Question about Garden
I have wacker plate with honda gx 160 engine ran perfect six months ago came to use the wacker and there is no spark?
  • dazsut1 Jul 28, 2010
    NEW FUEL IN. NO SPARK NOT SURE WHERE TO START AM MORE CAR MINDED THAN THESE LITTLE ENGINES LOL
  • dazsut1 Jul 29, 2010
    thanks have cleaned coil up and magnets
  • 12,061 Answers
Http://home.howstuffworks.com/home-improvement/repair/how-to-repair-small-engines.htm
http://www.m-and-d.com/helpfaq.html
http://www.nls.net/mp/volks/htm/spark.htm
Please find these websites above, helpful, the one above directly addresses your issue and the other two are just a helpful.
Check, all wiring, magneto, spark plug, lead, etc etc... above will sort you out.
Posted on Jul 29, 2010
  • 10,865 Answers
Hello. If your model has the auto oil level checker, that is most likely the culprit. I would cut the oil alert off and just check it like a normal engine. That auto oil checker has caused many people a problem. J.
Posted on Jul 28, 2010
  • 10,319 Answers
Check the fuel ine inside the fuel tank. sometimes they just disintergrate inside the tank if not drained for winter stowage.
    THANKS MATE TANK WAS EMPTY SO PUT NEW FUEL INBUT THEN DISCOVERED THAT THERE WAS NO SPARK? HAVE SEEN OTHER ON HERE THAT STATE COIL MAYBE DISFUNCT OR OIL SENSOR FAULTY?
5.5hp GX 160 only runs flat out wont idle
carburetor throttle plate stuck open or spring off/ stuck on governor assy.
Jun 16, 2014 | 5.5 HP GX160 Engine
04 crf450 wont stay running
Check both valves could be stuck
Mar 24, 2013 | 2004 Honda CRF 450 R
Where to connect the throttle cable on a GX 31 honda motor FG 100 tiller
I look up honda engines at : honda-engines-eu.com they have the best access to detailed information. If you can identify the carb butterfly, any cable should attach to the butterfly control. I see a Honda GX100, but not a GX31.
Oct 09, 2012 | Honda Horizontal OHV Engine 340cc, GX...
Honda GX 240 engine has spark, new carb; won't fire. what do I do?
remove the muffler and try it there is a screen inside the muffler that get carbon build up if it runs with out the muffler pry it open and clean it
May 24, 2012 | Garden
Honda 6500is wont start ran about 6 months ago drained fuel put new fuel in still wont start.
make sure you are getting fuel to carb, also check spark plug
Jun 12, 2011 | Garden
CRAFTSMAN WEEDWACKER 316-791860, WILL NOT START. HAS SPARK, FUEL LINES FILL UP, WAS RUNNING FINE, DIED, STARTED NEXT AM, RAN 5 MINS THEN DIED AND WOULDN'T RESTART
Two things which may be the problem: 1) carb need to be rebuilt or replaced, and 2) you need a new spark plug. The carb with shipping is around $50.00 from sears ( http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-3167918602008/0247/1503820/P0805032/00001?blt=06&prst=&shdMod= ) A sparkplug can be had at any small engine repair shop and most auto parts stores for less than $5.00 Start with the cheap solution... Also make certain you have fresh gas and that the oil mix is correct.
Apr 07, 2011 | Craftsman Convertible 25cc. Gas Line...
95 civic DX suddenly Died will not restart has gas, new distributer with coil and all internals Ecm to map sensor checked ok spark is fine new timing belt about six months ago did a compression test and...
I'd pull the timing belt cover and check the engine timing and belt condition. It could've slipped that badly if the camshaft pulley slipped past the pin. The thing that concerns me is not getting compression - it sounds like the top end is out of time with the crank - venting compression.
Dec 04, 2010 | 1995 Honda Civic
Honda GX 160 under 30 hrs from new, is running poorly
try removing the float bowl on the carburator and cleaning, sounds like needle valve is partially stopped up
Aug 02, 2010 | Honda Horizontal OHV Engine for Non Pumps ...
1993 Goldwing Aspencade With Slight Engine Miss??
could be a out sinked carb or gum from sitting gas won't last long
Feb 27, 2009 | 1993 Honda GL 1500 Aspencade Gold Wing
Honda 5.5 hp air comp. no spark wont run
Most honda engines have an oil sensor that prevents the engine from starting if the oil level is low or oil is dirty. Test coil by disconnecting oil sensor wire. With sensor disconnected coil should fire. If still no fire, check kill wire for short. If still no spark, coil may need to be replaced. enjoy
Nov 28, 2008 | Honda Quincy 17 - Gallon Air Compressor...
Garden Logo
222 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
