My color HP 4730MFP printer won't do anything. First the ready light flashes, then the Data light flashes and then the Attention light flashes. It continues to cycle between the 3 lights. I've turned it off and back on with no resolution.
  • 52 Answers
Takes several minutes to come up and ready
Posted on Jul 29, 2010
2 Suggested Answers
Salim Baig
  • 283 Answers
SOURCE: My color HP 4730MFP printer
Hi
This will happen only if your storage has a problem.
Normally the HDD in the printer or the Memory DIMM. Try to replace the HDD first.
Posted on Jul 21, 2011
Printer 5550 laser color cood 59.c0
I am assuming you meant HP Color LaserJet 5550 Error Code 59.c0
Description
A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly.
Action
  1. Press the green (Select) button to continue.
  2. Turn the printer off, and then turn the printer on.
  3. If the error message returns, turn the printer off.
  4. Perform a cold reset.
    1. Turn the printer on.
    2. Watch the control panel.
    3. When the memory starts counting, press and hold the green (Select) button.
    4. Continue holding the green (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
    6. Press (Down Arrow) button once. The control panel will display COLD RESET.
    7. Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
  5. If this message persists, contact an HP-authorized service or support provider.
Sep 06, 2016 | Laser Office Equipment & Supplies
How do i fix a 59.C0 error on my printer?
  1. Turn the printer off, and then turn the printer on.
  2. If the error message returns, turn the printer off.
  3. Perform a cold reset.
    7. Press (Select). The printer will perform a cold reset and then continue its power-on sequence. NOTE: If this message persists, you will need to contact an HP-authorized support provider.
Sep 15, 2015 | HP Color LaserJet CM2320nf MFP Refurbished
HP Color Laserjet CM4730 Scanner Not Initializing
I had an issue similar to this and it was fixed by replacing the memory dimm on the bottom of the formatter.
Nov 17, 2011 | HP LaserJet 4730 MFP Printer
Error Code 51.2 C on an HP 4600
This is a laser error. I found this directly from HP's website. Here's your fix:
  • Press the green c00224695.jpg (Select) button to continue.
  • Turn the printer off, and turn it on again.
  • Perform a cold reset.
    1. Turn on the printer.
    3. When the memory starts counting, press and hold the c00224695.jpg (Select) button.
    4. Continue holding the c00224695.jpg (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the c00224695.jpg (Select) button when the Ready, Data, and Attention light are on steady.
    6. The control panel will display SELECT LANGUAGE .
    7. Press c00224697.jpg (Down Arrow) button once. The control panel will display COLD RESET .
    8. Press c00224695.jpg (Select). The printer will perform a cold reset and then continue its power-on sequence.
  • If this message persists, contact an HP-authorized service or support provider. Please let me know if this helps you!
  • Oct 01, 2011 | HP LaserJet 4600 Printer
    51.2m error
    This is a problem with the magenta cartridge in your printer. According to hp's website, you can try the following to fix it:
    2. Turn the printer off, and turn it on again.
      5. Release the (Select) button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
    4. If this message persists, contact an HP-authorized service or support provider.
    Hope this helps
    Please rate this solution, thanks!
    Mar 09, 2011 | HP Color LaserJet 5500 Printer
    Error 51.2 y hp color laserjet 4600
    Hi There, Please follow the below steps to fix this issue :
    Action : 1. Press the green (Select) button to continue. 2. Turn the printer off, and turn it on again.
    3. Perform a cold reset : a.Turn on the printer. b.Watch the control panel. c.When the memory starts counting, press and hold the (Select) button. d.Continue holding the (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady. e.Release the (Select) button when the Ready, Data, and Attention light are on steady. f.The control panel will display SELECT LANGUAGE . g.Press (Down Arrow) button once. The control panel will display COLD RESET . h. Press (Select). The printer will perform a cold reset and then continue its power-on sequence. 4. If this message persists, contact an HP-authorized service or support provider.
    Nov 08, 2010 | HP LaserJet 4600dn Color Printer
    No poweraftereplaced the adf scanner in hp color laserjet 4730mfp
    Make sure you reconnected all of the cables when you replaced the scanner. Unplug and reseat the connectors -- maybe one of them is not seated all the way in.
    May 27, 2010 | HP LaserJet 4730mfp All-In-One Printer
    A 51.2 error message means that there is an error 51(Printer Error).2 (Laser Error) C (Cyan). This basically means that there is something wrong with the laser and the cyan color laser.
    Reference via HP Website, Click Here
    To Fix the problem:
    1. Press the green c00224695.jpg (Select) button to continue.
    Mar 21, 2009 | HP LaserJet 4600 Printer
    Keep getting 10.00.03 supplies error, have tried turning the machine off and on several times.
    10.00.03 - The printer cannot read or write to the yellow print cartridge memory tag.
    Solution:
    Turn the printer off and then back on again.
    If error returns, remove all print cartridges and turn off the printer.
    Cold reset the printer:
    Continue holding the green check button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    Wait for the printer prompt to install each print cartridge.
    This should return the machine to operating condition. If you still get the error, replace the yellow print cartridge.
    Jan 15, 2009 | HP LaserJet 4600dn Color Printer
    301 people viewed this question
    jasbo
    jasbo
