Question about Primavera Contractor 6.1 Full Version for PC
Unable to connect to the database. Would you like to configure the database connection now?
5 Suggested Answers
SOURCE: Chronos Soho Notes - Database
Hey I found the solution.
Reinstall Soho Notes but on the screen after accepting the license is a button marked cutstomize. Click on that and then make sure the database box is checked. Finish the installation and restart your machine. It worked for me
Posted on Mar 30, 2009
SOURCE: I just installed Primavera Project Management, and
What Operating System are you using? Are you using Windows 7? If you are using Windows 7, please make sure that you are launching the installation with Administrator Privileges. To do this, you can right click the installation file and click the "Run As Administrator".
Also, please check if you are able to login to Methodology Management directly.
If you are able to login, Please check these following entries in the registry:
  • HKey_Current_User/Software/Primavera/Databases/MM/CurrentAlias
  • HKEY_LOCAL_MACHINE\SOFTWARE\Primavera\Databases\MM\Aliases
Check if there are discrepancies on the data in these locations and correct them if necessary.
If you are not even able to login to Methodology management directly, uninstall the application and reinstall it with Administrator Privileges and configure the database properly.
Hope this helps.
Posted on Sep 20, 2011
intower18
  • 957 Answers
We just have to go to basic first, you might want to uninstall it first then restart your PC or laptop, then reinstall it. Then let let me know if it works or not.
Posted on Sep 23, 2011
SOURCE: can't configure the database connection for Primavera p6
i just installed Primavera Project Management , and Methodology management. After logging in with the default username of admin and password of admin it comes back with the message " Unable to connect to the database. Would you like to configure the database connection now?" How do I get around this challenge? iam using vista
Posted on Oct 16, 2012
Unable Connect To Database
Need more detail in order to help you. Let's start with:
Is this a home or office PC (or Mac, or Linux machine)?
Is the database stored on your machine, or are you connecting to a database server?
What type of database (Oracle, MS Access, Sybase, etc.)?
What type of client / business software are you trying to use to connect to this database?
With that, I may be of some assistance.
Oct 18, 2013 | Computers & Internet
I just installed Primavera Project Management , and Methodology management. After logging in with the default username of admin and password of admin it comes back with the message " Unable to connect
You must connect to a database to utilize Primavera. You can not bypass this portion. So, Either remove the Database and reconfigure, or in the "Configure" Screen you can Name a new DB and use it. I would suggest that if you do not require 2 DB's not to have two. "The Oracle Database 10g" application that is installed with P6 (In your 'All Programs') will give you some DB manipulation options. Other wise refer to the TenSix link to clarify DB Config
http://www.tensixconsulting.com/2013/03/primavera-p6-database-connection-configuration-details/
Feb 13, 2013 | Primavera Contractor 6.1 Full Version for...
Can't configure the database connection for Primavera p6
Feb 05, 2010 | Primavera Contractor 6.1 Full Version for...
Syncing client with server - Restaurant Pro Express
Your getting a connection successful because your looking at the localhost. The server would be the network name of your server. And the password is case sensitive and is pcAmer1ca. (Note the number 1, not an i)
Jan 29, 2010 | Pc America Restaurant Pro Express
Mar 25, 2009 | Computers & Internet
How to configure the sql server 2005
Enable remote connections for SQL Server 2005 Express or SQL Server 2005 Developer Edition loadTOCNode(2, 'moreinformation'); You must enable remote connections for each instance of SQL Server 2005 that you want to connect to from a remote computer. To do this, follow these steps:
  1. Click Start, point to Programs, point to Microsoft SQL Server 2005, point to Configuration Tools, and then click SQL Server Surface Area Configuration.
  2. On the SQL Server 2005 Surface Area Configuration page, click Surface Area Configuration for Services and Connections.
  3. On the Surface Area Configuration for Services and Connections page, expand Database Engine, click Remote Connections, click Local and remote connections, click the appropriate protocol to enable for your environment, and then click Apply.
