Question about Garden
My 1 year old gas powered Husky model HU80432 starts and runs fine but gets no pressure from the wand. Water is running freely through all connections and hoses so there are no obstructions, just no pressure, the water just shoots out in a thin stream for about 3 feet. I stored it inside for the winter so there were no freezing issues. What's wrong?
  • 21 Answers
Lime/calcium build up in the pump.
Pour a large amount of liquid TSP into the fresh water inlet and let it sit for two or three days, the longer the better.
This is how I fixed my no pressure problem.
Works great now
Posted on Aug 29, 2010
Husky 1800 Pressure Washer motor will not turn off when wand trigger is released
I think you have one of two things going on hear, an overpressure problem or a carburetor issue with the engine.
Jul 25, 2017 | Husky Garden
No pressure on my husky power washer 1650
Basic Issues As an electric-powered washer, a circuit overload may cause your Husky 1600 to shut down or prevent it from starting. In this case, check your home's electrical service panel for a tripped breaker or a blown fuse -- the 1600 requires a dedicated circuit rated at a minimum of 15 amps. To prevent a blown fuse, avoid using other large devices on the same circuit as your washer. If you use an extension cord, it must be rated at 15 amps as well. Before moving on to more complex troubleshooting measures, check the gun safety trigger and release the lock if your 1600's trigger will not move. Water Woes Releasing air from the pump serves as a simple fix for low-pressure water output; remove the wand and allow the washer to run as you depress the gun's trigger until the water output normalizes. If your water output seems to lack detergent, ensure that the clear tube is securely connected to the detergent nozzle. Likewise, check the connected water supply and make sure the faucet is fully open and that there are no kinks in the hose to ensure optimal pressure. Using a shorter garden hose makes for stronger pressure, as well -- Husky recommends a hose with a maximum length of 50 feet for a city water supply. Clearing Clogs If your Husky 1600's pressure seems lacking or its water flow is obstructed, clean the nozzle by removing the wand from the gun, clearing the nozzle hole of obstructions with a stiff wire and flushing the nozzle with clean water. Similarly, clean the washer's inner water screen, located behind the garden hose connector, by removing the screen and flushing it with water. This also corrects low or irregular pressure and may remedy a unit that does not stop releasing water when the trigger is released. Model HD1600 features a chemical solution reservoir with a similar screen; clean this screen in the same fashion if you experience chemical intake issues. More to Consider If your power washer issues go beyond troubleshooting basics, contact Husky's customer service department at 800-381-0999. Husky recommends contacting customer service when your 1600 has problems with its pump, bypass valve, discharge valve or manifold assembly, for instance. Because this series of powerwashers was originally offered around 2001 through 2008, Husky's one-year limited warranty no longer covers the cost of replacement parts or repairs.
Sponsored Links
Sep 29, 2016 | Garden
Will start and run fine water comes out but has no pressure
Maybe bad pump. Remove wand and wand hose, run machine with water in. High pressure water coming out of wand/hose connection, bad wand or hose. No high pressure water, bad pump, replace.
Apr 01, 2016 | Simpson PS2600 PowerShot Commercial-Duty...
Briggs and Stratton pressure washer will not start. I have a 6.75 hp pressure washer that is only a year old. when I pull cord it turns over but does not start. I changed plug and checked it, I have spark...
hello dave, the problem is compression to low,you need 60 to 130 lbs to run engine,check for blown head gasket,or bad rings,or a stuck open valve,hope this helps,,
Feb 22, 2012 | Briggs & Stratton Garden
I bought my new husky/ honda gcv190 about a month ago, i haven't even started it yet. I didn't realize that the owners manual was for a totally different power washer. I don't want to bid on one,buy one or...
http://www.apwdistributing.com/
You should be able to download a pdf version of the owners manual here.. you will need your model number.
Model number HU80432 uses the Honda GV190 Motor
Best of luck!
Apr 12, 2011 | Garden
Low pressure from wand
where do i get a washer for the wand?
May 21, 2010 | Simpson PS2600 PowerShot Commercial-Duty...
Owner's manual for Husky #HU80432 pressure washer
If you can't find it under Tech Support, Manuals & Guides on this site you could go to: http://huskypowerwasher.com/manuals_specs.php
You can also call Husky at: 1-888-550-1606 from 8:00 AM to 4:30 PM Central time.
I hope this helps.
Mar 28, 2010 | Garden
Husky Air Compressor has rattlling noise!
buddy im an engineer on these machines for 30 years and when this problem has occured believe it or not but it cheaper to buy another pump unit or compressor plus its the hardest job getting the crank out so your choice bud
Nov 16, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
We are able to start it but not able to get the water to circulate and come thru the wand. This is a portable power washer and only about 4 years old and used very little. When we started it this last time...
replace the plug. remove the wand and force water back through it to unplug it and the hose.
if you have a water filter on that machine i suggest cleaning it out.
Nov 15, 2009 | Garden
Garden Logo
365 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
