Question about Gateway GM5084 PC Desktop
Gateway wont load,monitor wont come on
Gateway won't load,monitor wont come on
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 196 Answers
Check ur cable connections from the monitor to the computer and from the monitor to the wall outlet
Posted on Jul 28, 2010
I have a gateway dx4870 running Windows 10. When I turn it on my monitor stays black. I plugged the monitor into my roku box and the picture was fine. Do I need a new graphics card?
possibly not
but you might need the driver for the monitor to be made compatible with win 10
go to the monitor web page , select down load for your model and select win 10 os then down load and run
you can do all of that where the scree is working and download to a usb stick then install that in the computer that you want the monitor on
Jul 25, 2018 | Gateway Computers & Internet
FIND SOFTWARE FOR GATEWAY FPD2485W TFT LCD Monitor
That model should be plug and play with windows, no disk should be needed. Just plug the monitor in and turn on the PC, it should show "New hardware detected" and load right up.
May 07, 2012 | Gateway Computers & Internet
When i turn my computer on my momitor wont come on without my help i have to push the button on side of monitor6 time then it comes on
Are you giving the computer time to begin sending a signal to the monitor. Some computers send a brief low resolution signal during BIOS load, then put the video back into sleep mode while loading the operating system. The video drivers are usually loaded fairly late in the boot/OS load cycle. You may just not be waiting long enough.
Jul 04, 2011 | Gateway (G-MAX2000) Computer Speakers
My monitor wont turn on on my gateway
Check for bent pins on connector. Also may have exceeded the resolution, check for resolution on another monitor. This will verify if the non-working monitor needs service.
-AAT
Feb 21, 2011 | Gateway Media Center 610XL (610XLMDIA) PC...
When I turn on my netbook, the screen stays black. Nothing appears.
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD need to replace.
Aug 21, 2010 | Gateway LT2030u Netbook
Gateway FPD 1975W LCD monitor,on light blinking, but wont turn on
I will assume you have already try this monitor with other PC? You should also set the PC VIDEO output resolution to be at native resolution of this monitor, which is 1440x900 @60Hz.
Mar 29, 2010 | Gateway FPD1975W 19" LCD Monitor
I need a driver for my gateway monitor model nl2501. Wont go higher than the 640 by 480 point. Bad picture
You don't need a driver for you monitor, you need a driver for your video card. The first step is to find out what video card you have. Once you have loaded the proper video card drivers you will be able to see higher resolutions to select from in your display settings box.
Dec 19, 2009 | Gateway Computers & Internet
I need a driver for gateway 17 in. wide screen monitor FPD1775W
You might want to consider a default settings reset. To refresh or reset the monitor back to default settings, unplug the monitor's power cord, and then press the the power button for five (5) seconds to drain any residual power. Plug in and then turn on the monitor. The default settings load.
Additional information about your monitor is available on the Gateway support website.
Nov 19, 2008 | Gateway FPD1775W Monitor
My Gateway FPD1530 will not turn on
replace c106 and c107. fixed 3 monitors back to back, all worked like new!
Aug 27, 2008 | Gateway FPD1530 15" Flat Panel LCD Monitor
Gateway GM5084 PC Desktop Logo
102 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