    Note Click OK when you receive the following message:Changes to Connection Settings will not take effect until you restart the Database Engine service.
  4. On the Surface Area Configuration for Services and Connections page, expand Database Engine, click Service, click Stop, wait until the MSSQLSERVER service stops, and then click Start to restart the MSSQLSERVER service.
Feb 28, 2009 | Microsoft Visual Studio 2005 Professional...
How to write jdbc connections
http://www.jdbc-tutorial.com/
window.google_render_ad();
welcome_title_image.gif Java JDBC Tutorial Java JDBC Tutorial
The JDBC ( Java Database Connectivity) API defines interfaces and classes for writing database applications in Java by making database connections. Using JDBC you can send SQL, PL/SQL statements to almost any relational database. JDBC is a Java API for executing SQL statements and supports basic SQL functionality. It provides RDBMS access by allowing you to embed SQL inside Java code. Because Java can run on a thin client, applets embedded in Web pages can contain downloadable JDBC code to enable remote database access. You will learn how to create a table, insert values into it, query the table, retrieve results, and update the table with the help of a JDBC Program example.
Although JDBC was designed specifically to provide a Java interface to relational databases, you may find that you need to write Java code to access non-relational databases as well.
JDBC Architecture jdbc.jpg Java application calls the JDBC library. JDBC loads a driver which talks to the database. We can change database engines without changing database code.
JDBC Basics - Java Database Connectivity Steps Before you can create a java jdbc connection to the database, you must first import the
java.sql package.
import java.sql.*; The star ( * ) indicates that all of the classes in the package java.sql are to be imported.
1. Loading a database driver,
In this step of the jdbc connection process, we load the driver class by calling Class.forName() with the Driver class name as an argument. Once loaded, the Driver class creates an instance of itself. A client can connect to Database Server through JDBC Driver. Since most of the Database servers support ODBC driver therefore JDBC-ODBC Bridge driver is commonly used.
The return type of the Class.forName (String ClassName) method is “Class”. Class is a class in
java.lang package.
try { Class.forName(”sun.jdbc.odbc.JdbcOdbcDriver”); //Or any other driver } catch(Exception x){ System.out.println( “Unable to load the driver class!” ); } 2. Creating a oracle jdbc Connection
The JDBC DriverManager class defines objects which can connect Java applications to a JDBC driver. DriverManager is considered the backbone of JDBC architecture. DriverManager class manages the JDBC drivers that are installed on the system. Its getConnection() method is used to establish a connection to a database. It uses a username, password, and a jdbc url to establish a connection to the database and returns a connection object. A jdbc Connection represents a session/connection with a specific database. Within the context of a Connection, SQL, PL/SQL statements are executed and results are returned. An application can have one or more connections with a single database, or it can have many connections with different databases. A Connection object provides metadata i.e. information about the database, tables, and fields. It also contains methods to deal with transactions.
JDBC URL Syntax:: jdbc: <subprotocol>: <subname> JDBC URL Example:: jdbc: <subprotocol>: <subname>•Each driver
Feb 01, 2009 | Microsoft Windows XP Home Edition
Sansa e200 shows refresh database fail
try putting it in MSC mode and formating it and then putting back on MTP mode. Hope that works
Aug 24, 2008 | SanDisk Sansa e250 MP3 Player
MSSQL Related Problems
Please see link below http://www.php.net/function.mssql-connect
Basic tutorial in connection PHP Language to MS SQL Server.
Please rate me SOLVED.
Nov 22, 2007 | Microsoft SQL Server Standard Edition for...
Primavera Contractor 6.1 Full Version for PC  Logo
1,126 people viewed this question
Top Primavera Computers & Internet Experts
Tom Chichester
john smith
Marvin
Marvin
Are you a Primavera Computer and Internet Expert? Answer questions, earn points and help others
