had a problem with the pumps seizing up when they first came out, I changed a lot of them under warranty.
I understand the pump is no longer a repair part, comes as a kit with the motor
Posted on Jul 28, 2010
  • 2 more comments
  • singingpr473 Jul 28, 2010
    all i hear is the normal draining sound. then it just a dry humming sound...not loud or anything...u spoke of a pump and motor, is that the same in one or two different things. So, I need to pull the washer out and check to see if there is any blockage? Not really clear on what im to do?
    what does pump out mean?
    was there a recall on this item? the pump/motor....do u have a picture of what it looks like. so i can know what im looking for?
    hello are u there
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
I have a whilrpool washer model WTW6600SWO. I have removed the drum and cleaned the shaft and now require some type of gear oil to re-install the drum
3in1 oil works just fine. That's all I use on service calls. Put a little of that 3in1 and your good to go.
Richard Roth
The FixYa Team
Aug 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My Whirlpool Cabrio top loading washing machine stops with an error OL . nothing wrong with the loading, this is only a small whash. Where is located this sensor for overload?
The sensing is done by measuring the motor amp draw. If the motor amp draw is high that is an indication of a heavy loaded washer which could cause the motor to overheat OR too much soap being used, OR the wrong soap being used, OR something between tubs. If you is getting an OL and the clothes is not the problem then you may have an item lodged between the tubs. You must remove the inner tub and get that thang outta there. Cabrio service manual
Rate it or hate it!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 30, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My cabrio washer has change that got under the tub how do i get it out what do i have to remove
Step by step instructions found HERE starting on page 4-9 on how to remove your basket.
It will take a minute to load the document.
Hope you get rich....:)
Mar 26, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio Whirlpool WTW6600SWO
you have a cabrio not a calypso..1st calypso did not display f1 codes BUT a cabrio does indicating bad control module.. changed 1 last week same issue..i'm sure if you go to sears .com click parts link type in your model number it will come up a cabrio..let me know how it turns out
Nov 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
