Question about Whirlpool Dryers
Have Whirlpool Model # LGB6200PQO dryer runs but does nut dry. Burner kicks on with fire on gas dryer but after about 5 min kicks off after a few minutes the igniter glows on but no fire then kicks off then a few minutes later does it again. Replaced thermal fuse but no change. What do you think it might be?
  • 10,319 Answers
The moister sensor can be bad or good. If the exhaust tubes are clogged with any lint build upo the sensor is working putting the burner into check
Posted on Jul 28, 2010
Whirlpool Carbrio dryer buzzing noise while running. Works OK just keeps buzzing off and on while drying. Not a grinding sound.
OK, remove the 2 screws on the front lower kick plate. Run the dryer to see if the buzzing is coming from the motor or from the burner area. Post back your results.
Nov 09, 2012 | Whirlpool WGD5600XW Cabrio 27" Front-Load...
I can hear ignter kick in at first dries for a few min. then goes cold no heat.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 09, 2010 | Whirlpool WED5520SQ Gas Dryer
Starts drying for about 15 mins then stops
Sounds like this is a gas dryer. Look at your burner after the dryer stops heating .Does the ignitor come on then go off without the burner firing?If so replace the 2 coils on top of gas valve wp #279834 msrp $20.00. Please rate my solution :)
Nov 14, 2009 | Dryers
Whirlpool gas dryer GGQ9858JQD runs fine not drying
Check the inlet and exit venting around the burner for lint or other obstruction.
Aug 23, 2009 | Whirlpool LGV4634JQ Gas Dryer
Dryer only heats when empty
Replace the 2 coils on the burner valve . Without model number , cant give you part number .
Jul 28, 2009 | Whirlpool LGR5636L Gas Dryer
Maytag mdg6700aww gas dryer runs but heat kicks out after 5 min
You have bad coils on your main gas valve . They tend to short (open) after getting warm which cuts off the gas to the burner . After cooling , they will work again for another 5 min until shorting again . Replace the coils (2 in a kit ).
Jul 12, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Thin twin stacked washer/dryer...dryer won't stay on
My twin stacking whirlpool washer/dry. The timer switch kicks on but does not dry clothes kicks off after 5 mins but, clothes still wet.
Nov 12, 2008 | Whirlpool LTE5243D Top Load Stacked...
Heating up..clothes not getting dry just warm and damp
the valve coils??? ifyour burner is firing ,the heat cycle is good, but yes it is possible that the coilsheat up after being on for 20-30 min adn then willl stop opening the valve thus no dry..
279834 set of valve coils, unplug the unit and remove the 2 philips screws holding down the set on the valve, easy repair, cost you about 20 bucks for the set.
UNPLUG UNIT BEFORE SERVICING
Apr 03, 2008 | Whirlpool GGW9200L Gas Dryer
Dryers Logo
78 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
