Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
Lawn Mower will not stay running then will not restart
Lawn Mower runs for a while then will not restart. I have changed the plug, air filter, replaced a gasket and 'o' ring. Cleaned the fuel line. Each time I do something it may work for a short time then quit. It is a tecumseh pull start mower. It is frustrating.
    New Friend:
    Problem Solver:
  • 12 Answers
First, you need to determine why it is not starting. If it is fuel related, or spark related. Many times a coil will stop working after it gets hot. When it does not start, pull the spark plug out, keep it connected to the coil, and touch the metal part of the plug to the frame of the mower. ( metal part only), Make sure you are not part of the circuit. Usually, a good place is on the head of the mower. Pull the start cord and see if there is a bright blue spark at the gap. If there is you are good for spark, if not, look towards a fuel issue.
Posted on Jul 14, 2014
    Master:
  • 969 Answers
Make sure oil is full. If not changed this year. Drain and change with 30wt oil. 16-18 oz. Always check stick level for full. Do not over fill.Air filter and plug changed this year?
Posted on Jun 12, 2014
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 12 Answers
I think we all understand the frustation penaone.
I noticed u didn't clean the fuel tank, water, dirt, and rust in it can give u problems. But u need to clean the lines and carb. again also. One of the kids filled my mower gas tank with driveway gravel once, and after I cleaned things out, the mower never run so good. Also your spark may be grounding out somewhere before it gets to the spark plug. Check for a bad spot in the wires from the magneto. Some of that may be behind the flywheel though.
ballping
Posted on Jul 29, 2010
Wrong gas in lawn mower, what to do
if its a briggs and stratton engine with the plastic carb fixed to top of the fuel tank then you will need to replace the diaphragm and blow out the fuel pick up pipe
Jun 26, 2014 | Briggs & Stratton Briggs Stratton...
Won t stay running
could be a bad coil
Oct 15, 2013 | Craftsman Garden
Toro lawn mower troubleshooting
Clean the carb, gas tank and fuel line (s). Replace air filter with a new one, I wouldn't recommend that you run it without the filter because that allows dirt and grass debri to enter the carb, fuel line and gas tank.
Replace the plug with a new one that is recommended for your engine.
Check oil level.
Other option is lawn mower repair shop....
Hope this helps, I had the same problem.
May 11, 2013 | Garden
"Poulan" Push Mower: the mower will start but not stay running...
Have you checked the spark plug to see if it is fouled? If thats not it, maybe the air filter is clogged. If that still isnt the case try some B-12 small engines carb cleaner. Use it generously.
May 17, 2010 | Poulan "Poulan" Push Mower
The mower starts, buts runs sluggishly, and dies
Most common is a dirty air filter, followed by a plugged vent hole in the filler cap on the gas tank. Next would be fuel issues either in the supply line or in the carburetor.
Hope this helps, --W/D--
Jul 19, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
My lawn mower will not stay started
Since it starts, it doesn't sound like an electrical problem, it sounds like it runs out of air. To test this, remove the air filter, start it and see if it stays running. If so, replace the air filter.
It could also be varnish or sludge in the carb bowl. This is best serviced by a technician if you have little mechanical prowess.
After sitting for 3 years, I would at minimum do all of this before I expected it to run ok:
  1. Change the oil.
  2. Replace the air filter.
  3. Drain the fuel tank by removing the fuel line from the engine end (not the tank end).
  4. Replace the spark plug.
If the above did not work I would drop the carb bowl and clean it, then add one ounce of carb cleaner to a full tank, and let it run (roughly if necessary) through the engine.
After sitting 3 years I would also replace the fuel line itself!
Mar 29, 2009 | Garden
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
647 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
