Question about Garden
What is the fuel mixture for a john deere 21c weed wacker echo smr-2100
4 Suggested Answers
panilling9
  • 284 Answers
SOURCE: How much oil to mix with gas for the 2100C John
3 oz. of 2 cycle oil to 1 gallon of fresh fuel
87 will work 89 octane prefered
Posted on May 28, 2010
Testimonial: "Thank you so much for the information on the gas to oil ratio."
wadembly
  • 513 Answers
SOURCE: Gas weed wacker will start, but won't hold significant power
if there 2cycle weed trimmers the high side needle valve should be one turn out from all the way in the low side should be about 3/4 of a turn out if it a 4cycle 1-1/2 turns try these it may help
Posted on Jun 06, 2009
  • 636 Answers
SOURCE: I have a john Deer XT140 weed trimer and I dont
Safe side 40:1
Posted on Jul 29, 2009
How to check fuel needle setting in Echo 2100 weed eater
Jack, Check the attached links for trimmer carb. tuning,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Tune Up an Echo Trimmer
http://www.echo-usa.com/getattachment/e8f287f6-0f5c-4f36-b0fa-ea8fa4a550b9/SRM2400241025012501S2510es_120194
echo srm 2100 weed eater
May 07, 2016 | Echo Garden
1330se it is brand new not getting fuel to motor will run on either
There may be a filter on the fuel pickup line inside the fuel tank that has clogged due to old fuel being left in the tank. Look inside the tank - it probably looks like rust - you need to change that. Any lawn mower repair shop should have a filter that works and could change it for you. Note - run the blower until it runs out of fuel before storage to avoid problems like this - same rule for lawnmowers, weed wackers, etc.
Jan 20, 2014 | John Deere Garden
Craftsman weed wacker will start and run
Are you sure you have the right fuel mixture? Many of these require 2 Cycle oil to be added to the gas. If fuel is right, you may have a vacuum leak at the carb (or crack in base where it mounts to the engine). My weedwacker needed to be run on half choke for about 10 min before it got hot enough to run with choke off.
Apr 29, 2012 | Craftsman Weed Wacker Lawn Edgers
I can't prime my carburator on my Echo GT200r weed wacker?
clean your fuel filter and then clean your carb and replace diaphram and needle and make sure hoses are good while you are at it, the methanol causes needle and diaphram to get stiff and gum up not letting fuel into carb when primed, replace your primer blb while at it
Sep 17, 2011 | ECHO, Inc. PB-251C Handheld Blower
How much oil to mix with gas for the 2100C John Deere weed wacker?
May 28, 2010 | Garden
Echo Weed Eater bogs down.
Echo carbs have a little black plastic plug covering the High speed adj screw..CA air pulotion control bs..So get that little black blug out and give the screw a little turn open and u should be good to go..It worked for me..on a PBL 251 blower..My Echo weed wacker has the carb also..Go to Echos site and download the parts break down for your unit and look at the carb page..You will see the plug and HS,screw..happing wacking and blowing
Jul 05, 2009 | ECHO, Inc. PB-251C Handheld Blower
Jun 06, 2009 | Garden
Garden Logo
472 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
