Question about Philips Magnavox MWC20T6 TV
Magnavox MWC20T6 Powers self off after 10 seconds
I have a Magnavox MWC20T6 TV. When i power it on, it turns off by itself after 10 seconds. It doesn't matter what settings it is on, or whether is it on TV, DVD, or VHS. I am a professional computer and network repair technician, so i'm not afraid to do the work myself. Does anyone know what the problem is and how i would go about fixing it?
Thanks
rey jr
  • 149 Answers
SOURCE: philips magnavox model 25ts54 c122.
hi there, you do have a power supply section problem, check the bleeder resistor which is 100K ohms or up. do some test. ty
Posted on Dec 26, 2007
SOURCE: My TV shutting itself down
My TV is shutting off after you turn it on.Model #27MT5005D.
The light continue to blink, but thats it.
Posted on Feb 12, 2008
  • 75 Answers
SOURCE: Magnavox TV combo with Dvd & VHS will not stay on.
Frist of all the tv is made by Funai the next thing is it is very hard to get parts from Funai at least it has been for me they tell me anywhere from 2 months to a year on parts. Now if the set is trying to load a tape without a tape being put in then shuting off you have a bad diode on the main board.Part is marked (D1224 on main board which it is called (LED) the Funai part number is (QPQS1R563ST) Need to replace this LED per Funai tec i have done this on a few of these models this problem stands true for 20 inch 24 inch and probley any others that are made by Funai that would have this kind of problem. The led that im talking about is under the VCR chasie in the center of the board and is clear glass looking. It has to be put inone way for it to work you have to unsolder it from the board. If you are not able to do this then it would need to go to a repair shop to be done. The shop may or may not know what is wrong so you could tell them, let them know that this is per Funai tec fix for this problem also give them the part number and hope that it does not upset them some shops would be ok with it and others would not.
Posted on Mar 08, 2009
  • 6 Answers
SOURCE: Philips Magnavox 27MS3404/17 27" TV
This is most likely the reset control on the back of the TV. When power is turned on it goes through the reset button and then to the TV. As it weakens over time, it can create the problem you have. See if the web site manufacture will sell you that part, or take it to a TV tech. for replacement, about $10 for the part not including the labor to take the back off and replace the part.
Posted on Apr 11, 2009
rulds2008
  • 3866 Answers
SOURCE: Turns off on its own after a few second clicks on and off for about 5 sec. until it turns itself off but the power light is still on
This is point to a fly back issue and a flyback fr this would run you $95 plus labor good luck with your TV
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 23, 2009
How to resize picture on a magnavox mwc20t6
Look for a setting called Aspect Ratio. It will include options like 4:3, 16:9, Zoom 1, and Zoom 2. Then click through the options to select the correct one for your program. Usually older SD programs will use either 4:3 or Zoom 1, while HD programs will be set to 16x9 for Widescreen hi-def viewing. There should be a button on your remote labelled Aspect Ratio or Picture that can toggle through these image modes.
Nov 26, 2014 | Philips Magnavox MWC20T6 TV
Magnavox mwc20t6 doesn't turn on
Hi
If you have a friend that is keen on electronics, your tv set may be open and checked for a blown fuse, as a firt step of troubleshooting. This is applicable when no light in the front panel is on or blinking. If this do not work or the fuse blows again, there is a short circuit or a bad component that need to be replaced. But this task require another approach.
Please follow the instructions on dealing with high voltage parts of the tv set.
I shall be glad if this is helpful.
Sully
Sep 22, 2013 | Philips Magnavox MWC20T6 TV
May 23, 2009 | Philips Magnavox MS3652S 36" TV
Magnavox 20-inch TV MWC20T6 must have vhs tape in. Knocking.
I think its your electrisity cause if both of them dont work
Jan 15, 2009 | Microsoft Xbox 360 Console
My magnavox model mwc20t6 keeps turning off after 10 to 20 secs
tv was working fine however when we moved it to another room it will not power on at all even using different plug ins
Nov 22, 2008 | Philips Magnavox 20MC4304 20 in....
Magnavox Model # MWC20T6
Manual will not help - if you unplugged it all night, and it will still not power up, try one more outlet in the house. If it still will not help, then you need to replace the power supply for the TV. Sorry.
Jun 14, 2008 | Philips Magnavox 20MC4304 20 in....
Wont say On
This TV needs to be taken to a service center, its problem is internal and needs a qualified technician service center to make the simple repair.
May 15, 2008 | Philips Magnavox 27MS343S 27" TV
36 magnavox tv shuts off by itself
MAGNAVOX TV ONLY. 5-10 SECONDS AFTER TURN ON AUTO TURNS OFF-NO LIGHT STAYS ON-I AM FRUSTRATED BUT IT SEEMS LIKE THE OFF ON SWITCH JUST CLICKS BACK TO OFF-ALSO DOES SAME THING BY REMOTE
Jan 16, 2008 | Philips Magnavox MS3652S 36" TV
Philips magnavox model 25ts54 c122.
Dec 24, 2007 | Philips Magnavox 27MS343S 27" TV
Powers on but turns it self off after 15 seconds.
CHECK FLYBACK TRANSFORMER LEADS FOR BAD SOLDER JOINTS, HAVE REPAIRED SEVERAL WITH SAME PROBLEM.
Dec 02, 2007 | Samsung TXN3071WHF 30" TV
Philips Magnavox MWC20T6 TV Logo
88 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
