Question about Vizio VO47L 47 in. LCD TV
Black screen - Vizio VO47L 47 in. LCD TV
  • 12 Answers
What I found to be the problem on the particular unit I repaired, along with several other flat panels varying from Samsung Plasma, Toshiba LED, Pioneer LCD, to off-brand generic backlight LED wanna-be\'s, was that there weren\'t any actual defects on the parts, circuitry, or wiring but mostly I found the troubles to be located in or around the connector housings that link the power supply to various boards &/or lighting components. The majority of them were simply just corroded or \'gunked-up\' if you will, with dirt, dust, \'fried\' insect remains, and even Insect &/or rodent ..i know that\'s gross but most of the units i work on are from homes located in rural areas where during cool temperatures the electricity flowing through these connectors is an ideal place for insects to breed and colonize.
All that being said, the first thing to check is power, if power is good then unplug all connectors and check for any debris or discoloring of the pins which can be cleaned with a simple cotton swab or toothbrush with a dab of alcohol on it and then dried before power is re-applied. If the connectors all look new, shiny & clean then look into any connections containing pins and ensure that they are all aligned and straight up ensuring they fit in the female connector that plugs into them. If you run across bent pins they are most likely shorting on the frame or other pins when pressure is applied by attaching the connector. **AGAIN, IF THE PINS ARE BENT TAKE CAUTION IF YOU TRY AND STRAIGHTEN THEM BACK YOURSELF AS IST IS EASY TO DO MORE HARM THAN GOOD!* An easy way for an everyday non-electronics worker with no applicable tools to do this i have found is to use something like a little red nozzle straw you find on many aeresol cans of lubricant or compressed air. Make sure it hasn\'t been used of course, and simply place a pin into the small hole at one end of the plastic straw and lift it until the thing is straight up, or as close as possible. This method allows for you to not \'double-bend\' the pins as well as serving as and insulator against the other pins when straightening.
I hope some of this helps before you run out and spend $100\'s or tear up your unit by attempting repairs on parts that aren\'t broken.
Good Luck & TAKE CARE.
T7
Posted on Mar 28, 2013
  • 11,361 Answers
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Posted on Jul 29, 2010
Screen blank on x836 turns on screen blacksout help thanks
Black Screen, Working Phone [Solved] - Phones - Cell Phone General ...
www.tomsguide.com/forum/id.../black-screen-working-phone.html
Dec 14, 2015 - 12 posts - ‎10 authors
I turn my phone off and then turn it back on, same result, black screen. I then tookout the battery and put it back in, same result. I took the battery ...
Why is my screen black but everything else works ... - iFixit
https://www.ifixit.com/.../Why+is+my+screen+black+but+everythin...
iFixitThe Samsung Galaxy S3 is a multi-touch, slate-format smartphone with ... I have a problem with my phone i dropped it and it works but all i see is a black screen ! ... was fine but then a couple of mins. later the screen started turning pink and when I .... i dropped my gs3, the screen cracked & the screen stays black, everythimg ...
Phone stuck on a black screen during or after a call? Here's ...
www.smartmobilephonesolutions.com/.../cell-phone-shows-a-black-scree...
Is your phone showing a black screen after finishing a conversation and not allowing ... causes and better yet some solutions to fix this issue on your cell phone. ... phone up to your ear, so that the phone will lock (turns on the black screen), ...
Jan 04, 2016 | Cell Phones
Why does screen go black or white by itself?
There are 3 step to repair black screen error
If you got black screen error then there is a 94% chance that your computer has registry problems. To repair black screen error you need to follow the steps below:
* Step 1 - Download a black screen error repair tool,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair black screen error.
Here are the url of black screen error repair tool:http://www.FixError2010.com/ttfix-black_... Source(s): http://www.FixError2010.com/ttfix-black_...
Sep 22, 2015 | Computers & Internet
Its the problem with microsoft grenuine license file a black screen appears on thge desktop screen
video adapter problems are the most common cause of black screen in you desktop.And also registry problem in windows can give the black screen error.You can fix black screen error manually.
Jul 21, 2012 | Microsoft Windows XP Professional for PC
Why screen is black out.
On my Windows 7 laptop, I got problem of Black Screen of Death, Windows Boot Genius fix the problem without data loss! I vote it!
Jan 26, 2011 | Computers & Internet
A black rectangular black screen shows up but..... sony trinitron
Check the set up. You may have closed captioning turned on which will show up as a black box if there is no closed captioning information for the selected channel. If that fails to resolve the problem, update this.
Thanks,
Dan
Aug 07, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Vizio VO47L 47 in. LCD TV Logo
275 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
