Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
Canon Ixus v2
My digital camera only works sporadically, the screen is dark and i cannot see the 'image'. occassionally if i return it to factory settings, it functions normally for awhile but eventually the screen goes dark again but flickers as though light is attempting to get in. At the moment not even restoring the factory settings is working. I can see past images/photos clearly though, it's as though there is not enough light getting in Or something is broken?.
  • JosieMack Apr 24, 2008
    Thankyou so much! I have just looked up the Australian Canon website and it says the same thing as the link to camerarepair.blogspot, so i will be calling them tommorrow and hopefully getting it repaired, thanks again.
    Josie
  • JosieMack May 08, 2008
    Just wanted to let you know that i sent the camera off to Canon to get fixed. Have just right now, received a package at my door. opened it up and they've sent me a brand new camera. Thank you thank you thank you
  • Canon Master
  • 4,738 Answers
Do you own an SD400, or is it really an S400? The symptoms you're describing sound like a defective CCD imager. If your camera is an S400, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Apr 24, 2008
Screen is dark purplish when I turn it on
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Sep 27, 2009 | Canon PowerShot A75 Digital Camera
On power up the view screen is dark with a few vertical coloured lines. will take a photo but the result is just a dark screen. Old photos on the camera can be viewed normally. Menu and all other functions...
Aug 01, 2009 | Canon IXUS V2 Digital Camera
When I turn on the Canon Ixus V2, the screen is black. There is all the usual display information, so I know the screen isn't broken, but there is no picture. This is the second camera of the same model...
Oh, and hope you still have that other camera with the same problem. They'll fix that too for free!
Jul 29, 2009 | Canon IXUS V2 Digital Camera
Dark fuzzy/flickering screen - Cannon PowerShot A75
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
Jan 25, 2009 | Canon PowerShot A75 Digital Camera
Dark Screen on Canon A70
May 04, 2008 | Canon PowerShot A70 Digital Camera
LCD screen is black
Apr 18, 2008 | Canon PowerShot A310 Digital Camera
No live display on LCD screen
Mar 25, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
No picture on view screen of my ixus 400 cannon
Jan 09, 2008 | Canon PowerShot S230 / IXUS 179 Digital...
Photo screen problems
This definitely sounds like a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
Dec 09, 2007 | Canon PowerShot S1 IS Digital Camera
CANON FAULTY SCREEN IMPORTANT READ ME
Only for the brave, on a warrenty expired camera.
Buy a set of jeweller's screwdrivers.
Make sure it is off, with the lens retracted, and remove the battery and SD card.
Remove the 11 screws holding it together
The metal shell is in two halves that can be pulled apart. The rubber socket cover flap has to be removed once one half is off. A rubber gasket round the eypiece lens may drop off - it is easily replaced.
Hold the inner chassis by the edges.
The lcd screen is held by one screw, half hidden under the wiring to the flash - remove it.
Push the wiring to one side just sufficiently to enable you to hinge the lcd screen up on its flexible printed circuit wiring loom.
Underneath you will see the back of the ccd pod, with a flexibe printed circuit wiring loom pinioned under a metal plate with two Y shaped holes filled with brown gunk, and held down by a torex screw locked with some holt melt adhesive, and two further screws inaccessible under the metal chassis to the right.
I hypothesised these were the contacts that become detatched in hot conditions, and (1) tried to shift the flexible printed circuit minutely from side to side using the hole in it (it didn't move appreciably)and (2) pressed down quite hard in the centre of the metal plate, having supported the chassis from below so as not to damage the lens.
I reassembled the whole thing and it worked immediately, with just a faint light smear down the left hand side of the image (the whole image had been completely smeared, then dark, before) which was only noticeable when photographing in dark conditions.
So I took a gamble and it seems to have worked. If it hadn't I was going to break the glue seal on the Torex screw and unscrew and then screw it up again.
Obviously doing this is on your own responsibility.
Oct 02, 2007 | Canon PowerShot SD100 / IXUS II Digital...
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
60 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
